2 Pages12>
Offline Mr. Ron
#1 Posted : 13 August 2022 19:48:50(UTC)
Mr. Ron
I notice some people refer to Marklin trains as 3 rail. This is incorrect. Marklin and even Lionel for that matter run on 2 rails just the same as any other rail system. The "3rd rail" isn't a rail at all, but a power pickup. It can resemble a rail like Lionel, but Marklin track has a thin bar (old Marklin track) and studs (modern track) that is referred to as a 3rd rail. Marklin track should be referred to as 2 rail with a center contact. There have been 2 rail systems with center contact in use in parts of the world. One is in the UK and another I believe in India. Many rail lines in the U.S. use an outside 3rd rail, but only 2 rails are used for the trail's wheels. This may seem a silly argument, but it just popped up out of curiosity.
thanks 1 user liked this useful post by Mr. Ron
Offline Rwill
#2 Posted : 13 August 2022 21:43:48(UTC)
Rwill
I believe you are wrong in your semantics.
As a south Londoner I never knew growing up there was anything other than three rail:
https://www.networkrail....ailway/track/third-rail/
And the third rail is outside the two rail on which the driving wheels sit and there are miles and miles in this system
Then there is the London Underground also three rail with centre power track.
If you told a Londoner that his track should be referred to "as track which should be referred to as 2 rail with a center contact" He would think you have gone loopy and the red indicates says you cant even spell centre. WE can get into discussion -2 rail /3 rail. AC or DC but why bother we all know what we are referring to.
Offline Copenhagen
#3 Posted : 13 August 2022 21:50:10(UTC)
Copenhagen
In Danish there is a tradition of calling DC 2 track and AC 3 track (track = "skinne" in Danish. So 2-skinne and 3-skinne).
Offline artfull dodger
#4 Posted : 13 August 2022 21:56:12(UTC)
artfull dodger
I also disagree in the semantics. Lionel track is 3 rails as there are 3 actual rails on the track. Early Marklin and even Hornby Dublo HO track had 3 solid rails on them. Current Marklin is 2 rails with center stud contact with its "rail" portion hidden below in the road bed out of sight. To me the "3 rail" set up be it a solid rail or stud contact is much easier to work with from an electrical standpoint, no reverse loop issues as seen with a true 2 rail set up. But its still 3 rail track when it comes down to brass tacks.
#5 Posted : 13 August 2022 23:38:00(UTC)
3 rail is easy to say and not complicated and therefore I will continue to use it.
Offline dickinsonj
#6 Posted : 14 August 2022 00:53:04(UTC)
I agree David.
I see 3 rail as a higher level concept, meaning a third power element is used, even if there are only two physical rails.
#7 Posted : 15 August 2022 06:21:51(UTC)
Both 2 and 3 rail have same power feeder. Two rail are when you feed plus and minus to the rail. Three rail are when you feed minus to the rail and plus to the stud contact.
Offline Copenhagen
#8 Posted : 15 August 2022 09:22:37(UTC)
Copenhagen
Another incorrect post by Goofy BigGrin
#9 Posted : 15 August 2022 09:37:52(UTC)
What the f**k are you talking about!??? 🤬🤬🤬
#10 Posted : 15 August 2022 10:24:23(UTC)
So, you mean to tell me that our Club's magazine 'The 3rd Railer' is completely wrong even though it has been called that for nearly 50 years.
Imagine if it was called 'The Thin Bar' or 'The Studs', it just doesn't have that ring about it.
I'll stick with 'The 3rd Railer'!
#11 Posted : 15 August 2022 12:24:02(UTC)
I watched this topic in bewilderment.
How can we become pedandic and so disconnected of simple thing as if some people just woke up after a 100 years sleep like the "Belle au bois dormant".
