Offline Mille
#1 Posted : 10 May 2023 10:03:36(UTC)
Mille
Light is on and i have tried
Another adres but cs3 says no
New mfx articles can be found
Anyone know why or have an idea why??
#2 Posted : 10 May 2023 10:27:47(UTC)
Please specify which m84 ( m84.1 = 60841=white, m84.2 = 60842 = black)
only the m84.2 is mFX configuration ready
what do you mean by "light is on" - which light.
refer manual for correct led status indications (next to red/brown feed)
please confirm the CS3 mFX protocol has not been disabled.
Offline Mille
#3 Posted : 10 May 2023 11:40:15(UTC)
Mille
The black m84
I mean the led light is on
so it got power
thanks 1 user liked this useful post by Mille
#4 Posted : 10 May 2023 14:20:43(UTC)
What is the dip switch set for? DCC, MM, or MFX
Offline Mille
#5 Posted : 10 May 2023 14:59:38(UTC)
Mille
2,3,4
Should be adres 53-56
in manual
#6 Posted : 10 May 2023 15:40:31(UTC)
Originally Posted by: Mille Go to Quoted Post
2,3,4
in manual
Dip switch number 10 are to set MM or DCC.
I recommended you try DCC protocol and click to search mfx article.
Good luck!
Offline Mille
#7 Posted : 11 May 2023 05:23:09(UTC)
Mille
Still no luck
Dont know what more i can try
#8 Posted : 11 May 2023 14:22:31(UTC)
If you've already disconnected it and retried, maybe it's defective? Have you checked all. The CS3 settings for correct parameters?
Offline Mille
#9 Posted : 12 May 2023 05:24:05(UTC)
Mille
What should be correct settings
in cs3 then?
Offline LSQ
#10 Posted : 12 May 2023 08:06:50(UTC)
LSQ
China
1. Try another set of address;
2. If have other workable 60842 in CS3, may replace it by new 60842 with same address to see what will happen.
thanks 1 user liked this useful post by LSQ
#11 Posted : 12 May 2023 16:01:33(UTC)
Yes, and set to DCC, there are more addresses possible, no? Or is it MM? I think the German "trainguy" on YouTube shows how.
#12 Posted : 13 May 2023 10:26:30(UTC)
Test by reset CS3.
It is possible that CS3 needs to be clean up.
I did have same similar problem with m83.
After reset CS3 the m83 did start work again.
Offline FrankF
#13 Posted : 16 May 2023 00:50:44(UTC)
FrankF
There has been a range of Marklin 60842 - M84 Decoders which is not working "correct" because of a failure made under Production.
These cant be programmed "manually" or with "mfx" and is not working correct.
If the M84 Decoder's Label on the backside of the M84 Decoder has a Serial-number where the last 5 Digits in the Serial-number
is inside the Serial-number range shown in the following listing :
41682-41861
40869-41501
40462-40783
38711-40423
37228-38126
M84 Serial-number
then the M84 Decoder has a Production-failure and can be replaced by your Dealer.
Contact your local Marklin Dealer for more Information.
CURRENT MARKLIN SOFTWARE/GFP/FIMWARE - UPDATES:
• CS3+ 60216 SW 2.5.2(6) • CS2 60215 SW:4.3.2(4) • MS2 (SW 5.6) • 6011x GLEIS-BOX (GFP1.70) • MS2-WLAN (FW 5.4.0.21) • 60117 WLAN-BOX (FW 0.3.0.2) • MS1 (SW:1.8 AP) • S88 LINK (SW1.1)
• MDT V3.6.0 (HW: 60970/60971/60801) • MLD3/MSD3 (FW 3.3.6.2) • MSD3.5 (FW 3.5.1.1) • 1098 MLD3/MSD3 DECODER-PROJECTS ON M-SERVER • MARKLIN SOUND-BIBLIOTHEK ( 33.744 SOUND-FILES )
• LOK-PROGRAMMER (SW5.2.15) • ESU HW (53451/53900/53901)
thanks 1 user liked this useful post by FrankF
Offline Mille
#14 Posted : 16 May 2023 07:29:30(UTC)
Mille
Sadly my m84 number was not there
I managed to get it work once but i needed to
delete m84 from article list becuse
i choosed an occupied adres
After that cs3 dont find it again
even if i have tried many different
dipswitch settings
Anyone have an idea why??
Offline FrankF
#15 Posted : 16 May 2023 09:48:05(UTC)
FrankF
Connect the M84 Decoder to the Programming-track and try to read out the M84 - CV Parameters under DCC.
If you can do that set CV 8 to the value "8" and try to reset the M84 Decoder under
DCC and see if this helps you with your problems.
The M84 Decoder only uses MFX-Protokol to add the M84 Decoder to the Article-List , after that the M84 Decoder is used
with the MM or DCC Protokol to control the Switching Articles.
Offline Mille
#16 Posted : 16 May 2023 12:38:09(UTC)
Mille
Tried it but only things that happen
is that it add a new article called X1
with adres 12
Guess i need go to my Märklin dealer
Thanks for all help
#17 Posted : 18 May 2023 12:11:23(UTC)
41682-41861
40869-41501
40462-40783
38711-40423
37228-38126
M84 Serial-number
Strange...i have never notice information by Märklin about the digital problems.
It should be present but never heard about info by Märklin.
This page was generated in 0.427 seconds.
