Offline Stefano Rocca
#1 Posted : 19 September 2023 18:36:45(UTC)
Stefano Rocca
Dear Märklin friends
i do need again your help, becasue I have to inspect a DT 800 and I don't know how to take off the chassis. It worked fine for many monthes,since I bought it through E-bay, but now the Pefekt reverse is not working and the Pantographs seem unable to take currrent. So the first I need to do is to open the chassis, but I don't know yet how to do that. Then what about the Perfekt not working with the 280 Märklin Super? and how may i sort the Oberleitung issues? Best regards!
Prof. Stefano Rocca
#2 Posted : 19 September 2023 21:59:04(UTC)
Prof. Stefano Rocca
The overhead issue - I would suspect the lever you toggle to switch between pickup shoe and overhead has been knocked and is not connecting to either item - easily done without noticing when handling the loco.
Offline nmbssncb
#3 Posted : 04 October 2023 12:08:35(UTC)
nmbssncb
Maybe the link below will help?
DT 800 info
Willy
Offline nmbssncb
#4 Posted : 04 October 2023 12:10:19(UTC)
nmbssncb
Willy
Offline nmbssncb
#5 Posted : 04 October 2023 12:21:22(UTC)
nmbssncb
Offline nmbssncb
#6 Posted : 04 October 2023 12:22:59(UTC)
nmbssncb
Offline Erik Baas
#7 Posted : 04 October 2023 14:57:48(UTC)
Erik Baas
#8 Posted : 04 October 2023 18:19:18(UTC)
Prof. Stefano Rocca
Hi Stefano
To remove the body, you have only one large screw to remove (located underneath near the rear of the loco
Here is a picture of my DL800 with same structure
I hope this helps
This page was generated in 0.683 seconds.
