Offline Michanglais
#1 Posted : 15 May 2022 10:02:45(UTC)
Michanglais
France, Metropolitan
I want to get a few yard lamps (72813) for a diorama I'm building.
I've got an old DC controller that could be used to vary the intensity of the light IF the LEDs are DC compatible. I don't know if AC-only LEDs exist and whether they would only work with a Marklin controller. I'm not keen on using a constant accessory power from my analogue AC controller as I suspect the LEDs will be too bright for my liking.
Has anyone got any thoughts on using DC to power this type of LED?
Many thanks in advance.
#2 Posted : 15 May 2022 12:05:25(UTC)
Hi Michel
What counts with LEDs is a DC power to avoid flickering.
Because, in the past I had a N scale analog layout, I have a few transformers and I use the variable DC part for lighting
So one possibility is to use a transfo. for DC trains with a M 84 to switch on and off.
On my steam depot I had Brawa lamps, beautiful but with regular bulbs that kept burning so I installed surface mounted LEDs from an adhesive LED tape and enameled thin copper wire for cabling. So it went like this
Offline Michanglais
#3 Posted : 15 May 2022 12:23:40(UTC)
Michanglais
That's great news, thanks Jean.
I have a perfect DC transfo I don't use any more with two outlets - just what I need.
Nice depot on the layout!
Michael
thanks 1 user liked this useful post by Michanglais
Offline nzrailfan
#4 Posted : 10 June 2022 09:31:03(UTC)
nzrailfan
Hi , the easiest, cheapest and most overlooked way (in my opinion) is a second hand laptop power supply , I have a 15v unit rated at 4A and a 19v unit rated at 4.6A running my ESU switchpilots switching my K-Track point motors Viessmann Signals and yard lamps. Paid about $10 NZD for each.
thanks 2 users liked this useful post by nzrailfan
This page was generated in 0.410 seconds.
