Offline geir
#1 Posted : 08 October 2023 17:53:52(UTC)
geir
Have anyone made a railroad crossing track for marklin c track? My plan was to glue thin pieces of wood between the rails but the problem could be the 3 rail,maybe gluing a thin wire on top to get contact?
thanks 1 user liked this useful post by geir
Offline dave55uk
#2 Posted : 08 October 2023 21:19:23(UTC)
dave55uk
I have wondered the same so will be interested in any replys/suggestions.
Offline mmervine
#3 Posted : 08 October 2023 22:13:17(UTC)
mmervine
thanks 2 users liked this useful post by mmervine
#4 Posted : 09 October 2023 00:55:48(UTC)
I get the impression one of those is included in the 5104 and 5107 kits mentioned (and linked at bottom of that page). The 5104 and 5107 appear to be complete railroad crossing kits with barriers, St Andrews cross signs and all the other signs and bits to go around a crossing, the difference between the two kits being the barrier style.
Offline mmervine
#5 Posted : 09 October 2023 01:52:29(UTC)
mmervine
That is correct. The 5106 part is available separately.
thanks 1 user liked this useful post by mmervine
#6 Posted : 09 October 2023 10:53:41(UTC)
Hi Geir
I did it on a Faller old-style crossing to adapt it for the Car System, and it was based on C Track
I used thin plywood (3 mm) with lots of filing. Between the rails, I used a spare plastic (polistyrene) of a dark colour, I used brass nails to figure the studs and placed them so they would not interfere with the Car system (Slider and wheels)
I used also the Faller "grove machine" to cut the grove for the cutting wire.
Here it is during the trimming
And here it is a little later during operation
There is a lot of trimming and filing but the result is fun
There is anoter approach to C Track level crossing (but I did not try it myself:
- use a long straight (e.g. 24188) use a powerful soldering iron to heat the studs from underneath so that they come 0.5 mm above the rail surface.
- then prepare a long rectangle out of a dark plastic to make the "planks" between the rails and mak the studs location, drill them
- install the "planks" between the rails and adjust
Note: you may have to cut a rectangle in the in-between space between the rails to allow the studs to be raised in a gentle slope
Why dark plastic? Because of abrasion, sooner or later, the paint will go away in small places (wheel friction, Car System friction)
thanks 9 users liked this useful post by JohnjeanB
#7 Posted : 09 October 2023 14:36:02(UTC)
Views messages in topic : 6,096
A German märklinist used this current-conducting Weinert product in the engine service area, but it could serve for a grade level crossing, too:
https://weinert-modellba...en-fuer-gleise-h0-detail
Offline costing
#8 Posted : 09 October 2023 16:18:30(UTC)
costing
Hi @geir,
Here is my take on this subject: https://www.marklin-user...erailing-zone#post584543 (and subsequent posts). I also used a thin plastic sheet plus a wire for the 3rd rail contact. Later I've managed to hide the wire even better, by digging a channel in the plastic and leaving just the very top of the wire exposed.
But now seeing @Alsterstreek's post, it would be a great way to achieve it, that's really neat!
.costin
thanks 3 users liked this useful post by costing
Offline geir
#9 Posted : 12 October 2023 19:34:06(UTC)
geir
Tnx for info
#10 Posted : 17 October 2023 16:31:04(UTC)
#11 Posted : 15 April 2024 16:01:46(UTC)
A German eBay seller offers custom-made fillers for Märklin H0 track, both straight and curved. Unfortunately, he is only shipping within Germany.
Link:
https://www.ebay.de/sch/...p;_nkw=m%C3%A4rklin%20h0
Offline bygger01
#12 Posted : 16 April 2024 16:14:38(UTC)
bygger01
I have chosen another solution for filling in between the K tracks in our harbor area.
The two tracks are lying parallel, and originally there was a transverse of two long switches 22716, but they were removed,as I found it impossible to cover the gaps.
I chose to use an N-flex rail as the center conductor, and it is 0.5 mm high. And at one end, where the approach is, the rail is bent downwards!
They were each equipped with soldered wires + a couple of controls made of straight 1½ square copper. The wires were held down underneath by guts from plastic electrical terminal blocks.
The spaces between all the rails were filled with plastic cobblestone sheets from Auhagen, and this covering matched the height of the K rails just fine, as it was just below the top of the rails, when laid on rail nails.
Before that, the gray color had been adjusted darker.
It lasts well, and still fits well!
Pictures can be requested if desired.
At other transitions in the port area, there are e.g. used the Faller gizmos, but also made a place with a thin copper wire.
However, I have a problem with a crossing over a switch, and here a temporary solution with some cut-to-size cardboard has been used, but it's not that nice, so it's on the list of changes. I have considered laser cutting it 1mm MDF, but drawings are difficult to make …..
Jørgen St. from Herning in DK
H0 / Märklin K track / CS3+ / full digital / Epoke III +/-
thanks 2 users liked this useful post by bygger01
#13 Posted : 21 October 2024 10:50:46(UTC)
#14 Posted : 21 October 2024 14:55:26(UTC)
The first two links are a bad gateway.
#15 Posted : 23 October 2024 20:41:05(UTC)
#16 Posted : 24 October 2024 13:48:36(UTC)
Great picture and idea. How would they be fashioned? Finding the correct metal gauge and using a bench grinder?
thanks 3 users liked this useful post by marklinist5999
Offline bygger01
#17 Posted : 24 October 2024 13:55:18(UTC)
bygger01
In Denmark, DSB uses similar e.g. to catch hanging screw couplings in front of road crossings.
thanks 3 users liked this useful post by bygger01
Offline revmox
#18 Posted : 25 October 2024 00:01:30(UTC)
revmox
On a different approach, I am currently reworking my simple unguarded 3D printed crossings as I found I needed an extra one and thought that the original design could be greatly simplified. Nevertheless, C-track road crossings seem unrealistically 90cm high when upscaled and form quite a barrier on layout.
Here's the progress so far. Straight off the printer - they need spraying with automotive filler and then painting. Secured by two C-track screws down the holes and then a post or boom gate printed to go in the 4mm top of the holes.
Here's some pics of the superseded complex, multi-piece version.
thanks 6 users liked this useful post by revmox
Offline applor
#19 Posted : 31 October 2024 23:39:49(UTC)
applor
For my layout I cover the centre studs (in my case a cobblestone surface out of plaster) and then run a 0.2mm stainless steel wire across the top which I feed under the track at each end and secure/tension with a button screw underneath at each end which is connected to power.
This is K track but method would be the same for C track.
https://www.marklin-user...st---Holzberg#post673243
thanks 4 users liked this useful post by applor
Offline 1borna
#20 Posted : 02 November 2024 19:33:09(UTC)
1borna
Croatia
Backo mini express did it like this:
UserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImage
thanks 4 users liked this useful post by 1borna
Guest (5)
This page was generated in 1.104 seconds.
