Offline rogerh2025
#1 Posted : 22 August 2025 08:17:36(UTC)
rogerh2025
The loco has one rear led which has been flickering,and is now inop.I have cleaned feed wire, and contact on the body cover to no effect .Marklin site shows these as maintenance free,and part of the body assembly.Switching the body front to back,shows the led light is at fault. Does anyone have any experience with these?
Offline Chas
#2 Posted : 24 August 2025 12:41:47(UTC)
Chas
I have had the solder come away from the light and oil on the plate where it connects, worth a try?
Offline rogerh2025
#3 Posted : 24 August 2025 18:38:04(UTC)
rogerh2025
Originally Posted by: Chas Go to Quoted Post
I have had the solder come away from the light and oil on the plate where it connects, worth a try?[/quote Can these be prised away from the body to repair?
Offline Chas
#4 Posted : 24 August 2025 19:01:12(UTC)
Chas
are the tangs on part 5 bent enough to touch and are they clean?
Offline rogerh2025
#5 Posted : 24 August 2025 19:12:46(UTC)
rogerh2025
I have adjusted the copper tangs several times to ensure contact,with no success Led contacts and tangs cleaned with lighter fuel,no success......
Offline Zme
#6 Posted : 25 August 2025 06:51:14(UTC)
Zme
Hello, hope all is well.
This is a tough issue. Most of the time, adjusting the circuit board tangs solves the problem.
I just would like to ask a few questions, I hope you don’t mind.
Would you have a similar locomotive which you could use to test the lights? See if the results are the same on a different chassis. As long as it has the same length chassis, it may be a Br 200 or 151 from the same period as your release.
No chance this might still be on warranty from your vendor? I believe this is an older 5 pole chassis which has been around for a while.
Do you have a source for old Marklin z parts? It is possible the circuit board is defective. Is it possible to check the LED by using text probes from the controller?
Does this model have the LED module fastened to the shell. It might not be possible to replace these. Just getting them loose from the shell, however, might cause serious damage. I have seen the light module removed and soldered to the tangs. I don’t believe this is a solution. Placing the shell back on the chassis correctly becomes an issue.
There may be a source for the lights, but I am not certain Marklin will have them. You may need to do more research to get the correct LEDs. High-tech modelbahn might be of assistance. https://www.z-hightech.d...g=6&sprache=englisch Shipping might be prohibitive.
I hope this might help.
Let us know what happens. Take good care.
Zme
Offline rogerh2025
#7 Posted : 25 August 2025 07:52:53(UTC)
rogerh2025
Swtiching the body around front to back,shows the same led is affected.So the light source is the problem,not the contact.
The led block is fastened to the body,so likely to be damaged,and damage the lights if prised off ..
One led still working,so I will live with it .......
thanks 1 user liked this useful post by rogerh2025
Zme
Offline Poor Skeleton
#8 Posted : 26 August 2025 22:40:01(UTC)
Poor Skeleton
I don't have any experience with this particular model, but I do know about electronics. The fault here certainly could be with the LED itself, but it could also be with the supporting circuitry, which probably consists of a regular diode a resistor and capacitor. Capacitors of the type used here are prone to fracture due to mechanical stress and that can cause them to fail over time in a way consistent with your description.
If I'm correct, though, the circuit board with the LEDs is mounted in the body shell and not easily removed and I think that is the major obstacle to resolving the problem. If you can remove the PCB it can almost certainly be repaired and you may even be able to sweet talk Marklin into sending a replacement. I'm very happy to help or advise if you do manage to get it out.
Good luck
Chris
Zme
Offline rogerh2025
#9 Posted : 27 October 2025 19:29:32(UTC)
rogerh2025
I contacted Märklin by email,and was given a repair number and sheet to complete
The loco was despatched,and has taken over a month to reach them ,from the UK .
Mail in the other direction arrives in around eight days .
I was uncertain they had collected it from Customs ( which is the norm),but heard from Märklin yesterday that the repair is in the queue.I was concerned the loco was kicking around lost - we will see........
Zme
#10 Posted : 27 October 2025 22:50:45(UTC)
Poor Skeleton
My experience of Marklin Service department has been positive, so I'm fairly confident they'll be able to repair this for you.
