Offline Thewolf
#1 Posted : 07 November 2022 23:52:12(UTC)
Thewolf
Hi gang. Cool
My goodness, it's been a long time since I came to the forum. Blink
Winter is coming and it's the beginning of the train season. I'm back to work on the layout.
I hope you are all well. I'm fine and it's been a great summer season...with a few surprises though and many decisions have been made.
To come back to my layout Train de la Vallée du Richelieu, after 3 minutes. already a little problem : after many months of inactivity, I put my cs2 in function...the stop bar blinks...the cs2 loads correctly...all the screen appears correctly.....and oops the stop bar lights up, remains frozen ...the leds of the stop bar light up red....the cs2 is frozen, planted.Crying Crying Cursing Blushing Mad
What should I do? Thank you for the answerCool
Thewolf
#2 Posted : 08 November 2022 00:17:34(UTC)
Hi gang. Cool
Thewolf
The current version of the software comes up with the stopbar lit when it has finished initialisation so that anything on the layout doesn't take off unexpectedly.
Did you try operating the stop bar to see if the red lights go out?
Offline Thewolf
#3 Posted : 08 November 2022 00:34:02(UTC)
Thewolf
Thank you for your reply.
SorryCrying I forgot to explain that I had tried to operate the stop bar so that the red leds went out.
Despite two or three attempts to operate the stop bar, the cs2 remained as it was with the red leds on.Mad
Thewolf
#4 Posted : 08 November 2022 01:27:27(UTC)
Have you tried disconnecting everything (except the power cable) to see if it will fully complete the startup, to rule out any external influence?
Offline Thewolf
#5 Posted : 08 November 2022 05:55:59(UTC)
Thewolf
No I didn't. Tomorrow morning without fail
Offline Thewolf
#6 Posted : 08 November 2022 17:41:30(UTC)
Thewolf
Hi gang Cool
The cs2 was sent to Mike, my dealer, from westend trains
Thewolf
#7 Posted : 08 November 2022 20:14:15(UTC)
Hi gang Cool
Thewolf
I guess that means it still did the same thing with absolutely nothing else connected except the power, (no connection to the track etc)?
Not much more you can do if that is the case. Might still be a relatively simple issue but needs technical experience to diagnose BigGrin
#8 Posted : 08 November 2022 20:19:53(UTC)
Hi gang Cool
Thewolf
IIRC there was a loop that could cause this when updating the software, but I think he has done the right thing by taking it to his dealer.
Online JohnjeanB
#9 Posted : 10 November 2022 13:12:40(UTC)
The CS2 was very innovative and I liked it a lot. I have 2 of them, one 60214 that failed and was returned / repaired by Märklin (changed the mother board for a 60215 one)
I used them intensively for 10 years but I met some difficulties with them:
- the Stop bar switch was not active all the time. I had to open and use contact spray on the switch to solve the issue
- the booting up was never completing (the progress bar, instead of stopping near the screen's center, continued all the way to the right). I solved this once by booting many many times being near an internet access and when successful making an update
- the accessory output not working. Never been able to repair this one.
So today, one of my CS2s is booting and working OK but without a programming track while the other one cannot finish booting no matter what I try. I read in a German forum, that this could be caused by a mass memory chip having too many errors to self-repair.
When I interrogated both my dealer in Paris and Märklin in Göppingen in 2020, I got this:
- no Märklin cannot repair any CS2 (60213 to 60215)
- send back the unit to Göppingen and we will check: They made an offer for a reduced price on a CS3
- I ended up turning down Märklin's offer as I got a better deal from MSL (Lippe) for a 60226 (584€ in Oct 2020).
So as of today I have a CS3 and also a CS2 quite functional but without a programming track capability
#10 Posted : 10 November 2022 13:42:33(UTC)
I find myself using the stop button on my auxiliary MS2 more than on the CS3. A derailment short often takes longer to trip off the CS3, and mostly the emergency stop will trip the MS2, thus the CS3 doesn't even show that it is in stop mode unless the error and warning red window pops up.
