Offline Boegies
#1 Posted : 29 August 2024 16:21:28(UTC)
Boegies
Hoi Marklin-users,
I have Märklin and use a CS2 and RocRail. Al my (old) locs are digitalised and running smoothly.
For two years a got a turntable (Märklin/Fleischmann 6652) with a DSD2010 digital decoder. I installed the tt on my layout and started to make it work with CS2 and RR..
On the CS2 (keyboard 225) its is working perfect, also on the layout screen.
With RocRail (RR) in manual mode / semi automode, everything is going well. When I change to automode and give the loc a schedule over the TT, the loc is waiting and waiting and…. I have to help RR bij moving the TT manual. So in automode the TT doesn’t automatically turn to the correct track.
My TT:
- 6 tracks (RR numbered 0,2,4,6,8, 10, DSD numbered 1,3,5,7,9, 11), CS2 keyboard 225,
- Each track a position detection zone,
- One detection zone on the bridge (RR-Enter) and one virtual detection point (RR-in)
- A virtual Bridge Block with the same name as the turntable (Draaischijf)
- In RR all necessary schedules and routes are made.
I have read almost all your tips/tricks on this forum and used a “Best Practices part 2” from” Digithal Bahn” (DSD2010) especially mend for the use off the DSD2010 decoder and RocRail, but I cannot solve the automode problem. Did I forget something, like actions or so?
I hope someone off the Märklin-users have some the answers for me.
Eef (Boegies)
thanks 1 user liked this useful post by Boegies
#2 Posted : 30 August 2024 10:50:02(UTC)
Welcome Eef to the group. Jonjean B (Jean) is the Rocrail expert here. I'm certain he can help you.
#3 Posted : 30 August 2024 17:52:38(UTC)
Bonjour Eef
Welcome to our nice forum. Glad to have you on-board.
Here crazy Märklinist HO digital Rocrail control with a 7286 TT (the 6652 from Fleischmann redecorated & packaged by Märklin and a DSD2010 installed around 2013/2014.
My TT operation
- 18 access tracks
- 3 sensor zones on the bridge
- 4 signals, lighted shed + flashing light
- sound module
- because of too many access tracks, the DSD2010 is controlled by a separate RS232+USB adaptor+ specific "Zentrale" for the DSD2010. This is additional to the CS2/CS3 3Zentrale"
- because of the importance of (1) the orientation of the bridge (+ or - side) and (2) the minimization of rotation, I have TWO routes for each access track (to DS1+ and to DS1-with an output to lock / unlock the route to the + or minus side.
- the TT operates in manual mode, in click and drag mode, in schedule mode, in aquarium mode.
- at the time (2013) RR asked to create manually all routes to and from the TT.
- because of an older version of the DSD2010 reporting only 24 positions (newer report 48 positions I think) then I created a virtual switch 24+ indicating position 1-24 and 25-48
Here is the little I know:
- all block accessing the TT must be arranged so the MINUS side faces the TT (don't ask me why as I don't know)
- you have the option to include the bridge block of the DS declaration or to have it separate. I selected the separate option "Integrierte Block" is UNchecked.
- the "shortest rotation" to go to any position is managed by the DSD2010 but must be set correctly
- any incident in the dialog DSD2010-RR is not managed by RR and in this case YOU MUST RESTART RR.
What can prevent a loco to be sent to the TT?:
- the loco logical orientation must be toward the TT
- the block entry side (arrow) must point towards the TT
- the loco length must be smaller than the TT length So if RR still believes there are cars / wagons with the loco, access will be blocked. (It happened to me many times)
- the TT must be "unreserved" (like any other track piece (turnout, DSS, crossing)
- all sensors on the bridge must be free (check the virtual sensor)
I understand that only in manual mode you can use the TT (GO TO Track xx)
Just to be on the safe side here is what my track table looks like
Here is how the configuration is
Allgemein (General)
Schnittstelle (Decoder)
Gleise (Tracks)
sse the first attachment
all other DS1 tabs are left alone
The separate DS1 track
Allgemein
Fahrstrassen (Routes)
And here is the TT operation in video (schedule mode)
There are so much more to say that it is better to stop here and let you have more questions
I forgot to answer your question: No there are no actions required for the setup to work BUT BEWARE when adding virtual sensors , include correct setting at each RR restart (system action)
Edited by user 31 August 2024 00:40:25(UTC)  | Reason: Not specified
Offline Boegies
#4 Posted : 09 September 2024 16:50:51(UTC)
Boegies
Johnjean B.
