Offline spinnerguy
#1 Posted : 01 January 2024 22:39:18(UTC)
spinnerguy
II have been using cotton buds,with lighter fuel to clean all wheels,which is effective. I have just noticed on an on line vid,that the current is tranferred - not from the wheel running surface,but from the inside edge,nearest the loco frame.I appear to have been lucky in wiping this area when cleaning ....
#2 Posted : 01 January 2024 22:46:19(UTC)
Yes and no! the wheel rolling surface is key to pick-up the voltage.
Now the voltage is often transferred from the wheel to the loco by internal slider (very small, flimsy and hidden behind wheels) touching the internal side of the flange.
So keeping both clean is key and extra care should be taken not to damage the wheel slider (easily bent or set out of position)
Offline Toosmall
#3 Posted : 03 January 2024 20:30:56(UTC)
Toosmall
When reinstalling wheels, use a very fine pointed tweezers to hold in contacts onto the inside of wheels flanges, not difficult.
I pull bogies apart & chuck then in a small container of lighter fuel (very cheap by the litre from hardware shops) & shake built up residue off.
Your loco would have had to done a 1000 km for contacts to wear beyond practical electrical functioning use. Swap contacts with boring locos, or otherwise buy new parts
But really, even flogging a loco to death, contacts still function.
Locomotive Wheel Cleaning (General MRR)
by Ranjit 06/08/2020 14:14:38(UTC)
Does anyone have quick wheel cleaning tips/tricks to share? (H0-scale)
by 5HorizonsRR 16/04/2020 07:58:57(UTC)
Cleaning the 66623 wheel cleaning brush (Small scale)
by Trainiac 16/02/2019 20:07:57(UTC)
Lux H0 scale wheel cleaning devices (H0-scale)
by Rinus 23/03/2008 22:35:13(UTC)
Wheel Cleaning (H0-scale)
by nevw 27/09/2006 14:03:43(UTC)
This page was generated in 0.441 seconds.
