Offline Toosmall
#1 Posted : 05 February 2022 02:57:37(UTC)
Toosmall
Trying to do my utmost to avoid actual work. Thought I would place my three ICE train sets in the station, first time. One set is very tired, the reason I bought spares. All three do need a grease and oil change.
ICE full length 14 car set running over bridge for those who haven't already seen it.
ICE.mov (2,462kb) downloaded 149 time(s).
thanks 12 users liked this useful post by Toosmall
Offline Zme
#2 Posted : 05 February 2022 05:07:36(UTC)
Zme
Hello. Hope all is well.
Fantastic ICE lineup. Impressive setup you have.
You know, when the ICE with the green strip on the locomotive comes out, you and I will need that one too.
Thanks for sharing.
Take good care.
Dwight
Offline Poor Skeleton
#3 Posted : 05 February 2022 13:07:58(UTC)
Poor Skeleton
All very impressive! Thanks for sharing!
All the best
Chris
Offline Toosmall
#4 Posted : 06 February 2022 11:03:04(UTC)
Toosmall
Thank you for the comments.
It was only when I reviewed the photos that I realised the shell of the ICE loco in the foreground was not down properly. Failing Z gauge eyesight! Those with a keen eye may have also noticed than on the same train set the loco at the far end, the pantograph is down. It's lost its spring, just forgotten where it is in storage, more senior issues! Another job on the to do list!
Anyway, a few more photos (85mm f22 & f1.4)
thanks 6 users liked this useful post by Toosmall
Offline Zme
#5 Posted : 07 February 2022 05:19:41(UTC)
Zme
Hello, hope all is well.
There is so much that I liked about your photos, I didn’t notice any issues. Your eyesight seems perfect.
Great layout you have! I like it very much.
I have been seeing the ICE Units with the green stripe in the front on YouTube videos. I suspect we will be seeing these as new models from Marklin at some point in the future. Here’s a sample. I have seen these on ICE 1 also.
The ICE Z Scale are fantastic models and an addiction easy to understand. Mine is the railbus, what an exact opposite to the ICE, go figure.
Thanks again. Take good care.
Dwight
Edited by user 08 February 2022 06:21:12(UTC)  | Reason: Added video
Offline Toosmall
#6 Posted : 07 February 2022 22:03:05(UTC)
Toosmall
I use a tripod to take photos. If you need the depth of field you don't have any choice. It is easier to use a tripod, then you can move the camera position a touch or move trains in the scene to suit the image. It is often just moving the camera a little bit can improve the image a lot. A tripod slows you down to think about the scene. I often use a sheet of white styrofoam to bounce some light into dark areas.
Operator view. There are 8 tracks in total at the rear. (29mm f11)
thanks 4 users liked this useful post by Toosmall
Offline Toosmall
#7 Posted : 09 February 2022 06:26:09(UTC)
Toosmall
A photo with my Canon S90 pocket camera pushed down under the catenary, had to correct perspective a bit. 4 identical stacked photos to reduce camera noise.
Only later noticed a bowed carriage. On the layout it is hard to see so not really an issue.
To make photographing things a bit easier the room is painted grey. Did this years ago for work, a "grey room" for colour correction. It works well with the layout.
Ceiling and wall colours.
Offline husafreak
#8 Posted : 09 February 2022 17:26:38(UTC)
husafreak
Wonderful layout, truly exemplary, also it is very impressive with those ICE trains lined up like that!
Zme, thanks for the video link. It looks like the cars will remain with the red stripes which is nice for us, we could get away with just changing the end cars. Marklin already has this set with the green stripes for HO scale. But looking at their HO cars is no way to predict what will be offered in Z! Also I recently saw pictures of an ICE train sporting a rainbow colored stripe in my Marklin literature, but I'm not home to find it and getting "blocked plug-in" on my Mac which I cannot get around...
Offline parakiet
#9 Posted : 12 February 2022 13:33:09(UTC)
parakiet
You could try a tilt&shift lense. Or connect your DSLR to an 'old' view camera.