Thanks for your reaction on my post. My response is a little late because we had a short holiday.
When I read your reaction I see a lot in common with my situation.
My TT:
6 acces tracks
1 zone on the bridge and for RR a virtual in-sensor
2 signals, lighted shed + flashing light
I used the DSD2010 program only for the first install. It works on the CS2, keyboard 225. I only have my shed-light on 241 instead on 225 as DSD2010 normally do.
In RR I have two routes for each track, to + and - side off the TT.
The blocks are accessing the TT with there minus side face to the TT.
I use a separate (virtual) block and the option “integrierte Block” is unchecked.
Further I use a position sensor (created by DSD2010) for each track.
On my RR layout I have for each track a output (got to track X) That works for the tracks 1-6 and the TT takes the direction that is used before (CW of CCW).
I looked to your screenshots, I hardly see no difference with mine. In the track screen I didn’t use all 48 tracks, just the six I use, as it was described in the DSD2010 manual.
In the mean time, I am so far that, when I give the loc a schedule over the TT and start the loc in automode, I have to send the TT manual (output or CS2: go to track 1) to the right track. When the TT arrived at the right track, the loc starts and rides on the TT (auto mode). , I send the TT to the next block (output of CS2: got to track 2). The loc rides off the TT in to Block 2 (auto mode). So the loc drives in auto mode, but the TT waits for manual commands.
I know the points you mentioned at “ what can prevent a loco to be sent” and I take care off them.
The question still is why doesn’t the TT turn to the track automaticly in RR? Do you have any ideas that might help?
#5 Posted : 10 September 2024 10:52:51(UTC)
Hi Eef
It looks like all is fine except the order to position the Turntable (TT) is not sent or not accepted
I understand that you can start a schedule through the TT, all is fine but the TT does not move. If, in parallel, you send an order to the TT then when it reaches the correct position, the schedule resumes and completes itself.
Can you drive your TT through Rocrail (right click on the TT, go to track x)?
If not then you must investigate why
If yes, then it is probable that the decoder refuses the order to move because it is reserved or the Block on the TT is not free
Good luck
Offline Boegies
#6 Posted : 10 September 2024 13:47:51(UTC)
Boegies
Hi Jean,
I have the same opinion as you, RR doesn't send a signal to the TT or the TT doesn't response on the RR order. In RR I use the 'go to.."with the output on my layout, that works. I will try to find out of RR sends a signal to the TT and otherwise look why the TT decoder refuses to move.
Thanks sofar for your help!
Eef
#7 Posted : 10 September 2024 14:02:45(UTC)
Does your TT block shows your loco as its target?
If yes then the command has been sent to the DSD2010
To make sure, install a switch with the same address as the. destination track on your TT and see if it is activated
Offline Boegies
#8 Posted : 11 September 2024 20:53:50(UTC)
Boegies
Jean,
When I start the loc with a schedule the TT shows itself (collor change and name off the loc) as the target off the loc.
In RR I have looked in the trace and see that there is a command to the TT to turn, but the TT doesn't turn. When I use the TT manuel, the sortest turn is made, so the + or the - site off the TT will go to the track.
I don't know off it is a Marklin 'thing' because somewhere I heard that you sould give two commands, the direction the TT should go and the tracknumber. A schedule in RR only has the 'go to' option as far as I know.
Thanks for the tip with the extra sensor. I will try it and let you know the results.
I will find a way to make it work.
Eef
#9 Posted : 12 September 2024 11:23:28(UTC)
Hi Eef
It shows the TT is not reserved
I would say the configuration of schedule to and from the TT do not include the proper TT command
You must work around that
#10 Posted : 12 September 2024 12:08:04(UTC)
Here is what a schedule to or froim the TT looks like
Here is in the DigitalBahn the screen to adjust speeds
Don't forget to write the changes on the TT memory
and the values are changed here (table of all parameters
Offline Boegies
#11 Posted : 12 September 2024 17:21:10(UTC)
Boegies
Hi Jean,
Thanks for the reaction. Your DS24+weiche is the direction choice?
