Offline Mr. Ron
#1 Posted : 28 March 2022 09:50:57(UTC)
Mr. Ron
Views messages in topic : 326
I have noticed on many layouts; S-curves are used when a straight line or smooth curve could be used. Is this to add interest? It causes an un-natural look especially in trains pulling long passenger cars. The S-curve causes un-real overhang as the car transits and reverses in the curve.
Offline rmsailor
#2 Posted : 28 March 2022 12:10:48(UTC)
rmsailor
A long S-curve can add scenic interest to a layout rather than a dead straight but as you say it looks unnatural when the ends of cars get badly our of line. If you have to use sharp curves even a short straight between them or if you are looking at a crossover between two tracks, can you use curved points so there is no reverse curve so stock looks better.
On a previous layout I had a reverse curve where coaches fitted with Roco short couplings, which are similar but not identical to Marklin ones, would invariably uncouple as the coacxh ends would pull sideways in opposite directions.
Bob M.
#3 Posted : 28 March 2022 14:41:50(UTC)
Hi Ron
S curves are nice with large radii. They are not allowed in R1 as Märklin does not test nor guarantee this operation. The smallest allowed radius is R2.
In R1 you must have a straight track between the curves.
S curve operation is very unattractive when using small radii as long passenger cars are totally out of alignment and short coupling mechanisms are at or beyond their operating angles.
Offline rbw993
#4 Posted : 28 March 2022 14:50:05(UTC)
rbw993
All model railroad curves are too small in radius except maybe on some giant layouts. Small layouts require small radii but I agree an unnecessary S curve is visually and operationally not a good idea. A good rule of thumb is to use tighter curves where you only view the train from inside the curve. The distance between cars will still look okay.
Roger
thanks 3 users liked this useful post by rbw993
Offline Copenhagen
#5 Posted : 28 March 2022 15:30:05(UTC)
Copenhagen
I have an S curve without any straight track in between on my "mountain" station about 12 centimeters (5 inches) above the main layout. It's a reverse loop (with R1 C tracks) so the trains go up and down on the same track. It doesn't give me any problems with Maerklin cars and locomotives and also not locomotives from Piko, Roco and ESU. With other brands of locos and cars I've sometimes been forced to make adjustments and take precautions not to get derailments.
Ideally I should rework the section in a future project.
#6 Posted : 28 March 2022 18:31:01(UTC)
S curves pose problems on long cars with the needed angle on the coupling that may exceed the permitted angle
Offline Toosmall
#7 Posted : 28 March 2022 21:46:37(UTC)
Toosmall
I have an S Bend on my layout, but it is subtle & looks good. It is a mountain scene.
thanks 8 users liked this useful post by Toosmall
Offline Mr. Ron
#8 Posted : 28 March 2022 23:14:03(UTC)
Mr. Ron
It looks like you have some straight section in between the curved track.
thanks 1 user liked this useful post by Mr. Ron
Offline dominator
#9 Posted : 29 March 2022 00:35:09(UTC)
dominator
When I was about 8 years old, I used to love lying down watching the 50's coaches negotiating my 5117 points. Didnt know any difference then but it was fun.
thanks 2 users liked this useful post by dominator
Offline Toosmall
#10 Posted : 29 March 2022 01:18:27(UTC)
Toosmall
If you have the room have a variable rate of change, it looks better. So large radius, tight radius, large radius, straight, reverse large radius, reverse tight radius, reverse large radius.
Knock up a test section and manually push your longest carriages through to see what overhang you are prepared to live with.
Offline rschaffr
#11 Posted : 31 March 2022 02:11:00(UTC)
rschaffr
I have a very gentle S curve on my "West River" section but I used flex track to get the effect I wanted.wriv20.jpg
-Ron
thanks 3 users liked this useful post by rschaffr
Offline Mr. Ron
#12 Posted : 31 March 2022 06:37:22(UTC)
Mr. Ron
I imagine railroads lay track in as straight a line as possible as curves increase the cost of building. There are stretches of track in Australia that are straight for almost 300 miles
Offline Toosmall
#13 Posted : 31 March 2022 08:35:59(UTC)
Toosmall
Then there are more long straight bits after slight kinks in the track. The same with our longest straight road, after slight kinks then there are more straight bits.
I think something has to give, even in Z gauge!