Online JohnjeanB
#11 Posted : 11 November 2022 13:33:00(UTC)
Yes, in some cases, with the latest s/w version on a CS3, when a short happens, the STOP bar does not lit but the current is cut all the same.
Small s/w bug I assume, that will be corrected by the next update. It has been more than a year since the last update so one is probably brewing in Göppingen.
They are also probably working on the CS3 replacement (should be released in less than 2 years time I think).
#12 Posted : 11 November 2022 19:21:29(UTC)
Jean, the last update was in March which included the third pop up Loco controller feature. The prior one to that was in October 2021. I log them in my CS3 big manual when I install them.
Offline Thewolf
#13 Posted : 17 November 2022 22:21:23(UTC)
Thewolf
Hi GangCool
I have a tile: my cs2 according to Mike has to go back to Germany but I'm not tempted, because you know when you send an item there but you don't know when it will return and I'm not sure they will fix it
So the whole gang knows I'm working with Itrain for layout control.
What should I take as a cs3 ? the 60216 or the 60226 ?
Thanks gangCool
Thewolf
Online JohnjeanB
#14 Posted : 18 November 2022 00:43:09(UTC)
The CS3 (60226) has the following advantages:
- has all the qualities of a CS3 + (60216) BUT has no integrated Link88 (that is simplified on a 60216 unit) and no capability to be a slave unit (does not matter when using only one CS3)
- is cheaper even when including a Link88 (60883).
- the separate Link88 offer 3 different buses one of which allowing to re-use older 6088 or 60880. The other 2 buses allow to grow the regular units 60881 in 2 directions which is key for medium and large layouts
- unlike the CS+, the whole power of the CS3 is fully dedicated to power the layout and not the S88 system
- the CS3 has 2 CAN plugs and not one like the CS3+
It must be noted that many CS2 users have already a Link88 (60883) which increases the attractiveness of the CS3
Just my opinion
Offline Thewolf
#15 Posted : 18 November 2022 01:04:18(UTC)
Thewolf
Just my opinion
Thanks Jean Cool
If I understood correctly what you were saying:
as I use a 60883 marklin with LDT RM 88 n Opto decoders, the CS3 60226 is the console I need.
It is cheaper than the 60216,
Thanks Jean, I will follow your advice Cool
Thewolf
Online JohnjeanB
#16 Posted : 18 November 2022 14:06:53(UTC)
Yes, exactly.
To come back to the idea of sending back the CS2 for repair, I have been through this, taked to Märklin Germany (Märklin service people) and here is what I got:
- NO for sure, Märklin will not repair any CS2 because they have no electronic spare parts. So, even for cosmetic repairs, they would be forced by (European) law to guarantee the repaired CS2 which they can't.
- So, almost without checking, Märklin will propose to keep and dispose of the faulty CS2 in exchange for a reduction at a Märklin dealer in your country. Märklin must be returned the faulty unit no matter what (cost). When this offer was made to me, I checked and found that this was better for me to keep my CS2 and order a new CS3 by checking the best offers in Germany. So at the time, I got a much better deal than Märklin's offer. Of course, shipment to France is much cheaper than to Canada (6 to 12 €, no duty)
About my 2 faulty CS2s: one does not boot up anymore, the other is almost fully functional: only the program track output is dead OK. I can even use it as a bosster and a slave unit to my CS3 (60226)
Offline nhumps
#17 Posted : 18 November 2022 19:51:53(UTC)
nhumps
Hi, maybe it is too late now but have you ruled out as suggested by Jean about the stop bar perhaps being faulty?
Do you have an MS2 you can plug in to test the STOP button?
Or connect the CS2 to the network and use the Marklin App or Web interface to try the stop button virtually?
For a while my STOP button on my CS2 was sticking and pressing it at different places/angles was required. As it turned out there was an obstruction in the mechanism and once cleared it has returned to normal operation
Offline Thewolf
#18 Posted : 18 November 2022 20:47:24(UTC)
Thewolf
I understand but I explained to Mike, my dealer of over 10 years in Toronto, everything that Jean commented to me.