For many simple and stupid people like me, 3 rails, the root of our hobby (started around 1900) means
- central rail / stud power feed, usually 16 VAC
- for many years an AC power feed
Two rails as started by Fleischmann around 1953 (I think) means
- normal rails insulated from each other, mounted on "Presspahn" (sort of carton) and then on plastic
- for many years on DC power feed
And yes there are exceptions all over the place
- power may come from the mains with carbon lamps in series to reduce the voltage 110V or 220 V AC or DC
- accumulator operation since around 1910 low voltage (approx 4V) but quite dangerous because of the toxic "liquid"
- DC operation in 3 rails (like here in France with brands like JEP)
- of course studs replacing the central rail
- side rails replacing central rail like early VB here in France.
- of course, digital replacing AC or DC operation
Mainiature train is supposed to be fun. Please lets have fun and I hope I haven't offended anyone
thanks 10 users liked this useful post by JohnjeanB
#12 Posted : 15 August 2022 15:15:46(UTC)
Does it matter what you call something as long as we understand what is and to what we are talking about. Marklin is known as the three rail system by those who use it and by those who do not. Hornby users here call their system two rail even if at one time it was three. It appears that most or all in our hobby understand the meaning of two or three rail as it is today so no need to complicate matters.
Offline Mr. Ron
#13 Posted : 15 August 2022 15:18:21(UTC)
Mr. Ron
I think when people refer to track as 3-rail, they think of it as a "toy" for children to play with. Not so with 2-rail. People who run Marklin or Lionel would be offended if they were accused of playing with trains. 2-rail vs 3-rail seems to be a sensitive term.
Offline PMPeter
#14 Posted : 15 August 2022 16:02:36(UTC)
PMPeter
In this case I have to agree with Goofy. What did he say wrong? The power feeder is the same in both systems having a positive and a negative. The difference is where you connect these 2 wires on a 3 rail and a 2 rail track. Perhaps his English could have been better by saying: Two rail are when you feed plus and minus to the rails. But hey, we all know his English is not the best and his message was clear enough
thanks 2 users liked this useful post by PMPeter
Offline Mr. Ron
#15 Posted : 15 August 2022 16:49:20(UTC)
Mr. Ron
What about the 4-rail system used on London underground that has an outside 3rd rail and an inside return rail? There are(were) several 4-rail lines used in the GB according to Wikipedia.
Offline Copenhagen
#16 Posted : 15 August 2022 17:26:55(UTC)
Copenhagen
If you run DCC the two wires are not plus and minus. The same if you run analog AC.
#17 Posted : 15 August 2022 18:07:38(UTC)
A picture.
Offline PMPeter
#18 Posted : 15 August 2022 18:18:33(UTC)
PMPeter
Good grief. I can see this spiraling down the rabbit hole again. Perhaps instead of using +ve and -ve we should be using Maerklin's B and O or red and brown wires.
Offline Copenhagen
#19 Posted : 15 August 2022 18:49:18(UTC)
Copenhagen
So true. Even Goofy's photo shows his goofs.
Offline Toosmall
#20 Posted : 15 August 2022 19:31:41(UTC)
Toosmall
When trains go the other direction.
Offline Mr. Ron
#21 Posted : 15 August 2022 20:42:56(UTC)
Mr. Ron
Sorry I asked!
Offline Copenhagen
#22 Posted : 15 August 2022 21:03:35(UTC)
Copenhagen
Sorry I asked!
No need to be sorry. It was an honest question in my opinion.
#23 Posted : 15 August 2022 22:48:24(UTC)
Bryan
I agree also, the initial point about 3-rail is very valid. It also keeps us entertained here without getting serious.
To me the3-rail term is the same as calling Marklin, Digital. The major digital system is DCC. Marklin is MFX. This does not mean Marklin is not digital because it uses MFX.
The term 3-rail really means, 3 points of electrical contact for locomotives to run via the track. The third rail can mean, outside rail as in the UK prototype, middle rail, middle contact etc. 3-rail is a generic term for 3 electrical pickup points, AND THE BEST SYSTEM for electrical transmission for conductivity.
David
#24 Posted : 16 August 2022 06:28:46(UTC)
B and O are plus and minus. It’s same connection by feed the tracks. DC or AC whatever. Simple same way for the digital. Märklin tracks are two rail with stud contact. I believe Märklinist will start scream like coffee aunties now? 😂😂😂
#25 Posted : 16 August 2022 06:32:03(UTC)
David
In fact NO!! Märklin do only have two electrical pickup points because both rail equal as one electrical point.
