Offline jonas_sthlm
#1 Posted : 05 April 2024 12:31:11(UTC)
jonas_sthlm
Has anyone manage connect an capacitor on mLD decoder ?
I get the capacitor 1500uF to charge U-/U+ but the decoder dies immediately when the power goes off.
I find this wiring diagram on moba-hgh.de Huh
Edited by user 06 April 2024 09:49:35(UTC)  | Reason: Not specified
Offline bph
#2 Posted : 05 April 2024 13:32:31(UTC)
Should work....
Could it be that something is not wired correctly. ? e.g. is the diode mounted the right way?
this thread might also help: (the instructions on the moba-hgh.de is not the best)
https://www.marklin-users.net/forum/posts/t31226-Marklin-Hobby-and-Trix-22075---22097---mSD-upgrade--buffer-capacitor
Offline jonas_sthlm
#3 Posted : 05 April 2024 15:10:15(UTC)
jonas_sthlm
I probably didn't connect it wrong Blushing I used this instruction...
The same capacitor works with mSD decoder so why not with mLD.... I dont get it Confused
Offline jonas_sthlm
#4 Posted : 05 April 2024 21:25:09(UTC)
jonas_sthlm
Someone has succeeded here making it to work with 470yF/35V together with PCB Mellow
Should this capacitor be requested between GND and +Ub if not using 21MTC PCB for mLD/mSD...
Edited by user 07 April 2024 11:10:03(UTC)  | Reason: Not specified
Offline bph
#5 Posted : 06 April 2024 22:03:46(UTC)
Perhaps you also need a capacitor on the +5v for the decoder processor. ?
I have not used capacitors on old mLD but only used them on mSD and as you also noticed it works fine.
Offline mmervine
#6 Posted : 06 April 2024 23:04:31(UTC)
mmervine
This video may be helpful:
thanks 1 user liked this useful post by mmervine
Offline jonas_sthlm
#7 Posted : 07 April 2024 13:32:25(UTC)
jonas_sthlm
The video is great but doesn't clarify functionality of mLD decoders...
Like I mentioned the powerpack works with the same generation of mSD decoder.
Yes the question are, and I will try decoder with circuit board later to see if the +5 capacitors will do the magic Huh
By the way how do you know its +5 on the board ?
Offline jonas_sthlm
#8 Posted : 27 July 2024 08:59:03(UTC)
jonas_sthlm
I did finally give up on the old mLD decoders and replace them with mDL3...
In the background, the inside measured from NMJ teak wagon, yet another disaster produced new model.
thanks 2 users liked this useful post by jonas_sthlm
This page was generated in 0.306 seconds.