Mike told me that my cs2 was dead and even if Marklin fixed it as it is over 10 years old there is no guarantee that it will work 100% in the future.
So I decided to upgrade to the cs3 60226
Thewolf
Online JohnjeanB
#19 Posted : 18 November 2022 21:17:35(UTC)
If we are sure, it is the stop bar that is not working (can it be activated by a plugged-in MS1 or MS2?) and all the rest is fine, then is is a matter of changing the SMC switch on the mother board.
Here is the backside of a 60215 mother board on one of my CS2s (the side adjacent to the screen and keys)
Once the transparent pusher (see the red frame in picture) is moved away, the regular SMC (Surface Mounted Component) switch can be removed and changed.
For this you need:
- a set of Metric Torx screwdrivers (to open the CS2)
- a SMC Digital desoldering iron hot air soldering station such as this one https://www.ebay.de/itm/40289546...YJo%7Ctkp%3ABFBMuI6DxpFh
- the switch component to be purchased on Internet (less than 1 € usually)
Note: it is delicate work with good tools and an illuminated magnifier.
Offline Thewolf
#20 Posted : 07 December 2022 18:09:33(UTC)
Thewolf
Hi everyone Cool
I followed what Jean said and ordered the cs3 60226 from Mike.
I will receive it in 4-5 daysCool
Have a nice day
Thewolf
thanks 2 users liked this useful post by Thewolf
Offline dickinsonj
#21 Posted : 08 December 2022 01:33:12(UTC)
I think you will really like the CS3. It is a far better machine (computer ) than the CS2, which I used for many years.
I won't go into all of the details but it is basically better in every way, with a far superior screen and processor. I still have my 60215 CS2 and use it as a slave to the CS3, which works quite well. ThumpUp
Enjoy!
Offline Thewolf
#22 Posted : 08 December 2022 04:52:29(UTC)
Thewolf
Enjoy!
Thanks for the comment.Cool
I will use the cs3 as a support for the ''Itrain'' software
Thewolf
#23 Posted : 08 December 2022 12:12:33(UTC)
I have the CS3 PLus ( dont want a link but just connect straight to the S88) You will like your CS3 which for me does all I want without the hassle of other software. CS2 was good and if fixed you can still use it.
Offline Thewolf
#24 Posted : 08 December 2022 17:05:46(UTC)
Thewolf
Thanks for the commentCool
According to Mike, he doesn't know how to fix the cs2 and I don't want to get it fixed by Groeningen, as it's over 10 years old.
We know it's starting to fail, it's not good. You fix it, you pay a crazy price and then something else breaks down.
Thewolf
Offline BenP
#25 Posted : 09 December 2022 00:02:46(UTC)
BenP
Thewolf
One more option perhaps. Can you use the CS2 as interface with PC train software, like Rocrail for example? My CS3 is underused and is just there to pass commands to/from PC. Expensive solution for an electronic interface. Maybe Marklin can offer a command connect box as future option instead of ever pricier control stations.
Offline Thewolf
#26 Posted : 09 December 2022 16:22:11(UTC)
Thewolf
Hi the gang Cool
I have received the cs3.
I am disappointed with the user manual: I thought I would receive the same complete manual as the cs2 but what I received will not help me much.
You pay a lot of money and you get less and less.
I have to say that Marklin don't care about their customers.
Thewolf
Online JohnjeanB
#27 Posted : 09 December 2022 17:42:52(UTC)
Hi The Wolf
I have to politely disagree. Yes, you are absolutely correct the paper documentation is quite thin on the CS3 (20 pages or so but to be honest it stayed in the box). I have an electronic copy on my computer.
Indeed, with my CS2 there were 4 thick documentations (50 - 80 pages not sure) in European languages (in late 2010). Later, in 2012 I got a Mega starter set with another CS2 and the documentation got already thinner.
I realized, over the years that the documentation kept on changing and the paper could not follow-up. Remember the CS2 Update to 2.0?
So Märklin decided to turn towards an electronic thick documentation constantly updated and assign the saved paper cost to better and fast-changing electronic documentation and plenty of videos on Youtube.
