2 Pages<12
#51 Posted : 06 March 2009 20:46:54(UTC)
Re 6/6 models postponed until 2010.
I guess that that will give Maerklin the time to decide to issue another road number than one that has already been released by Roco or Hag and also correct the positioning of the Cargo inscription on the Re 620.
I can wait for a few months longer. The models were in any case AFAIR listed for fall delivery.
Offline TimR
#52 Posted : 07 March 2009 00:12:44(UTC)
TimR
Indonesia
<br />Re 6/6 models postponed until 2010.
I wish they took this time to reconsider whether going with the standard 5 pole HEP for a new tooling item is a wise choice. Especially since they are killing their own HLA model by advertising SDS as the more superior choice.
If you look at the BR 152/182/189 family, they had managed to convert these from formerly HLA layout into SDS with almost unnoticable changes of the basic bottom frame. I'm still at lost why they haven't done this on more models instead of building extravagances like the Gotthardo or other exclusive insider models or the past three-four years.
Now collecting C-Sine models.
#53 Posted : 07 March 2009 01:25:06(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by TimR
Empty of money perhaps...?
#54 Posted : 08 March 2009 12:38:56(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Unholz
<br />You are right: Marklin has so far not produced a model of the Re 6/6. The reason is probably simply that Marklin thinks that the competition (HAG, Roco and Lima) has more or less flooded the market with such models for many years and that it would be difficult to create a big sales success at this stage.
You could certainly form an Re 6/6 consist with Marklin and HAG models, but in my opinion it would take some fine tuning of both locos to make them run exactly at the same speed and with identical behavior on gradients. Although more expensive, it might be easier to buy one of the Re 10/10 sets offered by HAG.
Not if you are using the most famous logotyp name:MARKLIN
That makes more hungry after theirs products instead by of using HAG.
I think Marklin was coward,by not producing some models that means also a new worktoy to created it...!
It cost money by acting like this.
Offline HGH
#55 Posted : 19 March 2009 21:56:34(UTC)
HGH
<br />Maerklin has not yet released a model of the Re 4/4II or Re 421 with the new air conditioning equipment on the left sides of the lok.
Hag has released a model of the Re 4/4II with this modification, which is a separately applied plastic piece. I understand that on the Re 6/6 (620), the A/C unit is merely printed on the lok shell.
Roco's Re 4/4II and Re 6/6 have not yet been produced with the A/C unit, although KML (ex Roco CH) have released special models for the Swiss market with printed on A/C based on repainted overstock of earlier releases.
The Hag lok with A/C is very nice, and if you are interested, it was recently listed at Eurolokshop at a very good price.
with kind regards ... HGH
modell-railroading is fun
Offline TimR
#56 Posted : 19 March 2009 23:31:36(UTC)
TimR
Indonesia
I think this has already been discussed. NONE of the Re4/4-II models released so far are equipped with SDS motors, but HLA's instead; including the ones introduced this year. Since many Märklin fans who are eagerly looking forward to the release of this great Re6/6 model will also to run it as Re10/10 consist, it would be quite challenging to synchronize the two very distinct motor types. Another advantage of a HLA model is its (relative) easy/ier installation of a (mfx-) sound decoder.
Hi Lutz,
The curious thing is just this;
This will be the first new five pole motor layout released by Marklin since at least 2006. Every other new tooling model from Marklin since then had been of the maintenance free ones (incl 36xxx models)
As you had posted a few months ago;
Any new Märklin Re6/6 would most likely be equipped with a SDS, opposed to the HLA's in their Re4/4-II's; but I don't see real big difficulties to align different motors, even from different providers (I achieved this successfully with a number of my models).
You had obviously reached the same conclusion I did then in regards of motor choice should Marklin released an Re 6/6. And you also pointed out that it will be easy to align the SDS to Re 4/4 II’s HLA.
Smile
Don’t get me wrong, I’m planning to get one of this new Re 6/6 too (I'm a sucker for Swiss models [:p]).
Just pity that this model is just not as good as it could had been.
#57 Posted : 20 March 2009 02:09:20(UTC)
Tim,
obviously, the Re 6/6 (620) was designed to match the performance of the Re 4/4II (420/421). This probably extends to common parts for the two series as well.
This makes sense as this way any Re 6/6 could be combined with a Re 4/4II and have simlar performance quality.
In any case, we will find out more about this model later this year or early next year once development resumes and production is started.
