Offline Kaspar
#1 Posted : 05 June 2023 19:10:17(UTC)
Kaspar
Just got my hands on a used 26600 set, unfortunately its got some broken passenger car connecting rods, and worse on some cars the connector housing itself is broken or missing.
And there is no user manual which would have the parts list possibly.
Does anyone have this and could share images of the part list?
Does anyone know it the connector housings and rods are custom for this model, or some standard Märklin parts used at the time.
Best
KS
Online Alsterstreek
#2 Posted : 06 June 2023 00:07:50(UTC)
Spare parts you are asking for:
Märklin E579120 - Coupler Pockets for Streamliner cars California Zephyr (CZ), Amtrak, AT&SF ...
Märklin E580730 - Coupler current conducting tab
Märklin E239550 - Current conducting tow bar
To make it easier to put the CZ on rails, I am employing these instead of the tow bars:
Märklin E115737 - Current conducting coupler
#3 Posted : 06 June 2023 05:02:34(UTC)
I believe that once you replace the broken shafts, you can use the current conducting close couplers instead of the fixed bar between coaches.
If you decide to use Viesmann or other couplers, you would have to solder the wires to the Maerklin contact plates inside the coaches
Offline Kaspar
#4 Posted : 06 June 2023 10:28:00(UTC)
Kaspar
Thanks a lot for this :) The only thing missing is the small spring that holds the pocket in place inside the car. Did the parts list have a number for this one? Best Kaspar
Offline Kaspar
#5 Posted : 06 June 2023 10:31:49(UTC)
Kaspar
Hi Mike. This is an interesting thought. Would the distance be similar with the close couplers (compared to the drawbar) ?
Also do you need to actually replace the shafts to use the couplers? I only need to replace half of them so the remaining pockets would still be original, they can not accommodate the new couplers?
Best Kaspar
Online Alsterstreek
#6 Posted : 06 June 2023 15:17:25(UTC)
There is no such thing as a parts list. The sources are "experience" and "investigation".
These should do the trick, but I cannot guarantee that they equal the "originals":
Märklin E321965 drawbar springs
Online Alsterstreek
#7 Posted : 06 June 2023 15:21:28(UTC)
Best Kaspar
That's what I already proposed in post #2: use couplers instead of tow bars (aka drawbars).
Wink
The distance is indeed similar. Do you mean by shafts the coupler pockets? If so, the Märklin coupler pockets can hold either Märklin couplers or Märklin tow bars (aka drawbars), no soldering needed, just plug and play.
Offline bgemski
#8 Posted : 06 June 2023 15:30:18(UTC)
bgemski
There is a USA seller that has them in stock his user name is gscholz. I usually keep a few of those in my parts bin. Easy to replace. He is based in California and super easy to deal with.
Märklin 579120 Coupler Pockets for Budd Streamliner Zephyr, Amtrak, AT&SF
I just checked he still has them in stock
Offline dickinsonj
#9 Posted : 07 June 2023 01:38:20(UTC)
I replaced the drawbars on my CZ with CC close couplers several years ago.
I ran that train for 20 years with the drawbars and these look just as good to me. As a bonus they are a lot easier to handle.
Offline Kaspar
#10 Posted : 30 June 2023 21:27:08(UTC)
Kaspar
So if anyone is still following this thread, I did get the spare parts recommended and can report that the Zephyr is up and running BigGrin
Zephyr
I did switch to close couplers and they look just as good and are of course easier to uncouple when needed. If anything I found the 321965 springs a bit fiddly to install. The few original springs were a larger type. But with some patience it did work.
As for the manual I was able to get scan from forum user Various Scales, I've attached a PDF version here for anyone else looking for this manual.
Marklin 26600 California Zephyr manual.pdf (1,237kb) downloaded 138 time(s).
thanks 6 users liked this useful post by Kaspar
Offline dickinsonj
#11 Posted : 01 July 2023 01:02:43(UTC)
My CZ is in storage and I have not seen it in months, so thanks for reminding me how cool it is. ThumpUp
I'm glad you have yours sorted now. Mine has always been one of the stars on my layout, even as I have added some very nice newer passenger trains over the years.
Offline Kaspar
#12 Posted : 13 July 2023 10:27:43(UTC)
Kaspar
It’s a great model both to look at and to run. Last week I had a neighbor over and we ran trains for a few hours. The CZ ran almost the whole time, no fuss or derails.
thanks 2 users liked this useful post by Kaspar
#13 Posted : 13 July 2023 11:21:19(UTC)
It is a perfect combo indeed.You can add the 43614 marklin car to have a longer train.Enjoy your perfect train.ThumpUp
Offline DasBert33
#14 Posted : 24 March 2024 10:43:27(UTC)
DasBert33
Thank you Kaspar for posting the manual, I just go a 2nd hand CZ and the manual was missing. This helps a lot.
The CZ I purchased was advertised as 'as good as new' but sadly the description was not super accurate. Half of the cars were ok depite being dusty, but others were really dirty and do have sun damage. Notably the plastic car ends and the transparant part of the vista domes have discolorations on the extremities (turning yellow). I know it is a - very- long shot, but is there any chance to get replacements for either part? Does anyone have the part numbers? I could spray the car ends with aluminium color if necessary, but for the transparent dome plastic I see no alternative.
On the baggage car the coupler mechanism does not stay in place, some notches holding the brass plate on the car chassis have broken off. For that I am going to attempt a repair with my 3D printer. And the seller forgot to put the foam parts between the loco bodies before shipping (they were on his pictures before) causing some black paint chipped of the locos during shipping. That needs repairs as well.
I paid 460 euros including shipping for my CZ. Too much or reasonable for a set in this condition? My kolls from 2016 I believe lists the price as 420 euros, but most ebay prices are way higher.
BR,
Bert
Offline bgemski
#15 Posted : 26 March 2024 14:28:32(UTC)
bgemski
Parts I’m really not sure other than mentioned couplers mentioned. I have not seen other parts for the cars themselves. The sets seem to be on USA EBay often and yes the prices asked seem to fall in between $700 to 800 for the set. I looked at the completed sales just last night and one sold for a little over $400. I am not sure what can be done about the domes discoloration but cleaning can be accomplished as well as the chipping paint. If it’s really bad I would search for another set altogether. Sorry I’m not all that helpful.
Offline DasBert33
#16 Posted : 28 March 2024 09:04:29(UTC)
DasBert33
No problem. I know the chance of getting the spare parts I need is very close to 0.
I wonder whether it would be possible to remove the yellowing using a method like this:
but the plastic should be greenish transparant. I guess it would remove the green too? Does anyone have experience with this?
In the mean time I was able to fix some of the issues of my set, so only the yellowing remains. I also got the new current conduction couplers (72025) and they work great.
Br,
Bert
thanks 1 user liked this useful post by DasBert33
#17 Posted : 28 March 2024 11:25:41(UTC)
Pick your poison, yellow or clear plastic. A drop or two of green dye in water could possibly work.
This page was generated in 0.556 seconds.