Not wasting resources (paper) and allowing to make electronic searches and annotations is now possible
Just my opinion
Similarly, I have all the Märklin catalogs on my computer (also all the real ones except 1949 and 1950) and I can access them quickly and much more easily than original catalogs 2007-2022 (cannot be scanned and shared)
Offline rhfil
#28 Posted : 09 December 2022 18:12:58(UTC)
rhfil
Most manufacturers have gone away from including detailed manuals with products but offer them online. The online downloadable CS3 manual is pretty good and you might want to consider getting the 03093 manual.
Offline Thewolf
#29 Posted : 09 December 2022 20:21:47(UTC)
Thewolf
Hi The Wolf
Just my opinion
Let's just say that my reaction was a "hot" reaction but once it was over, I was able to find the complete manual in pdf in French on the net.
I am in the process of reactivating my laptop which has been closed for several months, the little train activity being on standby for outdoor activities (summer).
Once the laptop is operational, I will be able to activate the cs3 pdf for use.
That said, Jean, you are right in your comment
Thewolf
Offline Thewolf
#30 Posted : 09 December 2022 20:23:33(UTC)
Thewolf
Thank you for your comment.
The 03093 manual is only in english and my native language is french
Thewolf
#31 Posted : 11 December 2022 20:27:17(UTC)
Interesting... But, what is hot air soldering??? Confused
Online JohnjeanB
#32 Posted : 11 December 2022 21:06:21(UTC)
Hi Henrik
With recent electronic components (SMC= Surface Mounted Components), soldering unsoldering technique changes.
In real electronic production SMC components are placed by a robot on a PCB covered with a special product (flux and solder) Then, the board is placed in a temperature-controlled oven.
Sometimes you have to repair, change components (e.g.: replace yellow SMC LEDs with white ones or a transistor, etc)
So basically, with the hot air blower you may solder or remove components. Very interesting but it requires a learning curve and I'd like to learn.
I tried using my present Weller, temperature controlled soldering iron but for small SMD components it really does not work.
Here is a flavor of soldering SMCs
So, this is what I believe but I am learning and more and more, I find normal electronic components (e.g.: 1/4 watt resistor or bridge rectifier) huge and I need miniature components.
Offline rhfil
#33 Posted : 12 December 2022 14:56:04(UTC)
rhfil
But all Canadians are by law bi-lingual.
Offline Thewolf
#34 Posted : 12 December 2022 14:59:46(UTC)
Thewolf
Really ???
Offline PMPeter
#35 Posted : 12 December 2022 15:33:40(UTC)
PMPeter
Where did you come up with that info?
Yes Canada is a bi-lingual country, but there is no law requiring every Canadian to speak both official languages. There is a consumer law that requires labels on products sold in Canada to have both languages and instructions to have both English and French versions, but that is about it. Yes, there are federal jobs that require a person to be bi-lingual, but that is situational and not a requirement for every person in the country.
Offline Thewolf
#36 Posted : 12 December 2022 16:06:06(UTC)
Thewolf
AbsolutelyCool
In my province (Quebec) which is recognized as a French-speaking province, many Quebecers do not speak English.
I myself do not consider myself bilingual
Have a nice day
Thewolf
#37 Posted : 12 December 2022 16:07:14(UTC)
Not all Swiss people speak all four languages.
Not all Belgians speak German, even though it is an official language there.
Not all Italians speak German, even though it is an official language there.
Not all Germans speak Sorbian or Frisian, even though those are official languages here.
Offline rhfil
#38 Posted : 12 December 2022 17:44:10(UTC)
rhfil
It was supposed to be humor. My grandparents were all born in Canada and even after many years in the U.S. spoke French Canadian at home. All my friends and relatives spoke French Canadian. I did not speak English until I started in a parochial school where half the day was in French. If I am not mistaken, the law requires bi-lingual instruction in P.Q.. Does it also require it in other provinces?
Offline PMPeter
#39 Posted : 12 December 2022 18:24:09(UTC)
PMPeter
Simply, no. French immersion is offered in BC but it is by no means mandatory.
This page was generated in 0.888 seconds.
