Offline rytter
#1 Posted : 15 October 2022 17:04:12(UTC)
rytter
I have bought a Märklin Decoder Programmer 60971 for programming mLD/3 and mSD/3 decoders, I am using a 6021 for my layout so I thought this would be a lot easier to program with.
I have a problem with it though, when I put a decoder on the 21MTC interface, the decoder software registers the decoder, and I can program it just fine.
When I however connect a decoder with the NEM652 interface I get a "Decoder doesnt respond" error (I am using decoders 60983 link for my small trains).
The trains with the 60983 decoders are working just fine on the track with functions and all, and I can program them with my 6021. But for all intents it should be working with the decoder programmer also.
I have asked Märklin customer support, but havent heard back yet. Is there anyone here who has experienced the same error or knows what I am doing wrong?
#2 Posted : 15 October 2022 18:17:33(UTC)
What you describe shows (I think)
- the decoder programmer is working fine
- chances are the issue is with the NEM 652 compliance issue
60971 Users manual https://static.maerklin....58bf7728441660728698.pdf
Märklin version of NEM 652 here - pages 28 and 29 https://static.maerklin....fbd9de85621663856176.pdf
One possibility (but you may not like it) use the direct wiring connection (4 wires):
Pin d Connection for the red and the black decoder wire (AUX1 output)
Pin e Connection for the blue decoder wire (orange marking) IN1
Pin f Connection for the blue decoder wire (yellow marking) IN2
Pin g Connection for the blue decoder wire (black marking) GND
I cannot help more because I program my mSD3 directly with a CS2 or CS3, using only 2 wires: GND and B (Slider)
Offline dickinsonj
#3 Posted : 16 October 2022 01:13:35(UTC)
I have had several similar instances, where my CS2 and CS3 could make changes to a decoder but where my Decoder Programmer failed to read the chip.
I (as a software guy) just assumed that it was a software error. BigGrin
I am hoping that it has been or will be fixed in a future update. ThumpUp
Offline ktsolias
#4 Posted : 19 October 2022 13:57:17(UTC)
ktsolias
In any case you have to connect the black and red wire together to the first screw (ws + sw).
Otherwise is not working is a problem of the programmer PCB desing.
Working fine with 21MTC
Costas
Offline maruju
#5 Posted : 20 October 2022 02:28:39(UTC)
maruju
Japan
I also ran into the same problem with the 60971 not recognizing the 8pin decoder.
With ESU's Lokprogrammer, even an 8-pin decoder can be recognized just by pointing to the pin, so I thought the 60971 was the same.
Looking at pages 18 and 19 of the 60971 manual, it says to connect the color wires in addition to the pin connections.
It was recognized when connected according to the manual.
I hope this solves it.
thanks 1 user liked this useful post by maruju
Offline rytter
#6 Posted : 26 October 2022 22:49:31(UTC)
rytter
So it does say, that is what I get for not reading the manual thoroughly. I unfortunately cut the excessive wires from the decoder so I will have to try and solder a new and see if it works then.
Thanks for the sharp observation :)
Decoder programmer (Digital)
by Mjn2ts 21/03/2025 01:21:10(UTC)
60971 Decoder programmer (Digital)
by Mjn2ts 12/03/2025 21:47:58(UTC)
Decoder programmer 60917, Roco motors (Digital components and Software reviews)
by digana 16/12/2019 21:47:22(UTC)
decoder programmer 60971 (Digital)
by 3gleise 31/10/2018 22:26:16(UTC)
How easy or difficult or user friendly is the Märklin Decoder programmer ? (Digital)
by river6109 18/04/2018 03:54:46(UTC)
Marklin 60971 Decoder Programmer and mDT3 software (Digital)
by BrandonVA 21/09/2015 20:09:29(UTC)
This page was generated in 0.303 seconds.