It is still possible that this model may be further postponed or cancelled depending on the decisions of the eventual new ownership of the company.
Offline TimR
#58 Posted : 20 March 2009 03:40:27(UTC)
TimR
Indonesia
Mike, it's almost certain that these two models will probably share the same basic motorized axles (& gears) housing.
I was just saying that with what Marklin had done with their Eurosprinters seemed to have indicate that they wish to upgrade more of their lineups to SDS.
AND the fact that new 5-pole layouts had not been built in a number of years seem to indicate that they are not planning to expand this range further and concentrate instead on the hobby range and SDS.
Many Marklin customers had, for the past few years, read these signs pretty clearly. For example, this had led to rumours late last year that Marklin would launch a new BR 41, eventhough technically the 37921 is still a current model.
As can be seen the development of the new BR 189 family had benefited last year's 39342 BR 152, which is a 'related' family model with similar axle designs. In similar ways, I think, Re 620 development could have benefited the existing Re 4/4 II design upgrade.
Who knows what's the real reason M had decided to opt with five pole layout for the new 6/6?
The simplest answer would had been to save cost, I would say, rather than deliberately choosing to get the new Re 6/6 to match the older Re 4/4 II's layout.
But if cost had been the main issue, the opposite argument is that it is possibly cheaper for Marklin to develop retooled SDS axles for a couple of their older models, slap new warm white LEDs (or other minor upgrades) and re-released them as new tooling models - like they had done with the BR 152, 189 & Taurus. Provided the PCBs can be shared by as many new models (don't know why they had so many diff PCB parts), development cost would had been minimal compared to entirely new construction model. As the 'BR 41' rumours had shown, it could help rejuvenate markets for these older models too, which are currently beseiged by the new SDS models and expanding 36xxx range.
But enough with all the long mumbling...Smile
what's been done is done.
Like I said, despite all of that, I am still looking forward for the 37320 and 37321.
Release date:
Even when I first looked at the original product scheduled release, I had concluded that this model will arrive in 2010, as the case was with the last year's BR141/E41. The latest news of postponement prob only move the release date to a more achievable time frame. Sadly of course, the question still hangs in the air on whether new owners might cancel this model.
#59 Posted : 22 March 2009 20:45:32(UTC)
The development department at Trix had nixed any new production with C-sine technology. Models that were being developed for release in Maerklin and also for Trix might be limited to HLA to minimize the need for different parts. Although the Re 6/6 was not listed as a Trix model, it would likely be released as a Summer, Fall or 2010 New Item. Same as the EC version of the Gottardo Set.
Offline TimR
#60 Posted : 22 March 2009 23:58:10(UTC)
TimR
Indonesia
<br />The development department at Trix had nixed any new production with C-sine technology. Models that were being developed for release in Maerklin and also for Trix might be limited to HLA to minimize the need for different parts. Although the Re 6/6 was not listed as a Trix model, it would likely be released as a Summer, Fall or 2010 New Item. Same as the EC version of the Gottardo Set.
Plausible explanation...
But then again, Trix did release a new BR 120 with plastic body, 4-axles driven, with 5-pole skewed motor last year (T22603-4) instead of simply converting Marklin's proven metal construction HLA 37536 to DC like they did with T22764.
#61 Posted : 23 March 2009 04:14:07(UTC)
You are correct. I believe that the 5-pole skewed motor will be the standard for all loks designed and built for Trix. The HLA will appear only in those models developed jointly with Maerklin.
Whether this will continue to be the case after 2009 is not clear as this had been one of the policies instituted by the Trix Development Department (Nuernberg), which has been pretty much decimated by the cuts announced by Pluta since the bankrutcy liquidation process started.
I guess that Trix Development will now be concentrated within the corresponding Maerklin Department, so we can expect more standardized models and less brand specific releases.
This decision may have an impact should somebody be interested in buying the Trix brand as they would have to restart an inhouse design and development department pretty much from scratch.
#62 Posted : 23 March 2009 12:03:01(UTC)
<br />You are correct. I believe that the 5-pole skewed motor will be the standard for all loks designed and built for Trix. The HLA will appear only in those models developed jointly with Maerklin.
5 polig skewed motor...?
You mean DC motor placement central of locomotiv with brasswheel...?
Don´t forget that Trix are already doing that with coreless motor typ Faulhaber or and Maxxon motor in the news locomotiv too.
SDS motor has some problems with DCC and circuitboard.
There has been complainment about that too.
