Bonjour Eef
Welcome to our nice forum. Glad to have you on-board.
Here crazy Märklinist HO digital Rocrail control with a 7286 TT (the 6652 from Fleischmann redecorated & packaged by Märklin and a DSD2010 installed around 2013/2014.
My TT operation- 18 access tracks
- 3 sensor zones on the bridge
- 4 signals, lighted shed + flashing light
- sound module
- because of too many access tracks, the DSD2010 is controlled by a separate RS232+USB adaptor+ specific "Zentrale" for the DSD2010. This is additional to the CS2/CS3 3Zentrale"
- because of the importance of (1) the orientation of the bridge (+ or - side) and (2) the minimization of rotation, I have TWO routes for each access track (to DS1+ and to DS1-with an output to lock / unlock the route to the + or minus side.
- the TT operates in manual mode, in click and drag mode, in schedule mode, in aquarium mode.
- at the time (2013) RR asked to create manually all routes to and from the TT.
- because of an older version of the DSD2010 reporting only 24 positions (newer report 48 positions I think) then I created a virtual switch 24+ indicating position 1-24 and 25-48
Here is the little I know:- all block accessing the TT must be arranged so the MINUS side faces the TT (don't ask me why as I don't know)
- you have the option to include the bridge block of the DS declaration or to have it separate. I selected the separate option "Integrierte Block" is UNchecked.
- the "shortest rotation" to go to any position is managed by the DSD2010 but must be set correctly
- any incident in the dialog DSD2010-RR is not managed by RR and in this case YOU MUST RESTART RR.
What can prevent a loco to be sent to the TT?:- the loco logical orientation must be toward the TT
- the block entry side (arrow) must point towards the TT
- the loco length must be smaller than the TT length So if RR still believes there are cars / wagons with the loco, access will be blocked. (It happened to me many times)
- the TT must be "unreserved" (like any other track piece (turnout, DSS, crossing)
- all sensors on the bridge must be free (check the virtual sensor)
I understand that only in manual mode you can use the TT (GO TO Track xx)
Just to be on the safe side here is what my track table looks like
Here is how the configuration is
Allgemein (General)
Schnittstelle (Decoder)
Gleise (Tracks)
sse the first attachment
all other DS1 tabs are left alone
The separate DS1 track
Allgemein
Fahrstrassen (Routes)
And here is the TT operation in video (schedule mode)
There are so much more to say that it is better to stop here and let you have more questions
I forgot to answer your question: No there are no actions required for the setup to work BUT BEWARE when adding virtual sensors , include correct setting at each RR restart (system action)
Edited by user 31 August 2024 00:40:25(UTC)
| Reason: Not specified
