Offline patnaik
#1 Posted : 15 September 2025 01:53:44(UTC)
patnaik
I have been adding sound to my Marklin loks with Loksound 5 decoders. These loks all have the 5 pole permanent magnet motor. I set the motor type to Marklin 5* High Performance motor with the Lokprogrammer. For most of the loks this works well, but for a few I observe jerking as the lok comes to a halt, and some hunting when the speed is changed. I make sure there is no binding in the drive mechanism, and the loks run perfectly before making the conversion.
I have tried the auto-tune procedure (CV54=0) but that makes it worse. Fiddling about with the many parameters is not really helping. Can anyone suggest a step-by-step procedure to tune these motors? Thanks!
Gopal
#2 Posted : 15 September 2025 12:19:51(UTC)
Hi Gopal
I use mostly Märklin mSD3 decoders but once I made an exception for an ESU LokSoundDecoder 5 Mini (for space reasons) and it was hell tuning with 500 CVs
I ended up not using the loco and now NEVER would I use these ESU decoders again
Sorry, it is not helping but what a difference with mSD3 when used with a CS3!! Very user friendly, can program them without any additional tool (LokProgrammer) the seft-adjusting procedure works really well.
Back to your problem
The manual is here file:///C:/Users/brucy/D...ual_Edition-15_eBook.pdf
If you look at page 70, you will find a paragraph and a table on how to set the motor-related parameters. ESU mentions that jerking at low speed is when the load compensation parameter needs adjusting.
Here is an interesting paragraph in the manual
Firstly, check if the irregular performance is due to any mechanical
faults. Bent driving rods are one common cause. When you turn
off load compensation (set CV 49 Bit 0 to 0) and the problem
persists then it is likely there is a mechanical fault.
Offline Kiko
#3 Posted : 15 September 2025 21:28:44(UTC)
Kiko
Hello Gopal,
I must disagree with Jean (sorry Jean). I have converted about 15 older Marklin locos that have the five pole motors with ESU LokSound 5 decoders. These are some of the best running locos on my layout. Furthermore, the sound from LokSound 5 decoders is much better than what comes from Marklin. (Note: I have many Marklin MFX+ locos, so comparisons are "real world").
In order to program LokSound 5 decoders, you will do yourself a big favor if you use a LokProgrammer. Using CVs and programming "bits" is not the way to handle sophisticated decoders.
The ESU web site has hundreds of projects for various locos. It's easy to choose a few as starting points and customize to your liking. These projects already have the motor setups and are "good to go". I, however, always do the BEMF autuo-tune procedure because each motor differs slightly from the next and the auto-tune procedure does a wonderful job in tweeking the right CVs.
I hope this helps. Let me know what loco you're having problems with -- I might be able to help.
Andry
Andry
Offline patnaik
#4 Posted : 16 September 2025 01:07:48(UTC)
patnaik
Originally Posted by: Kiko Go to Quoted Post
Hello Gopal,
Andry
I use the LokProgrammer to load a sound project from the ESU web site into a blank LokSound 5. I then make changes from that, typically adding sounds and changing function mapping. I use the motor preset for "Marklin 5* High Performance motor" This preset typically works well. However, in particular, I am not happy with the operation of a 37132 BR 75 that came with a 5 pole motor and C90 decoder. It jerks to a stop and hunts (overshoots) after a speed change. Auto-tune was worse than the preset.
What I a looking for is a procedure to manually tune the BEMF. The instructions in manual merely say to change values if you are unhappy, and do not prescribe a step-by-step way to identify the problem and which CVs have to be changed and up or down.
Gopal
Offline Ross
#5 Posted : 16 September 2025 03:52:29(UTC)
Ross
Hi Gopal,
Using the motor preset for "Marklin 5* High Performance motor" is a good place to start.
I have found that with the LP5 series of decoders I have had more locos that jerk when stopping, see 11.1.2.2. Parameter „I“, stored in CV 55 of the decoder manual.
