Offline Heh Igunen
#1 Posted : 16 December 2024 14:58:38(UTC)
Heh Igunen
Poland
Hello!
I am brand new to model-train hobby and I choose Marklin as my system.
I bought two locos for the very beggining: 39021 and 34831.
First of all: what decoder do I need for 34831? is for example LD-W-32 matching? I just want to control it from the MS2, now this little one acts like a mad dog :)
Secondly: I have the 3.5mm smoke generator and I've tried to use it with my 39021 but it doesn't work. Generator itself is working (hot-wire and tested with 37184) but no react here.
Furthermore, I've tried to connect it with a decoder--smoke plate and directly to the neutral (brown) cable and it works fine. It seems that while generator is in the funnel there is no neutral connected.
How I could fix that?
thanks 1 user liked this useful post by Heh Igunen
#2 Posted : 16 December 2024 15:12:03(UTC)
welcome Heh! I presume that the stack of your little railcar is plastic? If so, you need to solder a ground wire to the lower side of the generator after pushing it into the stack. I can't think of another way other than to sleeve the plastic stack with a metal sleve first, and siolder a wire to it.
By the way, I am 25% Polish, 75% Italian American second generation. My mother's grand parents sailed from Danzik in 1919 and 1920, from Telschow. Sir names were Scripski and Xylowetz. They settled in and near New Castle, Pebbsylvania.
Online kiwiAlan
#3 Posted : 16 December 2024 15:16:58(UTC)
If the body is plastic there is a version of the smoke units that have two wires. But you also need to take care that you don't melt the plastic body with the heat from the smoke unit.
Offline Heh Igunen
#4 Posted : 16 December 2024 15:24:02(UTC)
Heh Igunen
Poland
Guys, 39021 has full metal body, it should work without any wiring :)
#5 Posted : 16 December 2024 15:26:01(UTC)
Then just sand the inside of the stack a bit.
#6 Posted : 16 December 2024 18:12:30(UTC)
Hi Heh
NOTE: I never ever experienced contact issues between a Märklin metal body and the ground.
Problems come always from:
- a broken wire
- a dead decoder output (rather rare)
- a poor arrangement of the wire protruding out of the smoke unit (see Märklin installation recommendations below)
- a bent contact on the loco
- air in the smoke tube or over-fill of the unit (never more than 50% or the total capacity)
Offline Heh Igunen
#7 Posted : 16 December 2024 20:41:30(UTC)
Heh Igunen
Poland
Hi Heh
- a broken wire
Hay, as I said the tube is working well when I apply neutral wire from the track and not from the body. It works with the other loco without a problem as well.
Offline mvd71
#8 Posted : 17 December 2024 05:52:44(UTC)
I had difficulties some years ago with the 72270 smoke unit in both the BR55 and BR64. I did the same checks you did and had the same results.
I suspect the modern decoders are not well matched to the 72270, and it would perhaps work better with a seuthe smoke unit. I think the Suethe No. 20 is appropriate, but best check because I haven’t looked at these in years.
Offline kiwiracer
#9 Posted : 17 December 2024 07:01:42(UTC)
kiwiracer
My experience with smoke generators is limited but following investigation I found that the Suethe No 20 (same as Maerklin 77270) is for use with non-digital type locos. Whereas you need the Seuthe No 24 for use in digital locos.
The non-digital loco smoke generators work on a lower voltage upto about 20V or so, whereas the digital locos use a higher voltage 24v + to activate the smoke generator.
As per Jean's diagram it is also important that you ensure the contact on the smoke generator is positioned correctly so as to make contact with the metal tag in the loco.
I stand corrected if what I found is in-correct.
We all learn as we go along.
Don't dodge difficulties, meet and defeat them. (Anon)
Anyone can eat an elephant, one bite at a time (Anon)
thanks 1 user liked this useful post by kiwiracer
Offline mvd71
#10 Posted : 17 December 2024 08:08:35(UTC)
Ok, number 24 it is then.
My experience of smoke units in locos from that period of manufacture was always a bit disappointing. Earlier ones and newer ones (new tooling br78) has been great
#11 Posted : 17 December 2024 13:11:30(UTC)
I thought it's the opposite of lower voltage for the digital and higher for analog. At any rate, my experience is with both the Marklin and Seuthe brands, and both narrow and wide stacks. The narrow one in my br 10 has always been sporadic. Interchanging with the 24 and 20 makes no difference. It's an early sound model and I don't know what the decoder parameters are. My newer br 38 smokes great.
Online kiwiAlan
#12 Posted : 17 December 2024 19:12:26(UTC)
The 3964x series of Br64 are known to have problems with the grounding connection between the body and chassis.
Offline Heh Igunen
#13 Posted : 19 December 2024 18:51:18(UTC)
Heh Igunen
Poland
ok, so after another try this little wire from tgebottom felt off... so I need to buy another generator for tries. I assume that I would go for Suethe n.24 as mentioned, even tho it looks same as marklin but costs more ;)
And I thought the layout and tracks/cars gathering would be the worst part....
Offline Heh Igunen
#14 Posted : 23 December 2024 21:43:28(UTC)
Heh Igunen
Poland
another:
do You think that I need additional power supply for that kind of layout?
[img=http://ibb.co/8NvQ3YV]layout[/img]
Offline einotuominen
#15 Posted : 02 January 2025 11:32:03(UTC)
einotuominen
Originally Posted by: Heh Igunen Go to Quoted Post
another:
The trackbox that comes with MS2 is enough to power almost any layout. Just make sure to have several feeder wires evenly spaced. Many recommend a feeder every 1 meter, but I think one every two or three is enough.
The question is more of how many locos are you planning on running at the same time and will you have passenger cars that have interior lights?
-Eino
thanks 1 user liked this useful post by einotuominen
#16 Posted : 02 January 2025 11:52:49(UTC)
Yes, unless it's a quite large layout you may need a digital booster and that requires a separate power supply. This is where it gets more expensive, so a CS 3 may be more economical because it has a powerful booster inside.
Offline Heh Igunen
#17 Posted : 02 January 2025 17:49:25(UTC)
Heh Igunen
Poland
I've just ordered CS3...will see.
How to upload images properly? I would like to share changes to layout
Online kiwiAlan
#18 Posted : 03 January 2025 15:24:39(UTC)
Click on the paper clip icon in the tool bar when writing your post, and follow the directions the resulting pop-up gives.
Offline Heh Igunen
#19 Posted : 06 January 2025 19:43:04(UTC)
Heh Igunen
Poland
New layout in the attachment
Guest (4)
This page was generated in 0.787 seconds.
