Offline km90
#1 Posted : 13 August 2025 20:24:25(UTC)
km90
I started on a track plan based on this layout:
So far I've managed to this. However, I'm kindly asking the experts (I'm a complete novice) for any ideas and/or help with the following items:
- Any ways to get the inclines between the levels closer to 3% (Right now around 3,5%)
- Get track 2 & 3 connected on the right side so both tracks can be used for trains going through, and not using R1
- To get the slim turnouts at the left part of the station
If it helps, it should be fine to widen the layout a bit.
Thanks in advance for any help or tips! :)
thanks 3 users liked this useful post by km90
#2 Posted : 14 August 2025 10:52:11(UTC)
Nice concept, but quite a challenge for a beginner.
I have seen this one before. Is this your own image?
For example, the left curve should reach the rear edge of the layout as shown in the first image (but not replicated in the track plans), which extends the track length and thus reduces the gradient.
Do you mean that you want to avoid a 24671 turnout?
Well, the 246xx turnouts are not per se bad if used in „proper“ setting, depending on viewing angle and embedding in other C track segments. I understand your concerns. However, I doubt that everything can be conveyed in a „crash course“.
The double-track line exiting the station the left side is winding itself down to a reverse loop, but where is the double-track line exiting the station on the right side going to?
BTW, here is a similar design by a German Stummiforum member - see post #38:
https://www.stummiforum....-Gleis-1.html#msg2822885
Offline km90
#3 Posted : 14 August 2025 11:50:04(UTC)
km90
No, I found it on Stummiforum and used it for inspiration.
Yes, I'm aware of that from the original plan. My idea is to have the train coming back in a reverse loop (after been in a shadow station) so trains are coming back the way the came from. :)
Exactly. :)
I tried a bit and managed to get a few of them replaced, but would naturally be nice to replace all (or almost all) replaced. I'm open to the idea of re-arranging the station entry.
It's also going to a reverse loop (shadow station).
thanks 1 user liked this useful post by km90
#4 Posted : 14 August 2025 23:50:39(UTC)
Exactly. :)
Why, as it would not be not visible in the concealed area? I would rather be concerned with the performance of the foreseen 24771 turnouts on a slope.
Then one of my ideas might serve as food for thought - see post #180: https://www.marklin-user...d-innovations#post614376
Edited by user 15 August 2025 12:56:10(UTC)  | Reason: Not specified
#5 Posted : 16 August 2025 15:33:10(UTC)
The layout dimensions seem to be 180 x 340 cm. Thus, there is enough space for this approach for creating longer ramps in order to reduce the gradient.
NB regarding the depth: Human arms are not long enough to reach 180 cm.
Offline km90
#6 Posted : 17 August 2025 16:43:22(UTC)
km90
I'm running trains with long passenger cars and after reading on some forums, those cars don't really like R1. That's the only reason, nothing about the aesthetics. :)
Obviously there needs to be some compromises in a smallish layout like this, but the fewer the better I suppose. :)
I tried following this a bit, but got lost really fast.. If I could get concrete directions (for example a track plan to follow that suits my layout) would be much appreciated. It looks really cool though!
And to answer your point from your other post. The layout right now is 325*175cm. I'm aware that 175 is too deep in general, however the layout will be on wheels so can be reached from all 4 sides if necessary.
#7 Posted : 17 August 2025 20:16:30(UTC)
Yes, I got the hint - see track plan below: "level 0" track in red, 175 x 350 cm surface, maximum gradient 3%, station through tracks at least 170 cm long between turnouts, stub tracks placed at will, minimum radius = R2, no turnout on a slope, "trouble-free" standard R2 turnouts in concealed area, 24912 segments used for curve easements in visible areas.
Personally, I am not impressed by the performance of three-way turnouts or wide curve turnouts. That's why I avoided the former and placed the latter (one specimen only) at the front in case excruciating troubles require easy access; the return loops can be adjusted to your needs, e.g. by adding shadow station sidings.
#8 Posted : 17 August 2025 20:46:44(UTC)
A close-up view of the the station throat - see below. The C track slack accomodates the small gap visible in the track plan.
Depending on the purpose of the stub tracks on the right side of the station, a switching lead could be added in the front after replacing the far right 24611 turnout by a double-slip turnout in order to prevent shunting maneuvers to foul the main line.
Offline km90
#9 Posted : 17 August 2025 21:45:38(UTC)
km90
Wow, that's really cool! Thanks a lot for the ideas, it definitely gave me some solutions and inspiration. :) Supermega thank you!
Is it possible to get a copy of the Railmodeller-file? :)
#10 Posted : 17 August 2025 23:38:43(UTC)
PM sent.
#11 Posted : 27 August 2025 19:32:09(UTC)
Further to post#8, I tested the plan with real C track sections (24640 served as a substitute for 24620...), and it works.- see photo:
#12 Posted : 27 August 2025 19:44:21(UTC)
I tested the plan in post #8 with real C track sections (24640 served as a substitute for 24620...), and it works.- see photo:
#13 Posted : 25 October 2025 13:05:56(UTC)
This Facebook find reminds me of your project.
Source: https://www.facebook.com...t=pcb.122157452786761208
Offline km90
#14 Posted : 26 October 2025 13:04:50(UTC)
km90
That indeed looks really interesting! Thank you for the tip. The track plan is still not finalized, so any inspiration is good inspiration. :)
Offline km90
#15 Posted : 10 November 2025 19:08:48(UTC)
km90
It has now turned out that there will be a little more space to build a layout than previously thought.. :) Now I'll have access to an area of ​​3x4m. Those of you who are more experience than myself on the subject, what is preferable, U- or L-layout?
Does anyone have any ideas how to develop a track with the idea above into an L- or U-layout?
Gratefully accepting all tips and tricks. :)
Edited by user 11 November 2025 00:27:08(UTC)  | Reason: Not specified
#16 Posted : 10 November 2025 23:09:02(UTC)
Does anyone have any ideas how to develop a track with the idea below into an L- or U-layout?
Do you mean “above” instead of “below,” i.e., adapting the original approach to the enlarged space? Or are you planning a complete redesign?
Offline km90
#17 Posted : 10 November 2025 23:26:34(UTC)
km90
Yes, I meant above. I shouldn’t do two things at the same time..
I like the original idea of having a town partially above the main station, but I’m generally open to different ideas as long as it fits ep. VI and long (6-7 cars) trains. :)
#18 Posted : 11 November 2025 01:31:43(UTC)
Post #16 of this Stummiforum thread presents a L-shape iteration of your approach:
https://www.stummiforum....-C-Gleis.html#msg2261360
Post #11 of this Stummiforum thread presents a different U-shape idea:
https://www.stummiforum....-C-Gleis.html#msg2272775
3D simulations of the track plans, along with suggestions for the design of the shadow stations, can be found under the respective link.
Edited by user 11 November 2025 10:49:04(UTC)  | Reason: Visualisation...
Offline km90
#19 Posted : 11 November 2025 14:02:49(UTC)
km90
Ah, yes. I frequently visit those threads on Stummiforum. The poster of those layouts gives a lot of inspiration. I was trying to look at some others and in general getting peoples experience between U- and L-shaped layouts, pros and cons etc.
#20 Posted : 11 November 2025 15:20:59(UTC)
I see.
Edited by user 11 November 2025 22:19:38(UTC)  | Reason: Not specified
This page was generated in 0.589 seconds.