#14 Posted : 31 March 2022 17:47:31(UTC)
Well, one stretch of single track that I am aware of, across the Nullabor Plain. I don't think there is any other single straight stretch that approaches that length.
#15 Posted : 02 April 2022 11:05:59(UTC)
A long S-curv are far better than short S-curv because of the train length.
In fact does short train set fit better for the short S-curv.
In the real world prototype does narrow gauge trains work good with the short S-curv.
It´s all matter about train models.
Short wagons are excellent for the short S-curv.
It also depend of the layouts size in the room.
What you need is to test and practice.
Offline Toosmall
#16 Posted : 02 April 2022 12:22:16(UTC)
Toosmall
Actually the Nullarbor is very short, the scenery changes very quickly. The road is closer to the coast. In 2019 I drove from Sydney to Perth to pick other half up from the airport flying in from Germany. We wanted to continue our trip around the block from the previous year.
We have done part of the Indian Pacific & then the Gahn. As the trains travel through the night you miss out seeing half the trip's scenery.
One of the views you don't get from the train:
I reckon that with a bit of artistic licence it would be worth shifting the railway line a touch closer to the coast on a model.
Offline PeFu
#17 Posted : 02 April 2022 13:01:31(UTC)
PeFu
S-curve in uppercase RollEyes
thanks 3 users liked this useful post by PeFu
Offline Toosmall
#18 Posted : 02 April 2022 14:31:53(UTC)
Toosmall
I had to put an S curve in because there was a road in the way!
Offline Mr. Ron
#19 Posted : 02 April 2022 18:03:04(UTC)
Mr. Ron
In your case, an S curve was necessary in order to incorporate a return loop without crossing the road. The only places where I have seen S curves is where a rail line follows a river, as on the Rio Grande and Hudson river NY central track. As I said, railroads avoid S curves where possible due to cost. On a model railroad, it adds interest.
thanks 2 users liked this useful post by Mr. Ron
Offline Mr. Ron
#20 Posted : 02 April 2022 18:06:25(UTC)
Mr. Ron
Sidney to Perth; that is quite a trip.
Offline Toosmall
#21 Posted : 03 April 2022 02:05:15(UTC)
Toosmall
Have a look at the satellite view of the railway line through the Blue Mountains west of Sydney. It is constant S bends, plus tunnels. I have travelled this line a handful of times.
Originally it had a zig zag line to get over the Blue Mountains.
https://en.m.wikipedia.o...wiki/Blue_Mountains_Line
West of the Blue Mountains is a miserably cold place, not the hugh minus temperatures that other countries get, but the damp wet cold to the bones, which runs all the way up on the west side of the Great Dividing Range up to and into southern Queensland at times. Yes, snow in Queensland. God's own country, 'sunshine one day, perfect the next' as Queenslanders say.
The western line out of Sydney has some great little stations, you ask for the train to stop at the minor stations & on the station you flag the train down. This is the only main line west out of Sydney.
Blayney is a lovely little station in a miserably cold place which will freeze the nuts off a brass monkey.
The line through the this area is full of S bends. You have to put yourself into a meditative state or you will go mental if you are impatient.
I actually went from Sydney to Orange to look at out current new car, 268km one way. I jokingly said to the car dealer that Sydney to Dubai return is quicker. Went back to Orange a few weeks later to pick up the new car.
But at the end of the day all these S bends make this trip very slow. Electric trains stop at Bathurst, almost as cold!
Offline PeFu
#22 Posted : 03 April 2022 18:35:49(UTC)
PeFu
I would say S-curves in the prototype are pretty common wherever you have a challenging landscape with water and/or mountains. In the pic below (from the Degermyr–Vännäs line in northern Sweden), the S-curve is applied for managing a climb to a higher elevation.
Offline Mman
#23 Posted : 03 April 2022 19:05:51(UTC)
Mman
The Portsmouth Direct line between Guildford and Havant in Southern England is all reverse curves because it was cheaper to build it that way to traverse the hilly terrain. After Guildford it has one tunnel, South of Petersfield, which is ‘S’ shaped as well. It came later than the main round of railway building when improved locos could cope with curves and gradients, nevertheless this (electrified) route has line speeds of 70 to 85 mph today and plenty of flange lubricators to reduce wear on the high rails. If you stand in the corridor connection between two coaches it can be quite alarming as the coaches suddenly move away from each other laterally and then line up again only to violently move away in opposite directions.
