Offline Hans Haupt
#1 Posted : 15 March 2022 16:38:01(UTC)
Hans Haupt
I have many passenger cars, running on a hybrid Digital and Analog voltage. I have many older locomotives that I cherish, and more digital loks I also like. therefore, I either run from a digital trafo or a analog (older style) trafo. The lights in the passenger cars flicker and I know installing a capacitor will act as a steady battery and the lights will not flicker anymore. What capacitors should I use, and how are they to be installed? Also, I use current conducting couplers...
Offline BenP
#2 Posted : 15 March 2022 16:55:40(UTC)
BenP
Parallel connect of small 470mF/25V capacitor. Shoe power (red) and wheel/wagon ground (black).
thanks 3 users liked this useful post by BenP
#3 Posted : 15 March 2022 17:10:22(UTC)
For analogue operation and reversing voltages, better pick a 50 V capacitor. A resistor that limits the inrush current and a diode are useful add-ons.
Only use capacitors for DC, i. e. behind a rectifier.
You probably mean 470 µF or 0.470 mF.
Long story short: difficult to recommend flicker protection without knowing what types of lights are installed.
Offline Hans Haupt
#4 Posted : 15 March 2022 17:20:39(UTC)
Hans Haupt
Many have LEDs, some I do not know, so will get both kinds. They are not very expensive. You mention a resistor and a diode, both seem useful. Any specs on those? and a schematic diagram would help as well. Thank You!
#5 Posted : 16 March 2022 00:45:42(UTC)
I found diagrams on German websites. I hope they help - along with automatic translation.
https://www.bahnjockel.de/pufferspeicher.html
https://www.1001-digital...trolyt-kondensatoren.php
The diagrams are from two-rail websites. As mentioned before, a 50 V capacitor should be able to handle the reversing voltage of analogue AC operation.
Offline BenP
#6 Posted : 16 March 2022 03:13:17(UTC)
BenP
Sorry, microF, not milliF. The typical AC reverse pulse may damage LED strips, which are usually wired for less than 20V, whereas reversing pulse is closer to 25V (newer white transformers) or even more (old blue transformers).
I use rectifier (and capacitor) for digital current from track to LEDS, but not for basic AC lighting of building with LEDs (powered by inexpensive 18V transformer).
thanks 2 users liked this useful post by BenP
Offline dominator
#7 Posted : 17 March 2022 07:53:32(UTC)
dominator
I used a pair of 50v 1000 uf capacitors in my tinplate carriages which operate on both analogue and digital by way of tiny bridge rectifiers. No flickering on a 5 coach consist with one pickup shoe and connections through 1.25 twin sockets. In my first conversion, i used one car as a master with the resistor and bridge supplying all other cars, but each car has2 of those capacitors. They are big, but I found smaller uf wasn't anywhere as good. If you fit them up under the roof, you cant really see them. I also used strip LEDs. On later plastic coaches with current carrying conductors, I started using capacitors, resistors and bridges in each coach. Only flicker with them was caused by the conductor couplings.
thanks 2 users liked this useful post by dominator
This page was generated in 0.455 seconds.