Chris
Zme
Offline Zme
#11 Posted : 28 October 2025 01:52:25(UTC)
Zme
Hello, great to hear Marklin is involved. Is this a warranty repair or must you pay? I suspected Marklin will repair anything within reason.
I was wondering if this is a newer Marklin model and if you purchased it from an authorized vendor? (I have since checked, this was last produced in 2008)
I have a V300, 88300. It has the same issues, but I purchased on eBay and someone tried to fix it, but failed. I would be very happy if Marklin accepted this for repairs. Appreciate your reply.
Thank you.
Zme
Offline rogerh2025
#12 Posted : 28 October 2025 07:12:33(UTC)
rogerh2025
There is a payment limit requested on Märklin's form,after which you are evidently contacted.Not an expensive job I would guess for them ......
I should add ,I have bought all my locos used.Those from auction site have all needed work to get them running well,or at all . Mainy lack of proper lubrication,or brushes required .......
Zme
Offline rogerh2025
#13 Posted : 31 October 2025 18:00:26(UTC)
rogerh2025
Marklin have checked the loco.Led's are defective on one side,they have sent an estimate of 33 euros to replace.
These were supposed to be maintenance free .
I had allowed up to 48 euors to include postage,which I thought was reasonable.
They are carrying on with the repair - there is a four to six week backlog wait on repairs .......
Zme
Offline Zme
#14 Posted : 01 November 2025 04:34:55(UTC)
Zme
Hello, thanks. Maybe something different needed attention.
So much for maintenance free. It is what is known in the business as just a term of art.
You had to pay shipping both ways, I imagine. I feel your pain.
It will be worth repairing though. That is a nice locomotive will be nice to get it working again. Let’s us know how it turns out.
Take good care.
Zme
#15 Posted : 02 November 2025 19:35:31(UTC)
Poor Skeleton
I suppose just because something is maintenance free doesn't make it defect free!
Modern electronics is susceptible from damage from static discharge, and the worst of it is that that damage is not usually exhibited immediately and can take months to show itself. Red LEDs are usually not terribily delicate - I think there is a lot of bad luck behind this incident!
It has been an expensive repair (the faulty part itself, probably costs less that $0.10/£0.10) but I know I would also pay a disproportionate amount to have a loco fully operational!
Chris
Zme
Offline rogerh2025
#16 Posted : 02 November 2025 19:42:16(UTC)
rogerh2025
Its not over yet,so I'm not holding my breath.
People's time has to be paid for,and these locos are made in a way that the leyman can't tamper.
Unfortunately,I like things right,so its a licence to print money .......
Zme
Offline rogerh2025
#17 Posted : 06 November 2025 16:44:13(UTC)
rogerh2025
Ten days after authourising the repair,the loco has arrived back from Märklin.The faulty led unit was included in a bag. I tested the loco running,lights now working ok forward and reverse,apparently no charge after all from Märklin for the work. However,after about four minutes the body was getting excessively hot - not just warm.....
I took off the body,and although it was well oiled when it left me,there was no oil present in the drive gears.I do not know if the frame is dipped to clean it by them,or ultrasonically cleaned.The gears and pins were then oiled ,and put back.All now running ok.I think the top drive gear on the bogie needs to be free running on its pin.....
thanks 2 users liked this useful post by rogerh2025
ZmeRFC1
Offline rogerh2025
#18 Posted : 12 November 2025 08:15:41(UTC)
rogerh2025
Unfortunately,a bill for £35 has turned up from Märklin,which I have had to oay.Not so much goodwill as I thought.........
Offline Zme
#19 Posted : 13 November 2025 01:40:20(UTC)
Zme
To me that sounds like a fair price, perhaps quicker work than I would have expected. Were import fees charged in that total? Keep in mind, there are cheaper scales, but Z is always sold at a premium, especially now.
Can you tell if any other parts were replaced? Since the LED was bad, was there a way it was replaced or was the shell itself replaced?
I suspect the locomotive was cleaned, perhaps using the lighter fluid method or equivalent. That might explain why it was dry when you got it back.
It actually surprised me to hear credit was extended for this work. I suspect that is the only way this kind of work could be done.
I hope everything is fine and I hope you are satisfied.
Take good care.
Zme
Guest (5)
This page was generated in 0.389 seconds.
