#1 Posted : 29 July 2023 14:51:42(UTC)
Hello, the wheels are clean, rails are clean! slider clean! Could it be the copper wheel contacts up under the bogies need cleaning? Why does it only stop after a while? Expansion from heat?, but motor still cool. Anyon else with this model experience this?
Offline bph
#2 Posted : 29 July 2023 16:21:49(UTC)
yes, try to clean the "ground" pickups carefully. You can also check that the wires from ground pickups are intact, eg that none has come loose etc. If I remember correctly mine has a total of 4 wires going to the decoder.
#3 Posted : 29 July 2023 16:54:57(UTC)
Thank's bph! It hasn't been ran a whole lot.
#4 Posted : 30 July 2023 18:50:43(UTC)
I may be wrong, of course but seems to me Märklin ground return, on most (huge majority of them) is made by wheel axles.
Regarding the 39212, the ground return goes through a number of parts (see the exploded diagram below):
- the wheel pair
- its axle rings
- the bogie Zamak frame
- the loco Zamak chassis
Ground contact must go through all these parts and if any is unclean (old oil) / sludge then there is no contact
39212 bogies.png.
Ideally removing the bogies and cleaning using RS24 (Noch) and then drying / lubricating makes wonders.
Sometimes, only a little "practice" (let the loco run on a loop for a little while) is enough to restore a good contact.
Offline cintrans
#5 Posted : 30 July 2023 21:05:30(UTC)
cintrans
Aruba
My br212 (#37724) does exactly the same thing....
Stops randomly, a small nudge makes it move again....
Curious to see if this is a "common" issue and if there is a cure. Did all the usual cleans already, even changed the decoder, no changes...
Jean-Pierre
Offline bph
#6 Posted : 30 July 2023 21:12:22(UTC)
- the wheel pair
- its axle rings
This model (at least the later ones like mine) is a bit different as I believe it's basically a "DC" model. It, therefore, has two "track" pickups on each bogie. And on the AC model the left and right track pickups are just soldered together, making it 4 wires going together as ground. (2 wires from each bogie)
The track pickup is a small copper slide on the inside of each wheel. In the picture below I have coloured it yellow.
so it is these contact areas that need to be cleaned, if they are dirty.
and of course, the cause of the problem might also be something else....
#7 Posted : 30 July 2023 22:18:53(UTC)
The 37724 has two powered axles, the 39212 has four powered axles. Or with other word: they have nothing in common.
When the loco stops, but the lights are on, then there could be a problem with the brushes. I saw that with sisters of 37724.
When the loco stops and the lights are out, then there is a contact problem - either with centre-rail or, more likely, with outer rails.
#8 Posted : 31 July 2023 09:45:04(UTC)
Good point!
But if loco stop and the light are out then in case it´s very bad contact with the Märklin locos and this do happens to me often.
This happens when oxid are the problem.
Always clean locomotives and the tracks!
Cool Cool Cool
Offline bph
#9 Posted : 31 July 2023 12:32:36(UTC)
if the above does not solve it, you can also try to improve the ground pickup.
Eg like on this page:http://www.maerklin-sammler-infos.de/umbauten/lokomotiven/03072/03072_m_um.htm
Scroll down to: "Die Drehgestelle verbessern"
#10 Posted : 31 July 2023 14:48:09(UTC)
The lights do not remain on when it stops. I saw no excess oil, dust, or grease on anything. I used canned air, and plastic safe contact cleaner. I let it dry out 2 hours before running it. No difference. It is in curves that it quits the most. I thought perhaps that the decoder is being interfered by a lighting wire that passes under the tracks, or by the point where my ski lift power feed is connected to the track. Since others have the same issue though, it's unlikely.
I realize that these locos are mostly decommissioned from road switching and mainly used for dockside marshalling or in small yards, so it's not a major thing. I do however like running it around the layout with a moderate length freight consist.
Thank you Jean for the exploded diagram!
Offline bph
#11 Posted : 31 July 2023 21:09:27(UTC)
Have you checked the tension on the ground pickup "springs"? the wheels move a little sideways and if the spring does not follow you might lose some contact. You need to remove the wheels in order to inspect them properly. And be careful if you try to tension them.
#12 Posted : 31 July 2023 23:37:58(UTC)
No bph, but I will. Thanks.
Offline cintrans
#13 Posted : 01 August 2023 00:42:01(UTC)
cintrans
Aruba
Hi Tom
You'r right, my bad, mine has indeed only two driven axles and apparently also a different motor looking at the posted parts diagram....
In my case, the lights stay on, so it's not a question of loosing connection with the track....
I did clean the motor before to no avail...
Jean-Pierre
Offline heinrichhess
#14 Posted : 01 August 2023 03:24:48(UTC)
heinrichhess
I had this problem my track 3rd rail was low so pulled up with pliers and i was not cleaning inside slider
hess
thanks 1 user liked this useful post by heinrichhess
#15 Posted : 01 August 2023 17:21:15(UTC)
I left it on the layout overnight in the basement to allow it to acclimnate to the temp. down there. It ran better this morning.
#16 Posted : 01 August 2023 19:03:24(UTC)
hess
Yes this is one of the problem that is often miss.
This page was generated in 0.623 seconds.
