2 Pages<12
#51 Posted : 13 May 2023 00:36:57(UTC)
I, for one, am glad there is nothing in the summer items for me... thankfully. As I really need to focus on other things and will be glad to get my back order list from the dealer down to a handful of items or zero if I can manage.
I almost had a heart attack of "oh no now I have to get that certainly...." when i saw the thumbnail with the yellow RAILab train... whew, its for Z scale. Bullet dodged.
#52 Posted : 13 May 2023 11:15:27(UTC)
I think you will find the Plux22 connector will get used in Minitrix items.
Is not it the T66856 more targeted to mini-trix "Locomotive decoder mtc14 interface". Delivery date posted as just 2024 (rerun? = ongoing intent)
Offline jonas_sthlm
#53 Posted : 13 May 2023 13:22:44(UTC)
jonas_sthlm
Is the Sdgms wagon really scale 1:87, looks short with Semi-trailer Huh
Offline Sashmeister
#54 Posted : 24 September 2023 13:28:48(UTC)
Sashmeister
Bulgaria
Hello guys,
I have a question regarding the new decoder 60996. Has anybody succeeded programming a sound into it? I understand i need the stick 60971 and the board 60970. I already have the stick and successfully used it to program 21 pin decoders. German manuals are not that easy to comprehend. I saw a youtube video, where they connected the board 60970 to the Marklin control station via the "track" port. I imagine this p0ort feeds the board with power. However, i dont have a CS, I use multimaus. When i use the stick 60971 i just plug it to the PC USB-a and then plug the decoder in it and thats it. Where do i need to connect this "track" from the board 60970 if i dont have the Marklin Control Station?
Thank you in advance!
thanks 1 user liked this useful post by Sashmeister
#55 Posted : 24 September 2023 14:30:42(UTC)
It comes preloaded with diesel sound! A ealer or someone with a decoeder programming tool and web sound files can update it. Or, you can buy a blamk sound decoder.
Offline bph
#56 Posted : 24 September 2023 14:43:03(UTC)
Originally Posted by: Sashmeister Go to Quoted Post
Hello guys,
I believe what you are seeking is described in this post:
https://www.marklin-user...y-normal-dc-power-supply
Offline Sashmeister
#57 Posted : 24 September 2023 15:36:06(UTC)
Sashmeister
Bulgaria
Thank you. Perhaps i missed it in your post, but what power supply i need to get? 12v? If i dont find a power supply can i just plug it directly to the Roco z21 instead of the track?
Offline Sashmeister
#58 Posted : 24 September 2023 15:38:53(UTC)
Sashmeister
Bulgaria
and also.. what happens if i switch the polarity ? :D
Offline bph
#59 Posted : 24 September 2023 16:37:45(UTC)
I believe that any DC power supply around 18-19v should work. when you switch polarity the other LED lights up and it seems to work fine but haven't tested programming.
Offline Sashmeister
#60 Posted : 24 September 2023 17:41:43(UTC)
Sashmeister
Bulgaria
thanks. It is very unfortunate that the stick doesnt have a 22 pin adaptor. I dont need all that bizmos the board offers. I just want to write some sound...
Offline bph
#61 Posted : 24 September 2023 20:38:16(UTC)
you could also try to manually wire up that decoder to the wire input on the 60971 plate. (green with 4 screw terminals).
Offline Sashmeister
#62 Posted : 24 September 2023 22:19:27(UTC)
Sashmeister
Bulgaria
There are only 4 holes and I have 22 pins. Thats too advanced for me, I guess..
Offline bph
#63 Posted : 24 September 2023 22:37:08(UTC)
it should be fairly straightforward, only a few cables are needed as described in the manual, and if you have eg a loose PluX22 decoder plate it should be possible.
note that I have not used this way myself but others here on the forum have used it. so I can not guarantee that it will work. you could also try to call Marklin service to make sure it will work, before you try it.
2 Pages<12
This page was generated in 0.511 seconds.
