Offline Eddie7979
#1 Posted : 18 October 2022 11:58:28(UTC)
Eddie7979
I have just preordered the latest SNCF Corail coach set from Roco, 1 x 1st Class and 3 x 2nd Class.
The plan is:
- install lighting, using the Roco 40420 throughout
- have one coach with the Roco decoder 10880 and slider 40500
- use the Viessmann or ESU 2 pole current conducting couplers
- change the wheels to AC compatible ones
I may also add an SNCF restaurant / buffet from LS Model once I find one that works with the set. I’ll use the same set up.
Just wanted to see if anyone out there has done this before and will to share their experiences. I’d be particularly interested in any information around the wiring.
I drew a very basic wiring diagram for the powered coach, I would love any feedback, especially if completely wrong!
Eddie
Perth 🇦🇺
Marklin | Roco | Piko
CS3+ & iTrain
#2 Posted : 18 October 2022 13:32:00(UTC)
Looks correct. Now if you want, you don't need to connect the wire on the couple to the locomotive., unles it has a digital switched coupler socket. You may also connect both leads to the led strip at one end. if it has dual terminals like Marklin does. If you do wire the other end to a current coupler, using the locomotive for lighting, be sure a pick-up shoe is not in the train consist on a car with a current condicting coupler, or it will short out!
#3 Posted : 18 October 2022 14:04:28(UTC)
Hi Eddie
Märklin user here.
In your schematics, you connect directly the slider to the LED strip and IMO:
- usually, self-adhesive led strips I use are 12 VDC and are much too bright (need a dimming resistor I often use 5.6 kOhms)
- not being sure that the LEDs can withstand the reverse voltage -20 V, it is better to insert a diode to rectify
- you need both alternances to avoid flickering so a bridge rectifier (full wave rectifier) is needed
It goes something like this
thanks 7 users liked this useful post by JohnjeanB
#4 Posted : 18 October 2022 20:15:52(UTC)
Not had much luck with attaching a slider to a Roco coach. The light bar looks expensive but you do get a spring type for the ground.
Look forward to hearing how you get on.
Offline Eddie7979
#5 Posted : 19 October 2022 01:22:51(UTC)
Eddie7979
Hi Eddie
Märklin user here.
Hi Jean,
I will keep this in mind if I use regular LED strips. I’m hoping that the Roco ones won’t need the extra components.
According to the description, Roco set 40420 is compatible with AC and DC, it can also accomodate a decoder which can adjust brightness. It also has the buffer capacitor to avoid flickering, this was really attractive to me.
Thank you so much for sharing!
Eddie
Eddie
Perth 🇦🇺
CS3+ & iTrain
Offline Eddie7979
#6 Posted : 19 October 2022 01:30:46(UTC)
Eddie7979
Hi David,
To be honest I was worried about this as well, I created a post about this as well and asked people to share their experiences.
This will be the first time I use Roco coaches so, we will have to see. I’m told that attaching the slider can be a bit fiddly, it’s easy to break.
The link to the post if interested:
https://www.marklin-user...Conversion-to-Marklin-AC
Eddie
Perth 🇦🇺
CS3+ & iTrain
Offline Eddie7979
#7 Posted : 19 October 2022 01:37:08(UTC)
Eddie7979
Thank you!
I coupler between the coach and train will not be powered. The plan is to have the last coach as the powered one, sharing to the others.
I noticed that the Marklin LED strips have dual terminals, the Roco ones don’t. I was just going to solder 2 wires together, on one terminal - this should have the same effect right?
Eddie
Perth 🇦🇺
CS3+ & iTrain
Offline dominator
#8 Posted : 19 October 2022 03:33:24(UTC)
dominator
I used Marklin single contact couplers, a reel of LED strips, Bridge rectifiers and resistors in each coach, and one pickup shoe. Cant remember what size resistors I used but where I could, I used 1000 uf 50v capacitors.
At first the lights were too bright but higher resistance fixed that. I have the capability to run my coaches on either analogue or digital [ hence the 50v capacitors ].
Genuine stuff is quite expensive. You can even make your own conductors, by fitting a brass strip through where the pre-uncoupler would normally go. I even fitted conducting couplers on older coaches that were not designed for them.
All the best.
Northland. NZ
Offline Toosmall
#9 Posted : 19 October 2022 04:19:08(UTC)
Toosmall
Could you design an electrical connection using neodymium magnets for alignment.
I have used a few neodymium magnets for larger projects. They are brilliant. Be careful, they can guillotine fingers.
If you can have some surface contacts that self align. A pair of magnets will hold them together.
Offline Eddie7979
#10 Posted : 19 October 2022 04:44:51(UTC)
Eddie7979
All the best.
Totally agree with you, I guess I’m not too confident in my abilities to solder and being able to retrofitting lighting / couplers. Once I build some experience and skills, I will try using different ways.
Thank you for sharing this information, I’m keeping all this for future references and learning a lot!
Eddie
Perth 🇦🇺
CS3+ & iTrain
Offline Eddie7979
#11 Posted : 19 October 2022 04:58:30(UTC)
Eddie7979
Hey,
Actually, I was looking at doing something like this. Since I will be adding a buffet car from LS Models in the future, having the self alignment would be really practical.
The one I had my eye on is made by REE Modeles, I believe they come with different lengths as well which will be handy with avoiding derailments on short curves.
https://www.jb-webshop.d...s/XB933&Locale=en_GB
Which ones have you used, if you don’t mind me asking?
Eddie
Perth 🇦🇺
CS3+ & iTrain
#12 Posted : 19 October 2022 06:46:01(UTC)
This appears in the instructions for many Roco 1/87 coaches
The original can be downloaded here: https://www.roco.cc/rde/...ssraumwagen-der-sbb.html
The part which they say should replace the original plastic base for the slider is no longer included with the models. It may still be possible to find online or at parts sources
Once you have swapped the part, you can glue the slider to the bottom of the bogie and the two pins will secure it in place.
Offline Crazy Harry
#13 Posted : 19 October 2022 17:59:36(UTC)
Crazy Harry
All the best.
Derek,
Could you provide a sketch of what you did? What current are the single contact couplers carrying? If it is from the single slider why does each coach need its own rectifier and resistors? Thanks in advance for your clarification.
Harold.
Offline Eddie7979
#14 Posted : 20 October 2022 01:44:16(UTC)
Eddie7979
Hi Mike,
This was something that stopped me from buying any Roco passenger coaches and couldn’t really understand why Roco would recommend a part that they no longer supply.
However, I asked about conversion of Roco coaches to AC in the following post:
The photos posted by the good Marklin community on this forum shows that the spacer may not be needed in the modern coaches.
I made a decision to just take a risk and order the coaches and then see how it goes. I think the bogeys and slider might have been redesigned to prevent it from twisting, meaning there is no need for the spacer perhaps…
One thing is for sure, the slider screws into the bogey. Not sure if the screw is supplied or the size - that remains to be seen!
The Roco coaches are on pre-order so it might be a while until I receive them. I’ll be sure to post photos and talk about any success or problems I encounter for others to learn from.
Eddie
Perth 🇦🇺
CS3+ & iTrain
thanks 1 user liked this useful post by Eddie7979
This page was generated in 0.391 seconds.
