Offline JohnMishler
#1 Posted : 20 May 2025 21:49:51(UTC)
JohnMishler
I have several old semaphores that I acquired in a “mystery” box purchase about 10 years ago that I’ve never incorporated into my layout. I’d like to try to re-use those in my current layout but am at a total loss for wiring them. I currently have a couple of Marklin 74391 Color Light Block Signals in my layout working as expected connected to a M84. I use a CS3+ with the layout controlled via Rocrail. Thus, I am not using braking modules/sections nor will I use the M84 for track control but instead just for signal control. Below are some pics of one of the signals in question. I have no idea of brand or model number for the semaphores. There are 6 wires on the signal with 2 of them seemingly paired in a red sleeve and another 2 seemingly paired without a sleeve. The other 2 wires are separate one from the other with each having a black sleeve. Any thoughts or suggestions on how I might wire them to a M84 port would be much appreciated!
Check out progress on my layout here.
Offline Martti Mäntylä
#2 Posted : 21 May 2025 17:14:31(UTC)
Martti Mäntylä
This does not help a lot, but your signal looks similar to these ones: https://www.trainmaster.ch/ZY-490.htm
- Martti M.
Offline JohnMishler
#3 Posted : 21 May 2025 19:38:50(UTC)
JohnMishler
That is actually very helpful. I’ve located the manufacturer website and made an inquiry directly to them for wiring information. Again, many thanks!
This page was generated in 0.325 seconds.