I wil complete my routes with the direction choice.
Greetings,
Eef
#12 Posted : 12 September 2024 18:16:20(UTC)
Hi Eef
No, the direction choice is made by properly programming the DSD2010
If I remember correctly this is by programming "Turn" one way of the other (see framed field below from the DigitalBahn documentation - not my configuration)
In one way, the TT will select the longest way and with the other it will select the shortest way.
Back to your question: the switch (or turn-out) is there to remember which side is the TT position 1 to 24 or 25 to 48 (Remember my DSD2010 is a 2014 one with only 24 positions being reported. So, using virtual sensors and this turnout I can have 48 position sensors
Offline Boegies
#13 Posted : 12 September 2024 21:47:26(UTC)
Boegies
Hi Jean,
The DSD2010 that I use is a 2021 version. I don't know off there are differences between your and mine version. I used the documentation supported by Sven Brandt for the installation off the decoders.
I look further for solutions ic what I have to change.
Eef
#14 Posted : 13 September 2024 13:33:11(UTC)
Hi Eef
I believe the version you have reports all 48 positions of the bridge so you don't have to do the virtal sensor and virtual turnout thing I had to do.
The DSD2010 sends more info on the S88N sensor system than previous version.
More, I can't say because I cannot find DigitalBahn's access to downloads
On the 2015 version I have (but cannot transmit through this forum, here is a picture of the 48-position report (later version than mine but probably applicable to yours
If you are interested by the full pdf copy, I think I need your email address by PM .
Offline Boegies
#15 Posted : 13 September 2024 15:46:38(UTC)
Boegies
Hi Jean,
The download page is ' https://www.digital-bahn..._ds2010/dsd2010_doku.htm '. I have downloaded all documents already and used them for the installation off the decoders and the setup.
In my CS2 the 226 (green) the 180 turn option and 228 is the direction Clockwise or Contra Clockwise (CW and CCW) In RR is this the same, as far as I know.
Because Märklin only use 24 positions I choose for the dipswitches mode 3 (24 tracks and 1/2 half) In my DSD2010 is M08 the first/second half sensor and M09 t/m M32 are the tracks.
Untill now I used the Motorola and I will try DCC as protokol.
Greetings
Eef
#16 Posted : 13 September 2024 23:20:50(UTC)
Hi Eef
So, all is fine. Unlike what it seems, the programming of "Turn" allows to decide for the quickest way or longuest way in automatic mode (you only tell the decoder the destination track and it will decide for the shortest or longest wa and the decoder which direction to choose).
Offline Boegies
#17 Posted : 14 September 2024 18:49:54(UTC)
Boegies
Hi Jean, thanks for the explonation of the "Turn" command. I will hope to get the TT moving. Till now I stil have to move it manual.
I keep on looing for 'the' solution for automode.
Greetings
Eef
Offline Boegies
#18 Posted : 15 September 2024 12:20:57(UTC)
Boegies
Hi Märklin-users,
I changed the TT from Motorola to DCC and I hoped that the TT would work at in auto mode, but no, still no response on the TT.
When I use the keyboard codes (225-240) the TT turns. In RR I have Outputs in my lauout. Other than I earlier mentioned, I didn't use the goto command, but I use the CS2 keyboard codes (track 1 = 229-red, track 2 = 229 green .....).
Today I found out that the goto command in RR doesn't work. When I click on the TT picture in RR and use goto track .., nothing happens.
When I look in the tracefile I think to see that RR sends a signal to the TT
trace:
20240915.114958.364 r9999I 00000CE8 OMBUS 0830 command=tt:1
20240915.114958.926 r9999I 1_3F2C78 OTT 2534 dsd2010[Draaischijf]: 0
20240915.114958.926 r9999I 1_3F2C78 OTT 0521 turntable from track[4] to track[0]
20240915.114958.926 r9999I 1_3F2C78 OTT 2582 dsd2010[Draaischijf] goto track 0, current pos=4
20240915.114958.926 r9999I 1_3F2C78 OTT 2612 dsd2010[Draaischijf] goto track 0
20240915.114958.926 r9999I 00000CE8 OMBUS 0830 command=tt:1
I looked in every screen in RR comparing with the screens from Jean, bud I can't find why the goto command doesn't work.
