Offline Yigal
#1 Posted : 14 May 2023 07:41:52(UTC)
Yigal
Israel
I got from a friend used Marklin HO scale AC tracks and turnouts and a DC locomotive.
The target is to use them for a layout, powered by DC.
The tracks are easy to modify for the DC usage. yet I am not sure about the turnouts.
Would it be possible to use them with DC power?
Offline cintrans
#2 Posted : 14 May 2023 14:22:34(UTC)
cintrans
Aruba
What track did you get?
Marklin has M, K and C track.
M track (full metal) would not usable to be used on a DC layout
The straight K track is usable without modification, straight C track you have to cut on the underside to isolate the left and right rail from each other
As far as i can see the switches from K track are next to impossible to isolate the left and right rail.
Do not know about the C track switches, I have none close by to investigate.....
Jean-Pierre
#3 Posted : 14 May 2023 15:25:40(UTC)
It would make more sense to get Peco points and track if only two rail running is required.
Use Trix C track points (and track). Trix C track is two rail only, the only problem is it doesn't have the full range of pieces that the Marklin C track does. One would have to compare catalogues to check exactly which pieces are not available in the Trix range.
Offline Williamka
#4 Posted : 09 June 2023 06:29:57(UTC)
Williamka
I have managed to successfully convert C track to DC running as I wished to use the Marklin curved ramps and bridges for an above ground Subway/Metro project and only Marklin C track fits. For another venture I bought a Marklin turnout to see if it could be converted to DC. So far it awaits the necessary surgery as I figure things out. I might be wrong but I believe that it is possible. It has a live frog which I believe means it will short when switched. So it will need some work to insulate/isolate the straight downline spur... Its the unique way the Marklin C track works to connect one piece to another that will need to be figured out and reconfigured. Getting the C track to work on DC presents its own unique headaches - it can short through the central contact strip so it is more reliable when that is isolated - a swift piece or surgery using a Dremel cutter does the trick. My Ree USA tank is happily whizzing around the oval as I write... I'll post again if and when successful.
Offline Yigal
#5 Posted : 09 June 2023 06:34:07(UTC)
Yigal
Israel
At this stage, I gave up and ordered DC turnouts.
Let me know what conclusion did you reach.
#6 Posted : 09 June 2023 14:47:28(UTC)
Hi Yigal and you all
Welcome to this great forum.
Yes converting C track to 2 rails is easy. Where it gets difficult is to convert short radius (R2) turnouts to DC
Here is a German video on how to insulate rails on short radius switches
Notice that the frog is insulated during the conversion
I have not done it but it seems feasible.
In case you have difficulties with German:
Turnout (24611 - 24612
- all ground bridges (Three of them) are cut "Masseverbindungen" Video 1:46 into it
- all rails on the same side are wired (LHR and RHR) 3:58 into the video
- the frog is pushed down 4:26 into the video
- the "A"-shaped contact sheet metal is removed 5:00 into the video
- the frog is filed so to be insulated 5:56 into the video and so that it does not contact the small rails after the frog.
- check continuity and insulation 8:03 into the video
Double Slip Switch (24624)
- cut the four bridges
- connect all LHR together and all RHR together
- that seems to be it.
Offline Williamka
#7 Posted : 09 June 2023 22:34:22(UTC)
Williamka
thanks 1 user liked this useful post by Williamka
Offline Williamka
#8 Posted : 09 June 2023 22:41:42(UTC)
Williamka
Hello Jean - I tried to reply and thankyou. But alas I have no idea how this software actually works - there seemed to be nowhere to type! Thank you very much for the Germán Video. I could understand much of it and took some screen shots to help. It was simple to execute.. Getting the frog off the turnout took some persuasion - (a rubber mallet and tool). A small tank will run over the turnout in both directions - it tends to stall or hesitate on the frog - so needs a boost to get through. I'll get another turnout to sacrifice and see if I can do a better job. :)
#9 Posted : 09 June 2023 22:53:25(UTC)
Hello William
Also me, when I write a message I correct myself afterwards No problem.
