Offline OMAC
#1 Posted : 15 September 2023 23:33:14(UTC)
OMAC
Does anyone have a wiring diagram for a 3076?
Or direct me to a site that has one.
I have downloaded an exploded diagram but unfortunately it does not have the wiring diagram.
Regards Owen
thanks 1 user liked this useful post by OMAC
#2 Posted : 16 September 2023 13:14:22(UTC)
It should be a standard wiring and motor with a mechanical reverse unit. Same as a 3000 br 89. Pickup shoe, field coil, old type motor brushes and flat commutator.
#3 Posted : 19 September 2023 10:00:32(UTC)
Regards Owen
Hello Owen,
Do you require the diagram for repair or replacing with digital?
There are pictures of original and modified for digital on this site showing replacement with digital decoder.
http://maerklin-sammler-infos.d...omotiven/03076/03076.htm
Offline OMAC
#4 Posted : 19 September 2023 10:47:54(UTC)
OMAC
Thanks Kimball for your info.
The reason why I am looking for a wiring diagram for the 3076 is that I recently managed to buy a secondhand 3076 and I want to gather as much information as possible to enable me to maintain my locos correctly.
I do not convert any of them and prefer to keep them all in original condition. So to answer your question - The wiring diagram is for repairs.
I download exploded diagrams for each of my locos and then convert the parts description from German to English. A lot of the exploded diagrams do have a wiring diagram associated with the loco. A lot of wiring diagrams are generic but in the case of the 3076 it is completely different - hence my request for a 3076 wiring diagram.
Maybe a member might have a 3076 ac analogue loco that they could take some closeup photos of the wiring and then post it here?
Regards Owen
OceanSpiders 2.0
3028 & 3076 Railcars - I need some measurements! (H0-scale)
by Ian M 08/08/2021 00:36:49(UTC)
Problem with 3076 on corners (H0-scale)
by Ark_42 26/02/2020 22:10:48(UTC)
Will decoder/motor set fit a Marklin 3076 be 515 diesel railcar (H0-scale)
by danmarklinman 29/04/2016 16:15:50(UTC)
Converting a 3076 (Digital)
by xxup 21/03/2016 06:57:54(UTC)
This page was generated in 0.415 seconds.