Both rail works like redirection.
#26 Posted : 16 August 2022 07:54:38(UTC)
What happens if a 3-rail track identifies itself as a 2-rail track? RollEyes
Offline Mark5
#27 Posted : 16 August 2022 08:31:03(UTC)
Mark5
"We" must be bored.
I have to say I really admire Goofy's ability to take so much flack from dissenters.
Thanks for all your feedback Goofy. The forum would not be the same without you.
As we say "Water off a duck's back". Do you have that expression too?
I kind of like using the old minus and plus myself and find it a handy way to think of flow, even if it alternates. It helps to stay well grounded. Cool
thanks 2 users liked this useful post by Mark5
Offline Copenhagen
#28 Posted : 16 August 2022 09:54:22(UTC)
Copenhagen
I see no reason to praise Goofy. Again and again he says things that can lead people down the wrong track(!). This thread is no exception.
#29 Posted : 16 August 2022 12:35:57(UTC)
The aliens skipped this planet, as there was no sign of intelligent life...
#30 Posted : 16 August 2022 13:44:33(UTC)
I think it's partially a language barrier, and Goofy has his own way of transfering thought to words. I.E., by both outer rails working as a redirection, he means in essence that the reverse loop short is eliminated. Yes, there are still two wire connections with 3 rail as he said. Positive, and negative. Some think in an analytical dimension, and some in a quantative.
It doesn't mean one of us is smarter. Some are bettetr at math, some at language and spelling for example. Some are better with shapes, some with numbers. I think people better with shapes may be more artistic, and those with numbers more statistical. Those good at both, may be more likely to be engineers.
But I agree about the aliens. As in how mankind gets along with ourselves. Always the desire for control or power over others.
#31 Posted : 16 August 2022 16:48:38(UTC)
It finds that is not the point ??? Blink Blushing Crying LOL
Offline Copenhagen
#32 Posted : 16 August 2022 17:05:53(UTC)
Copenhagen
I hope we can remain positive and avoid negativity as much as possible. After all this is a forum for our beloved hobby. Smile
thanks 2 users liked this useful post by Copenhagen
#33 Posted : 16 August 2022 17:10:13(UTC)
I like Goofy. As a member here for years he keeps us going even if it can lead down the wrong road. Some of what he says here is correct and some wrong but I always read a Goofy thread just for all the fun it can bring.
thanks 5 users liked this useful post by David Dewar
#34 Posted : 16 August 2022 18:04:12(UTC)
I think some members are going off rail and some of us 3 rail enthusiasts are trying to keep the topic on track., another useless "word" topic
#35 Posted : 16 August 2022 20:09:48(UTC)
Another picture.
Offline Copenhagen
#36 Posted : 16 August 2022 20:41:42(UTC)
Copenhagen
Why the plus and minus signs when it's not DC?
#37 Posted : 16 August 2022 21:09:13(UTC)
Just regard them as instantaneous voltage on the AC sinewave or the digital signal.
that way the thread will die.
Offline ccranium
#38 Posted : 17 August 2022 02:30:19(UTC)
ccranium
Technically, AC doesn't have a + or - wire; the Marklin outer rails are the "neutral" and the center rail or studs, or the catenary wire are the "hot" or "energized" rail. The hot wire's voltage varies between + and - at the system's frequency (usually 60hz in the US).
#39 Posted : 17 August 2022 06:14:51(UTC)
Stud contact is not a rail! It’s differens. A rail is a rail. Märklin tracks are two rail with stud contact.
#40 Posted : 17 August 2022 06:17:36(UTC)
Plus and minus are DC power feed. You can simple too feed Märklin tracks this way.
Offline PacoM
#41 Posted : 17 August 2022 18:45:55(UTC)
PacoM
Entertaining but useless. None of us will change the short and simple names fans all over the world use to describe the two physically apparent ways by which model trains pick up electricity (and data).
thanks 3 users liked this useful post by PacoM
#42 Posted : 17 August 2022 22:21:38(UTC)
No the topic is very interested because Märklinist do have hard to understand what are Märklin track.
