Offline Rolando
#1 Posted : 07 September 2022 13:08:56(UTC)
Rolando
Hi everyone.
My friend has a CS2 . It is problem with the starting up.
It will not start after a shutdown , he has to wait at least one hour.
Sometimes one hour is not enough , then he wait a couple of hours more.
If he is lucky it starts........
Sometimes he has to try with starting up to 10 times.
I suspect there is something wrong with the unit , but what can it be ??
He has the latest version 4.3.0 (5)
Has anyone met this problem with a CS2 ??
Kind regards
Roland in Sweden
#2 Posted : 07 September 2022 13:32:45(UTC)
Originally Posted by: Rolando Go to Quoted Post
Hi everyone.
Kind regards
Roland in Sweden
This sounds like an electronic fault, I suspect the only remedy will be to send it back to Marklin.
However there are a couple of questions to ask first ...
Does the stop bar light up when powered on? It normally does some flashing while the system boots up.
Does the display light up?
Does it get as far as showing the progress bar on the display as it boots up?
There is the possibility of a bad solder joint on the power connector. Does wriggling the connector change how long it takes to power up. Once it is powered up does wriggling the power connector change the display.
There is also the possibility that the problem is the power supply. Have you tried it with another power supply?
This is probably the more likely problem than the above items, and I would suggest trying another power supply first.
Offline Rolando
#3 Posted : 07 September 2022 14:25:19(UTC)
Rolando
The lightenings of the stop bar and display seems to be Ok. We will try with wriggling The Power connector and also try with another Power unit.
Regards from Roland
#4 Posted : 07 September 2022 14:44:14(UTC)
You have been a member since:: 04/02/2011(UTC)
Hi Roland
I have two CS2 and one of them is now refusing to start: the start screen is displayed and the progress bar, instead of stopping near the middle is going all the way and nothing happens.
It happened to me before and I got out by trying many many times to start it near my internet box and when the start was successful I had it call for an update.
It solved the problem for a few month but now it refuses to start.
I know many CS2 are dying that way and no one in Germany seems to have answers.
PS my other CS2 is working fine EXCEPT both the main and programming track outputs are dead.
To be honest this is after 10 years of good service. I have now a CS3
Send the CS2 to Germany? I checked, Märklin does not repair them but offer a "discount" for the purchase of a CS3.
The discount in question is less than ordering from a German shop and having it sent to France so I ordered from MSL (Lippe)
#5 Posted : 10 September 2022 23:33:34(UTC)
I had my CS2 for 10 years when it just would not start. Tried various things but nothing worked and like Jean I now have CS3.
I reckon that 10 years trouble free was OK but not sure why it just gave up. CS3 is fine and going well.
#6 Posted : 11 September 2022 01:15:17(UTC)
I was thinking about this the other day (after I made my posting above) and I suspect the NAND FLASH chip used for the 'disk drive' is getting excessive errors. While there is a certain amount of spare space in the chip to counter this happening, along with an error correction process, i think the chip just gets too many errors for the system to be able to boot reliably. Sadly the only way to correct this problem will be to replace the chip, but then the problem is how to load the program image onto the chip (it is not as simple as doing another update, which relies on already having a program image on the chip).
The process is similar to when a PC gets disk errors.
#7 Posted : 11 September 2022 12:59:58(UTC)
Interesting Alan and could well be right. Hopefully my now three year old CS3 will keep going.
Offline bph
#8 Posted : 11 September 2022 13:14:55(UTC)
You are probably spot on.
have experienced "similar" failures with other types of systems/instruments, where the flash drive fails. sometimes even quite premature, at and of course at the worst possible timing.
Märklin CS2.exe (Model railroad software)
by w4sepp 09/11/2022 10:44:12(UTC)
Märklin CS2 (Digital)
by Rolando 24/08/2022 10:11:46(UTC)
Märklin CS2 is loading, loading, loading but not starting? (Digital)
by jaakkomu 11/02/2021 19:27:06(UTC)
Märklin CS2 60214 software update from old version 2.43 (Digital)
by Janne75 06/03/2020 20:47:49(UTC)
Märklin MobileStation vs. RemoteCS2 - Android Apps for Märklin CS2/CS3/MS2 (Model railroad software)
by Moritz-BR365 09/08/2016 14:26:16(UTC)
Märklin CS2 Programming (Digital)
by Onkenhout 23/10/2015 04:25:13(UTC)
Märklin CS2 Programing (Digital)
by willydvs 10/11/2014 06:54:43(UTC)
Märklin CS2 App and Android (Digital)
by Armando 07/11/2012 22:18:38(UTC)
This page was generated in 0.362 seconds.