Really fun to play with :)
thanks 2 users liked this useful post by parakiet
Offline Toosmall
#10 Posted : 13 February 2022 08:32:27(UTC)
Toosmall
I have a couple of Mamiya RZ67 "door stop" cameras & a 75mm shift lens, but it doesn't tilt. Great lens for architectural work.
Have a Toyo View 5x4" camera. The problem is I couldn't get the lens board working properly with any worthwhile movement with the wide angle lens needed. Even with a soft bellows it was not possible. Part of the issue is I would have to saw off the DSLR handgrip, actually saw off most of the camera, as it is in the way for mounting. You need to use a recessed board which makes the problem worse. The rear of the large format lenses are completely different to small format lens, they are big and get in the way.
Plan B:
So I knocked up a 316 stainless bracket for greater flexibility to mount the pocket camera on a platform with a bit of stability!
I have tapped holes in the Novaflex rails to screw on Manfrotto quick release plates. I can swap the rails, N/S E/W for greater flexibility. Also have a Manfrotto 131DB arm for further reach.
Manfrotto 161mk2 tripod and 400 head, about 13kg with rails with height up to about 3 metres, or another 600m with arm vertically. Just need a ladder at hand!
I also use a couple of Mamiya 645 lenses on the Canon from an adaptor I made from parts. The Canon half came off a dead 70-200mm zoom lens I found in a bin. The film plane distance could not have been more perfect. Saved machining, just had to tap some threads to screw the two together.
Offline Zme
#11 Posted : 17 February 2022 07:28:40(UTC)
Zme
Hello, hope all is well. Thought you might find this interesting.
I found a place where I “park” my ICE 3, when not in use. Also a string of freight wagons and v260 in the back.
This is a dealers advertising window display.
Take good care.
Dwight
Offline Toosmall
#12 Posted : 17 February 2022 08:05:54(UTC)
Toosmall
Nice display. The ICE 3 never did it for me. I liked the continuous look of the original. It has it's running issues out of the box, but a bit of wire across the diodes solves that problem. I also took out all the lighting parts to reduce weight. Didn't need the electrical connection the length of the train due to bypassing the diodes.
Older photos taken a decade ago, trees without dust! Train station layout module removed. I was 2 ICE cars short back then to make up three 6 car sets. 7 cars on a set will fit within the platform with station module but 6 cars looks nice.
Offline zoooctan
#13 Posted : 17 February 2022 11:08:26(UTC)
zoooctan
Singapore
I love the layout and the ability to run such long trains. Are you able to share with us your layout plan and dimensions? I noticed multiple levels. Are they connected? And is this all analogue or DCC?
Wonderful! Feel free to share more photos or videos!
Gavin
thanks 1 user liked this useful post by zoooctan
Zme
Offline Toosmall
#14 Posted : 17 February 2022 11:36:27(UTC)
Toosmall
There is information on the layout design in this thread:
https://www.marklin-user...rack-folded-dogbone-loop
Zme
Offline Zme
#15 Posted : 16 March 2022 03:08:03(UTC)
Zme
Hello.
Found this ICE 4 with German flag for the stripe:
Take good care.
Dwight
thanks 3 users liked this useful post by Zme
Offline husafreak
#16 Posted : 16 March 2022 03:46:18(UTC)
husafreak
Nice!
Zme
Offline parakiet
#17 Posted : 17 March 2022 19:04:57(UTC)
parakiet
Yesterday I saw one passing at Brussel-Centraal (Belgium), love those ICE trains :)
thanks 1 user liked this useful post by parakiet
Zme
#18 Posted : 17 March 2022 20:08:35(UTC)
Poor Skeleton
A couple of years ago I rode one from Brussels to Frankfurt. What surprised me was the very traditional wooden panelled interior - quite at odds with the futuristic exterior!
Chris
Zme
This page was generated in 0.910 seconds.