Märklin tracks is not three rail because there is only two rail and stud contact.
Offline Copenhagen
#43 Posted : 17 August 2022 22:52:49(UTC)
Copenhagen
On Maerklin M and C track the studs are part of the third rail that is situated under the track bed. The third rail is the power rail.
On K track it's a bit harder to understand because the power rail is hidden in the sleepers to make the track look and feel like prototypical railway tracks.
Also read Rwill's #2 post in this thread.
Personally I don't care what you call it. Using the terms DC and AC for 2- and 3-rail, is probably better and easier - even though DC and AC is misleading when you run DCC.
#44 Posted : 17 August 2022 23:34:19(UTC)
For Goofy. Just think of the third rail being a normal rail but cut into small parts called studs. Thus Marklin has three rails. Most rails have wheels on them but Marklin also have a slider which you could say is a type of wheel making contact with the third rail (Stud)
Im off for a lie down.
#45 Posted : 18 August 2022 03:40:03(UTC)
How stupid of me: many, many years ago we had our layout for public viewing about 250km south of Perth (Western Australia) and we had a strange experience with one of our paying visitors: he entered the hall, paid the entry fee and than asked if the layout is 2 or 3 rail and my answer was 3 rail and he left apparently driving another 250km back to Perth,
I should have told him its 2 rail with studs in the middle.
#46 Posted : 18 August 2022 06:16:32(UTC)
No! There is no third rail. The stud contact is not a rail. Stud contact on the Märklin tracks are B or + if you so like can call it, but never ever as rail. It’s difference. A rail is a rail and nothing else.
#47 Posted : 18 August 2022 06:22:01(UTC)
Stud contact is not a rail. It is a power feeder for the pick up shoes. Rail is a transport or support for the wheels. Rail works as power feeder too. We can call it + and-. Even to write B and O.
Offline Copenhagen
#48 Posted : 18 August 2022 08:46:26(UTC)
Copenhagen
As mentioned before it is a correct and established fact that it can be a rail even without any wheel touching it. Like the British third rail and the Märklin 3600 type track where there is a solid center rail. The Copenhagen Metro also has three rails, two for the wheels and one for the for the pickup shoe.
(Added later for clarification:) As we now have established the fact that a rail can be a solid metal power line it logically follows that even if we put the rail out of sight (as with C track and later M track) but make sure that the power from it can be accessed via parts of the rail protruding through the track bed so that the pickup shoes can receive power, then it is still a rail even though it is more or less hidden.
I don't see anybody using + and - when dealing with Märklin AC and DCC.
#49 Posted : 18 August 2022 11:30:23(UTC)
This is getting a bit out of hand - there's an old saying quite relevant here. "If it ain't broke, don't fix it". The term '3-rail' has become synonymous with Märklin in particular, but can also be used with regard to Lionel, Trix, Hornby-Dublo among others.
As is well known in English, and other languages, one word can have different meanings. 3-rail of course goes back to the early systems where there were 3 actual "rails", two of which were used to guide the wheels and the third for power delivery.
It's a term that has carried over for decades and many people are quite comfortable using the informal term 3-rail as a very easy description of the system. Anyone who doesn't like it is free to use their own description but ridicule of the informal use by others has no place in a gentleman's hobby.
The specific use of the word 'rail' also has electrical accuracy - https://en.wikipedia.org/wiki/Third_rail
#50 Posted : 18 August 2022 13:29:27(UTC)
As a person involved with electronics for over 50 years, i have probably used the term 'rail' to apply to a power rail (even if it is a line on a schematic circuit) more times than I have referred to marklin as using '3 rail' track.
So having centre studs as a 'power rail' is quite legitimate in describing the track as three rail - especially when isolating one of the running rails to sense train occupation of a section.
So someone stick that in their pipe and smoke it. Time for a moderator to lock the thread methinks.
2 Pages12>
This page was generated in 1.264 seconds.