Using the LokProgrammer the regulation parameter “I” [CV55] was decreased from the default of 200 (400ms) to a lower value to prevent the locomotive jerking when stopping. I reduced the value by 5 and if it didn't work I reduced the value further by 5 again until the loco doesn't jerk when stopping.
Gopal
Ross
Offline Kiko
#6 Posted : 16 September 2025 19:56:15(UTC)
Kiko
Very good suggestion by Ross. There should be no reason for these locos to jerk. I converted many 5* DCM motors to LokSound 5 and they all run very smoothly even at speed step 1 (very, very slow crawl).
All digital locos need some tweeking, whether Marklin, ESU, or other decoders. It all depends on how much time you're willing to spend to get flawless performance.
Please keep us posted on your progress. Feel free to ask.
Andry
Andry
Offline applor
#7 Posted : 16 September 2025 23:14:41(UTC)
applor
Are these older loks all equipped with 5 pole motors? Maybe try the DCM motor pre-configured setting (or LFCM/SFCM if that is what they have)
Also just checking you did left the motor chokes installed? The only choke to be removed is the one connected across the motor poles, the ones inline need to remain.
Offline patnaik
#8 Posted : 17 September 2025 00:01:49(UTC)
patnaik
Andry
I have tried auto-tune several times with poor results. I have tweaked parameters from the default 5* ones and have been able to get good mid- and high-speed performance. Low-speed is good down to step 2/28 but 1/28 is jerky and there is a lurch when speed is set to zero. Motor is quite loud at step 1. Fiddling with the low-speed parameters makes things only slightly better.
Gopal
Offline patnaik
#9 Posted : 17 September 2025 00:23:23(UTC)
patnaik
These are 5 pole DCM motors. I start with the presets for this motor type.
My understanding is just the opposite. All chokes and capacitors are to be removed except for the one across the motor poles, which can remain.
Gopal
Offline Kiko
#10 Posted : 17 September 2025 10:08:24(UTC)
Kiko
No, you have to remove the chokes across the motor. I often remove all chokes.
Andry
Andry
Offline patnaik
#11 Posted : 17 September 2025 18:41:29(UTC)
patnaik
Andry
I removed the choke/capacitor across the motor brushes. No discernible difference.
Offline Kiko
#12 Posted : 17 September 2025 19:44:46(UTC)
Kiko
I'm on vacation away from my layout, so I don't have access to my LokSound projects. I would recommend looking at your voltage CV -- I keep mine lower than suggested -- and then run your auto-tune.
Attached is a good reference article that could help you.
BEMF Setup.pdf (165kb) downloaded 37 time(s).
Andry
Offline patnaik
#13 Posted : 19 September 2025 16:23:40(UTC)
patnaik
Kiko,
I have the voltage CV 53 set to 60, about 1/2 the initial default value. I then tried auto-tune several times with poor results, both at mid-speed and low speed.
The reference article is for V4 which has slightly different CVs to control BEMF. V5 for example does not have a I slow, just a single CV for I (CV 55).
The problem appears to be that I has to be large enough (sufficient damping) to prevent oscillations at mid-speed, but also as low as possible to prevent the jerk when stopping. I have not been able to come up with a value for I that satisfies both. I have kept K small so I can be lower without oscillations. I think that this small tank locomotive just does not have enough inertia on its own unlike my heavier locomotives.
Gopal
Offline Kiko
#14 Posted : 19 September 2025 22:23:51(UTC)
Kiko
Yes, the reference article is for the v4, but it's the principles which are explained that make it useful.
Being on vacation, I don't have access to my LokSound files. When I return next week, I could look into the values that I use for my small locos.
I have several small locos with LokSound decoders -- BR80 (33041), V36 (37368), V60 (3064) -- and they all run very well at crawl speed.
One caviat that I need to mention -- I replaced the original motor of the V36 with a sb-Modellbau motor. Now it crawls at unbelievable smoothness.
All I can say is to keep trying, but only change one parameter at a time in order to keep track of what works and what doesn't.
Andry
Edited by user 20 September 2025 21:47:55(UTC)  | Reason: Not specified
Andry
This page was generated in 1.261 seconds.