ChrisG
Offline BenP
#24 Posted : 03 April 2022 20:29:12(UTC)
BenP
The dreaded S curve. Need them to connect 2 panels and keep access. Lower S curves combine R1 and R2 track, so newer (close) couplers work. Upper (metal) overpass comes only in R1 radius, but works with older (relex) couplers; not suitable for extra long cars and CCs.
Offline Mr. Ron
#25 Posted : 03 April 2022 20:38:25(UTC)
Mr. Ron
Let me correct myself. S-curves may be necessary depending on the terrain. Although it may be cheaper to lay straight track it may not be cost effective to straighten out terrain. It all has to be at a case-by-case basis which I'm sure railroad executives are well aware of. On my layout, I'm using M-track which has pretty tight curves. S-curves look bad using M-track. Adding a straight section of track between reversing curve tracks helps minimize the excessive overhang.
Offline Toosmall
#26 Posted : 04 April 2022 04:46:21(UTC)
Toosmall
If you can't do S bends an alternative is a Z, somewhere I have heard of Z failures everywhere!
Plenty of videos on the internet of the only Z system which still functions!
https://en.m.wikipedia.org/wiki/Zig_Zag_Railway
Zig Zag Railway is an Australian heritage railway, situated near the town of Lithgow in the state of New South Wales. It was opened by the not-for-profit Zig Zag Railway Co-op. Ltd. as an unpaid volunteer-staffed heritage railway in October 1975, using the alignment of the Lithgow Zig Zag line that formed part of the Main Western line between 1869 and 1910. The line climbs the western flank of the Blue Mountains, using railway zig zags to gain height.
Offline Toosmall
#27 Posted : 04 April 2022 06:35:40(UTC)
Toosmall
I believe every layout needs a bit of straight track & a few S bends to look better than your mistress (as a boat moored near us is call 'Mistress Again', when they sail her on the weekend they give her a good hammering and score medals!)
Even better, add a few S bend roads, it looks good and roads are easy to spray out of 150ml touch up cans with grey, white and black pre heated, pre mask the white road markings with Letraset if you can still get it or finely cut masking tape.
Z gauge:
Offline Mr. Ron
#28 Posted : 04 April 2022 19:38:07(UTC)
Mr. Ron
I agree with S-curves as they add interest, but on a small layout, the abrupt change creates an un-natural overhang of long cars. Super large layouts can afford to use large radius curves, but on small layouts we are confined to tight radius curves. On European layouts, the 4-wheel short wagons take S-curves better than long 2-truck passenger cars.
Offline Mark5
#29 Posted : 19 April 2022 17:03:25(UTC)
Mark5
What a great topic when applied to model railroading!!
Functional, technical issues versus aesthetic choices...
If you want to have pure ovals and straight track that is your choice and they have great interest such as above posts. So many personal choices and for good reasons all on our own. HOWEVER... when what I call "MMRIP" is in play, (Miniature Model Railroading Infinite Possibilities and then Rest in Peace) the S-curve is a staple issue in the world of Art and we would have to argue with masters of ancient Greek sculpture to do away with it. Praxiteles himself was a fan. If you want to get fancy you could tell complainers that you have a thing for "contrapposto" and it will make your layout a bit more sexy. In my view the invention of flex track was a gift to landscape creativity on MMR layouts. Gently weighted tilted hips in sculpture is also seen in landscape, it slows down the eye and invokes desire. And don't tell me that anyone here does not love trains! XD
Here are few short accessible articles on the subject. I like this one on painting because I always think of the overall landscape of the layout as a kind of painting.
She quotes William Hogarth definition of the curve; “[A] Notion in compositional theory that objects arranged on an S-shaped line suggest grace and beauty.”
https://nancyreyner.com/2011/05/13/the-s-curve/
https://en.wikipedia.org/wiki/S-curve_(art)
A bunch more references here:
https://hyperleap.com/topic/S_Curve_(art)
Offline Mark5
#30 Posted : 19 April 2022 17:07:47(UTC)
Mark5
How would we drive through the Italian mountains without a few switchbacks and serpentine hill climbs?
Good shots Toosmall!
This page was generated in 0.786 seconds.