I hope somebody has an solution for me.
Greetings
Eef
#19 Posted : 15 September 2024 14:17:40(UTC)
Hi Eef
What you describe makes perfect sense as the "go to track" command is also used by the routes to send orders.
It all focus on the track table where the track no (0 to 47) is converted into a a code to send to the decoder by Rocrail (1 to 48) but with a convertion.
There are TWO METHODS:
- the direct control by RS232 (that I use now) which sends the track number through the RS232 irrespective of the Märklin 7687 "old-style decoder"
- the direct EMULATION of the 7686 decoder where you can basically send orders from address 225 to control the TT.
The documentation of the 7687 is here
https://static.maerklin....876e4b34bc1574773383.pdf
The DSD2010 offers a convertion table to allow those 24 positions to be converted to the 24 track position really used (one uses rarely al 48 positions
Here is one assignment of really-used tracks into codes
One important thing to remember is a route sends order to switches also here so why not test with a swicht (turnout) programmed at the same address 229 for track 1 and 2, etc)
Offline Boegies
#20 Posted : 16 September 2024 17:36:23(UTC)
Boegies
Hi Jean, thanks again for the quick response on my post. Do you know what is best to use for the dsd2010, Motorola or DCC protocol? Using the adresses 229 and so on, does work, I use it in the outputs (track 1: 229 red, track 2: 229 green etc). The strange thing is that when I right click on the TT symbol and use the command 'goto 2' or an other track, nothing happens.
Cheers Eef
#21 Posted : 16 September 2024 19:58:32(UTC)
Hi Eef
Driving my DSD2010 by MM2 works very fine for me and it is highly probable that using DCC will do EXACTLY the same (in your case working with Routes and not working with the GoTo command.
I think, in your case, because you drive the TT only using turnout commands, the way to fill the TRACK table is different to my case
You should check this
https://wiki.rocrail.net/doku.php?id=turntable-tracks-en
One possibility (I have not verified it)
- as Rocrail indicates the standard mode is 24 track (in absence of the RS232 link)
- in the interface TAB indicate the TT type (DSD2010). The address is implicit.
- in the track table left column you start with Track 0 until you last REAL track (e.g.: 6)
- in the track table Decoder Track column you start with Track 1 until (e.g.: 7)
In this case, you must have configured the DSD2010 (Track Definition tab indicating:
- where is track 1
- what tracks are used
- where is the pole change (used only for 2 rails but you must indicate where is the pole change)
Then I assume that RR will send Turnout commands in accordance with the TT DSD2010 track definition table
Offline Boegies
#22 Posted : 17 September 2024 13:58:57(UTC)
Boegies
Hi Jean,
Thanks for your remarkes. I will tryout your options and let you know.
A little question about 'goto', is there a reason why in my case the goto option doesn't work?
greetings
Eef.
#23 Posted : 17 September 2024 16:24:46(UTC)
Hi Eef
Sadly I don't know why the GoTo does not work. I started using the DSD2010 without an adapter (10 years ago) so it MUST work. Just a question of how. Maybe ask the Rocrail forum?
I have a question: since you should (must?) adjust the DSD2010 parameters using the RS232C Link ,(I think there is no other way. Is there?) Why not get yourself an RS232 / USB adaptor similar to this one?
https://www.ebay.de/itm/33431880...D%7Ctkp%3ABlBMUO7H2YXAZA
Using this, you can do all your testing and adjustments andc drive the TT much more precisely (all 48 tracks)
Offline Boegies
#24 Posted : 17 September 2024 19:26:11(UTC)
Boegies
Hi Jean,
I have a RS323/USB adapter and used it to install the DSD2010. I read that for CS2 and Rocrail you ditnot need to use it, so I configured the DSD210 in CS2 and Rocrail. As I told earlier, everything is working accept the 'goto' command and tat is what you need in automode as far as I know now.
I no decided to try if it is possible in a schedule to use a switch command with a TT adres to make the TT go to the right adress.
I keep on searching and trying.
Greetings
Eef
This page was generated in 0.686 seconds.
