marklin-users.net community
| Forum
Home
Community Forum
Login
or
Register
Forum
Active Topics
Login
Register
OK
General topics
H0-scale
New Edelweiss Coach set
3 Pages
1
2
3
Go to Page...
New Edelweiss Coach set -
Is it to heavy ?
Email this topic
LinkBack Topic URL
Retweet this Topic
Share Topic on Google+
Like this Topic
Share on Facebook
Digg this Topic
Reddit this Topic
Share on Tumblr
Watch this topic
Print this topic
» Normal
Threaded
Previous Topic
Next Topic
Posted :
08 January 2025 11:51:21(UTC)
Retweet
Hello Sally
I have this wonderful set and the cars are very detailled and do not need any superdetailling
The bag of extra parts (with each car) contains:
- the folding inter-car corridors in retracted position (for extremity cars)
- the brake lines (non-compatible with normal operation and couplers but rather for showcase)
Note: the arrangement of cars in the consist is imposed by Märklin:
- the baggage car at the end with the slider and folded bellows at the end
- the other (non-fitted with red marker lights) at the other extremity
- all other cars (Voitures salon) inbetween
If you need to change the arrangement of cars you may need to:
- swap the unfolded bellows for folded ones or vice-versa
- change the current pickup location but ONLY ONE pickup per consist AND you need to open the car to change the pickup location which is not recommended because these cars are fragile and complex
Here is an opened Voiture Salon (bottom part only
A wonderfull set BUT ATTENTION any coupling with a loco fitted with older couplings may cause derailment so better change the loco coupling for the last (super-flat) ones #72000
My layout videos
latest vid
marshalling yard
My Layout
4 users liked this useful post by JohnjeanB
mbarreto
Bent
User Profile
View All Posts by User
View Thanks
Posted :
08 January 2025 13:28:14(UTC)
Retweet
Refer to the instructions manual and it may show. These are usually grab irons, roof vents, destination boards and or bogie and undercarriage details. Brake parts, axle speedometer, or climate control parts. Some may fall off and get lost during running around the layout.
User Profile
View Thanks
Posted :
08 January 2025 16:39:32(UTC)
Retweet
On this set all grab irons and roof vents are factory installed
My layout videos
latest vid
marshalling yard
My Layout
1 user liked this useful post by JohnjeanB
User Profile
View Thanks
Posted :
08 January 2025 17:38:44(UTC)
Retweet
Yes, and the parts are probably something that fits under the carriages and where they go is no doubt shown in the instructions.
My set is still in my jumble of Marklin items from my move last year, but if I locate those coaches I will let you all know.
It won't be something that is important as far as running the coaches, but more likely something primarily for display purposes.
I have never seen any Marklin model without the grab irons already installed at the factory.
User Profile
View Thanks
Sally
#105
Posted :
08 January 2025 19:17:34(UTC)
Retweet
You have all been so very helpful! Thank you.
I do not see grab irons in the cars when I look through the windows. I think they would look nice if they were factory installed down the middle of the ceiling. I imagine that I could glue them to the undersurface of the ceiling under the light plate... Not sure it is worth the risk in my hands.
Thanks again!
User Profile
View Thanks
Posted :
08 January 2025 19:26:01(UTC)
Retweet
The grab irons people referenced are on the outside, placed besides the doors.
User Profile
View Thanks
Sally
#107
Posted :
08 January 2025 20:39:28(UTC)
Retweet
There are no Grab Irons outside the doors on the Edelweiss cars.
1 user liked this useful post by Sally
User Profile
View Thanks
Posted :
08 January 2025 20:46:47(UTC)
Retweet
Hi Sally,
I had to check what was in those bags and Jean already answered this, which I somehow missed.
The rectangular pieces are the retracted diaphragms that would replace the extended ones that came installed on the coaches. You would only install them if you were running one of these coaches at the front or rear of the train. In normal operation the baggage cars would be in those positions, and they would not be needed. So they are probably not something that you would ever use.
Jean's other answer is also correct, and the tiny bits are brake lines that you would only install if these were being displayed, not operated. So basically they are part of the set and should be kept, but not something very likely to ever be used.
Doing this reminded me to get some track powered to run these on, since I have never even seen them lighted yet! Sad but true.
1 user liked this useful post by dickinsonj
User Profile
View Thanks
Posted :
08 January 2025 20:49:59(UTC)
Retweet
Your are quite correct. Those kind of grab bars are normally seen only on locomotives. I was just clarifying what marklinist5999 had suggested.
User Profile
View Thanks
Sally
#110
Posted :
10 January 2025 18:23:39(UTC)
Retweet
Does anyone know where these parts fir on the Edelweiss pullman cars?
Thank you!
User Profile
View Thanks
Posted :
10 January 2025 18:41:05(UTC)
Retweet
Thank you!
The small parts are brake hoses/cables etc, intended for vitrine displays. they are to go where the yellow markings are. (both ends on all cars)
otherwise, there are also some loose steps for the baggage cars, also intended for vitrine displays. mounting positions marked in red.
turn your wagons upside down and you will see mounting holes "under" the couplers for the brake hoses/cables etc.
Unfortunately, the instruction manual does not include any information about where to mount the extras.
2 users liked this useful post by bph
User Profile
View Thanks
Posted :
23 February 2025 12:45:44(UTC)
Retweet
Regarding the "dimm" table lights.
there are some interesting posts over at stummiforum
https://www.stummiforum.de/t220678f2-Pullmanwagen-Set-Edelweiss-5.html
one guy there has improved the table lights and installed a decoder in each wagon. Quite interesting but it seems that he has wired the table lights directly to the decoder and in the process bypassed the buffer capacitors on the main/roof PCB. ?
overall I wish there was a way to only dim the roof lights and leave the table lights as they are.....?
But overall the wagons are great, and the slightly dim table lights are only a minor detail.
Tried the
42470
after a locomotive with a dimmable current-conducting coupler and it was only possible to dim them very slightly, and of course, the table lamps were also dimmed. (same type of relay as used in
39781
User Profile
View Thanks
Posted :
23 February 2025 13:19:10(UTC)
Retweet
I have considered dimming the overhead lighting with some type of cover, which would be much simpler than doing it by altering the electronics. Perhaps some yellow plastic under the LEDs to make the light warmer and lower intensity compared to the table lamps.
I haven't even opened one of these beautiful coaches yet, but I may give that a try whenever I get some time to experiment.
2 users liked this useful post by dickinsonj
User Profile
View Thanks
Posted :
24 February 2025 15:47:38(UTC)
Retweet
Hmm, that is a good idea. I will keep an eye out for something that might be usable.
User Profile
View Thanks
3 Pages
1
2
3
Go to Page...
General topics
H0-scale
General topics
- General MRR
- H0-scale
- Small scale
- Big scale
- Prototype
--- Videos
----- Steam
----- Electric
----- Diesel
----- Accidents
- Digital
- Model railroad software
- Model railroad photography
Reviews
- Loco Reviews
- Reviews of rolling stock
- Accessories reviews
- Model kit reviews
Collector's Corner
- Collector's Corner general
- Märklin Sprint
- Construction kits
- Steam engines
- Tinplate toys
The Projects & Workshop area
- Track plans
- Painting & Weathering
- Model railroad wiring
The Club Corner
You
cannot
You
cannot
You
cannot
You
cannot
You
cannot
create polls in this forum.
You
cannot
vote in polls in this forum.
Powered by YAF.NET
This page was generated in 0.811 seconds.
