Offline mornick
#1 Posted : 23 April 2025 19:45:16(UTC)
mornick
Hello dear marklin users community!
After almost 2 decades, I managed to buy my first Marklin CS1 60212. Don't ask me why, I know that in CS1 in 2025 is rubbish, but it was my dream since I was a child to own one... One thing led to another and now I have 3. (Judge me freely ...). My question is if I can connect two CS1s together to make a 4 locomotive console. Is it possible? Otherwise, I'll buy a terminal and connect my MS1s because I have 4 of them. I kinda love the old consoles. I know they are very limiting against a modern CS3 etc but, this is what I always wanted to do....
Any help/ideas/advice are greatly appreciated, and I'm really looking forward to get into model railroading again, because I was into a 10-15 year old hiatus.
Greetings
Nick
Offline pederbc
#2 Posted : 23 April 2025 22:59:25(UTC)
pederbc
Hi Nick,
Connect the track output on one CS1 to the ”sniffer” input of the other. Check the manual on how this work.
Peder
thanks 2 users liked this useful post by pederbc
Offline mvd71
#3 Posted : 24 April 2025 09:09:04(UTC)
Hi Nick,
The Cs1 while old, is still a very capable controller. As described you can connect via sniffer port.
Cheers….
Offline mornick
#4 Posted : 24 April 2025 16:10:31(UTC)
mornick
Originally Posted by: pederbc Go to Quoted Post
Hi Nick,
Peder
Thanks for the response, do you have any idea on how that's possible? Because I haven't used a sniffer before...
Offline pederbc
#5 Posted : 24 April 2025 21:47:43(UTC)
pederbc
Hi again,
Here is an excerpt from the manual:
Replace the example 6041 with your other CS1.
If you don’t have the manual, you can download it from Märklin: https://www.maerklin.de/...S_60212-update_DE-EN.pdf
Note! The middle picture is continueing text from the last picture!
Hope it works for you, Peder
Offline mornick
#6 Posted : 24 April 2025 23:37:47(UTC)
mornick
Hi again,
Hi again, I tried it and it worked!! However it only works with fx lovomotives... Completely understandable for the provided early 2000's technology.
Also I should note that I reached out to Marklin and they said that it is not possible to connect two CS1s together...
Thanks again.
Nick
Offline pederbc
#7 Posted : 25 April 2025 00:18:56(UTC)
pederbc
Hi Nick,
I don’t think it’s restricted to fx (motorola protocol). All of your loks has to be defined in the primary CS1 as mfx, dcc or fx, of your choice. In the setup you define the sniffer address regardless of the real address. If it’s an mfx there’s no address anyway. As stated in the manual you can only set addresses between 1 and 80. On the secondary (slave) you create a virtual lok, perhaps with same name as the real one and define it as an fx lok with the same address as the sniffer address defined on the primary CS1. As also stated in the manual you can only use functions F0 to F5 on the secondary CS1.
Peder
Offline mornick
#8 Posted : 25 April 2025 20:22:38(UTC)
mornick
Hi Nick,
Peder
Well that sounds very promising, I'll definetely give it a try!!!
OceanSpiders 2.0
This page was generated in 0.585 seconds.