One thing I suspect but I am not sure of is: are the short rails and mobile blades powered? I think they are even after removing the A-shaped sheet-metal part.
Improvements could be by fitting the luke: powering the frog by inserting a wire on the hole before clipsing the frog to its ballast.
Your approach is very interesting.
My fun is with automation. Here is my PC-controlled layout (Rocrail+CS3) on a 3 rail, C-track system
https://www.youtube.com/watch?v=F6WnhXPcRqI
Offline Williamka
#10 Posted : 10 June 2023 07:50:12(UTC)
Williamka
Hello William
The mobile blades are powered - there are connections to the live rails where the A shaped insert joined the mobile blades ( I cut these connections - my big mistake) the fixed blades
once the A insert is removed are not connected. There should be no problem with a loco with a longer wheelbase than a tank engine. My soldering skills are not so far equal to the task of connecting the fixed blades... A lot of molten plastic and loose wires...:) But it may be possible to remove only the apex of the A insert and leave the rest in place - then the fixed blades would be powered - my guess is that that would not be satisfactory!
Thank you for the video -that is one truly amazing layout.
#11 Posted : 10 June 2023 12:59:10(UTC)
Hi William
Glad you liked my layout. Thank you
Soldering C track rails: this is possible BUT you must use "Soldering water" (not sure how you call it in Canada, I use here a German product called "Lötwasser"
The critical point is to reach rapidly the soldering temperature without melting the plastic around. Some training with old C-track bits may be helpful and also temperature-controlled soldering iron (for Electronics).
Offline Williamka
#12 Posted : 11 June 2023 00:36:32(UTC)
Williamka
Hi William
Thank you - I'll Give it a try..
Offline Williamka
#13 Posted : 11 June 2023 07:10:06(UTC)
Williamka
The problem of the dead fixed rails on the turnout was given a quick fix by placing two springy copper wire 'U's between the fixed rails and the live rails to draw power. They don't interfere with the running and are not highly visible. They make the turnout fully operational. ...
Offline heinrichhess
#14 Posted : 11 June 2023 12:25:31(UTC)
heinrichhess
i think the wheels will have problems as well as height are different
Offline Williamka
#15 Posted : 11 June 2023 20:12:06(UTC)
Williamka
Many thanks for the advice..
My experience is that the rolling stock and Loco's whether North American, OO UK, or Euro DC all handle these turnouts with ease.
It's not a smooth frog but so far there have been no derailments either forwards or in reverse...
There well maybe some rolling stock out there that does not work.
If anything of a standout nature surfaces during operations then it'll get a mention..
Offline Williamka
#16 Posted : 12 June 2023 18:05:32(UTC)
Williamka
And here is the quickest solution - don't fix the turnouts - Trix apparently do identical track in DC..
#17 Posted : 12 June 2023 18:11:19(UTC)
Alan mentioned that in #3.
Offline Williamka
#18 Posted : 12 June 2023 19:54:33(UTC)
Williamka
Thanks I am as thick as two short planks !BigGrin
#19 Posted : 13 June 2023 21:54:00(UTC)
So long as it is not two short tracks ... RollEyes RollEyes
Offline Williamka
#20 Posted : 23 June 2023 19:58:19(UTC)
Williamka
The Trix turnouts have arrived (one left and one right) and I am pleased to report that they work very well with the DC adapted Maerklin track.
The colour of the plastic is a lighter more of tan shade of brown so the colours don't match but they do blend.
I now wish that I had known about the Trix/Maerklin compatibility before setting out on this current venture.
There's enough range for the Trix/Maerklin track that make it suitable for many different uses.
It's a quality engineered product and useful for the rapid prototyping of proposed layouts
whilst making good use of many of the Maerklin accessories, like bridges and ramps and so forth..
SO
Thanks everyone for all the encouragement and help..
This page was generated in 0.506 seconds.