Offline TimR
#63 Posted : 23 March 2009 23:53:24(UTC)
TimR
Indonesia
I think the possibility is slim that the Re 6/6 with HLA construction, is going to be released by Trix, especially considering they opted out of (what supposedly cheaper/easier option) metal HLA BR 120 in 2008.
It will probably as slim as the chance that Trix's new tender-driven S3/6 could ever be released by Marklin.
I mean, most of us are not too terribly excited with tender-driven steamers common in the DC markets. So possibly DC customers are not too excited about Trix's remaining HLA models as well.
Offline Unholz
#64 Posted : 11 November 2009 20:53:43(UTC)
Unholz
I don't remember whether these two pictures have already been shown here somewhere (scoll downwards a bit, thank you):
http://www.bahnorama.ch/...nfo.php?products_id=5326
The front view reveals that Marklin is again not willing to properly render the window sides as part of the body structure. Instead there will just be a cheap looking vertical line of paint on the window insert, as in case of the Ae 6/6. Not the kind of quality customers are used to from the competitor models! [:(!]
Offline jeehring
#65 Posted : 11 November 2009 21:09:22(UTC)
jeehring
[size=1" face="Verdana" id="quote]quote:Originally posted by Goofy
Not true.
SDS works very well with DCC.
Offline TimR
#66 Posted : 11 November 2009 21:55:59(UTC)
TimR
Indonesia
<br />I don't remember whether these two pictures have already been shown here somewhere (scoll downwards a bit, thank you):
Looks like they did the same like in the Re4/4 II - but overall I think it was very well done and tidy, as Cem's picture in this thread shows;
https://www.marklin-user...ult.aspx?g=posts&t=13995
The vertical line between the front windows and the side front windows looked to be quite thin in HO, so I guess it is understandable why Marklin want to take the shortcut. I had not even notice it in my Re4/4 II until you pointed this out on the Re6/6. Overall, I don't reckon it's going to be a problem, as personally, I am fully satisfied with the level of details on Re4/4 II.
On the Ae6/6, attention to detail is just not up to the level done in Re4/4 II - well, this is an old tooling after all..
Perhaps a minor makeover for the Ae6/6 is overdue..
With Re6/6 - I'm more concerned with its pulling power; this is the Gotthard locomotive, after all. At the very least, I hope it would do as well as the Re4/4 II and Ae6/6. But I guess we'll see when it comes out..
#67 Posted : 11 November 2009 22:07:53(UTC)
I wanted to thank Stefan for posting the link to the photos of the raw mould for the new Re 620 model. Stefan pointed out that Maerklin appears to be using the same design for the windows that they already used for the Ae 6/6 and the Re 4/4II.
Bahnorama has also posted models of the mould for the green Re 6/6 with the round headlights:
http://www.bahnorama.ch/catalog...ci2uol6idd6p9u1pqsvles01
I am looking forward to seeing the final model. I am not too concerned about the window issue as long as it is not blatantly visible like it was in the Fleischmann and Lima models.
Every model has it's positive and negative points. The Roco model had very nicely detailed pantographs and windows. However, it suffered from an oversized footboard and a red shell that allowed light to shine through.
The Hag model initially had a very visible casting mark adjacent to one of the driver's cabs. This is not visible or is less visible on subsequent productions. The other issue with the Hag model was light shining out underneath the motor bogie and lighting up the tracks.
So, I am willing to give the Maerklin model a chance and see how it looks and performs. The only downside for me is that I already have the 11687 "Bischofszell" from Hag (OK not digital) and 2 Re 620s from Hag. I would have preferred if they would have put out a lok number not already on the market and will probably wait for the model to come out in red.
Hey Maerklin, how about 11629 "Interlaken", 11628 "Konolfingen" or 11679 "Cadenazzo"?
I know Lima already did the "Interlaken" model but I like the City!
#68 Posted : 12 November 2009 01:27:02(UTC)
Hopefully with Led's being introduced into Roco Models, she shine through effect will be a thing of the past.
My Roco Re 6/6's had some alterations to increase the pulling power
a.) added axles with Rubbertyres
b.) modified middle bogy with ground pickup feeder
c.) stretched springs to keep middle bogy firm on tracks at all times.
The VSLF is the only Re 6/6 with advertising and is seen here with the 100 year celebration of this club
VSLF: Verein Schweizer Lok Führer (Swiss Loco Driver club)
regards.,
2 Pages<12
This page was generated in 0.664 seconds.
