Offline Luna
#1 Posted : 03 November 2023 05:08:50(UTC)
Luna
Has anybody come up with a way to put the 74030 insulator on the track rail? I seem to be able to put a couple on no problem and then I run into a piece of track that will not accept the insulator. Is there some trick to consistently get them on? Maybe soften them with hot water? I've already ruined a fair amount of track pieces due to the insulator distorting the rail during application. Can't use pliers either as they ruin the insulator. Thanks in advance for any ideas.
Luna
Offline PeFu
#2 Posted : 03 November 2023 06:27:10(UTC)
PeFu
I usually use tweezers to "push" the metal sheets together a little, according to the blue arrows. After this, I find it easy to apply the insulator.
thanks 4 users liked this useful post by PeFu
#3 Posted : 03 November 2023 09:47:43(UTC)
I apply the red cup at the corner of the inner lid, then gently push the inner lid to the outside of the track, then push the cup over both lids.
Same effect as PeFu's method, but without a pair of tweezers.
Offline Flupke
#4 Posted : 09 November 2023 14:39:04(UTC)
Flupke
So you squeeze shut the outside connector, but what do you do with the connector where the insulator goes into. I have tried to pry the insulator between the two metal prongs, but it doesn't seem to hold the insulator in place. It is not clear from the picture how the insulator is held in place.
#5 Posted : 09 November 2023 15:29:17(UTC)
You push the insulator over a pair of metal prongs.
To make this easier, you can squeeze them together with a pair of tweezers.
The red insulators can be used for the centre-rail (inside prongs) and for the outer rails (outside prongs).
Offline Flupke
#6 Posted : 10 November 2023 02:55:11(UTC)
Flupke
Thanks, I had not seen that there was a hole in which the metal prongs were supposed to slide in. I got it to go in using tweezers.
#7 Posted : 10 November 2023 22:13:04(UTC)
Hi Luna
Luna
There is a simple way. No tweezers needed, simply push the insulator sleeve in blue arrow direction without excessive force. Works every time! Do not hesitate to trash damaged sleeves
Note: there may be some tricky tracks where probably force was exerted on the contacts. The result is not both contacts are at the same, "altitude" resulting into difficulties inserting the sleeve. First make sure both contacts face each other before inserting the sleeve
Offline Luna
#8 Posted : 11 November 2023 04:06:04(UTC)
Luna
I still have to insist that Marklin couldn't have made something that should be simple so difficult for someone that has normal sized fingers if they had purposely tried to. This is the only way they could figure out how to insulate their tracks? I also know that I'm not the only idiot that has trouble putting those nasty things on the rails. Thanks to all who have come up with ideas of how to get them on. I maybe get one success for four screw ups. At this point I've given up trying to make contact tracks.
Done with rant.
Luna
thanks 1 user liked this useful post by Luna
Offline dickinsonj
#9 Posted : 12 November 2023 01:21:00(UTC)
Good point about normal sized fingers. I get around that by using tweezers to put them in place, where they often stay for years.
Offline Captain
#10 Posted : 24 January 2025 18:09:34(UTC)
Captain
Indonesia
In regards to those red insulators. Is there a DIY version of the insulators
I have lost mine an dmy train shop has sold out..
Thank you
#11 Posted : 24 January 2025 22:37:24(UTC)
I would try square tapered toothpicks if you can get them.
Offline rbw993
#12 Posted : 24 January 2025 22:52:23(UTC)
rbw993
Or you can just snip off the prongs. I have never bothered with the insulators.
Roger
Offline dickinsonj
#13 Posted : 25 January 2025 01:25:09(UTC)
Roger
Right, you will always want isolators in your layout, and those plastic bits are a little flimsy ands way overpriced.
I would take Roger's advice and just make it permanent.
Offline Captain
#14 Posted : 25 January 2025 02:05:46(UTC)
Captain
Indonesia
Roger
I think I will make it permanent by sniping off the prongs. I'm just not sure exactly how and where to cut .. I'm still just a beginner..
thanks 1 user liked this useful post by Captain
#15 Posted : 25 January 2025 12:47:08(UTC)
See my answer to this post.
Offline Drongo
#16 Posted : 28 January 2025 07:14:38(UTC)
Drongo
Hi Luna
Luna
A word of warning - if you squeeze the prongs to assist in installing the red tabs, and then at a later date you remove the red tab, you may find that the prongs are not making contact with the next piece of track and thus there is no electrical continuity - I found this out the hard way.
Marklin Z Track Insulators??? Do they make them? (Small scale)
by darticus 19/08/2017 15:56:11(UTC)
This page was generated in 0.501 seconds.
