Offline Willem99
#1 Posted : 25 January 2022 20:32:22(UTC)
Willem99
Views messages in topic : 124
Hi there,
I have two old Delta sets with steam locomotives, sets 2916 and 2964, both sets were purchased during the early 1990's.
Both steam locomotives have the digital address 78.
These Delta decoders do NOT have the DIP switches, so I can not just simply reset the dip switch.
Is there a way to program one of those to a different digital address (75) using my old 6021 control unit ?
Otherwise will I just have to live with it and make sure that both locomotives are not running at the same time ?
Both of these locomotives are fairly cheap, so I really do not want to go through the expense of buying a new decoder, besides, I have no clue how to do that.
Thanks for the help
Tim
#2 Posted : 25 January 2022 20:48:06(UTC)
Originally Posted by: Willem99 Go to Quoted Post
Hi there,
Thanks for the help
Tim
Yes you can. I don't have the instructions handy for doing this with a 6021, but it is certainly possible to do it. It is a bit of a hassle though, if you know someone with an ms2 or cs it will be easier to use that.
Offline Willem99
#3 Posted : 25 January 2022 20:52:21(UTC)
Willem99
There are no marklin dealers or marklin users I know off in this part of Georgia. I am a lonely wolf here :)
#4 Posted : 25 January 2022 22:34:10(UTC)
I don't recall Delta decoders being programmable, but additional addresses can be set on some of them. Browse through the DIY and modifications section here:
http://www.drkoenig.de/digital/ehomepag.htm
and look at the Delta decoder items.
Some had solder bridges that just needed to be bridged with some solder to set a different address.
See http://www.pallund.dk/convert.htm#a
Offline Willem99
#5 Posted : 25 January 2022 22:39:00(UTC)
Willem99
I saw those as well, but my soldering techniques are just not good enough for those kind of details.
My chances of burning that decoder when doing that are very close to 100%.
thanks 1 user liked this useful post by Willem99
#6 Posted : 25 January 2022 22:44:45(UTC)
ok, so you may have to mail one of them to someone and have them do the soldering, or install a new decoder
Online JohnjeanB
#7 Posted : 25 January 2022 23:03:28(UTC)
Hi Tim
Here is the way to change addresses on programmable Delta decoders. Look here https://www.manualslib.com/manua...remier-Ep-5.html?page=32
Address would be CV0
I hope this helps
cheers
#8 Posted : 25 January 2022 23:06:58(UTC)
It would be nice to know exactly which decoders are mounted, and if possible, find the instruction manuals for them Cool
If soldering is needed, it must be possible to find someone to help you; but instead of soldering, it could also be
de-soldering / removing a connection, which then could be done with a sharp knife, instead of a soldering iron BigGrin
P.S: I don't think DELTA decoders from the 1990s are programmable.............. Blink
#9 Posted : 26 January 2022 00:16:40(UTC)
I agree - other than changing the decoder address and that is usually done with the DIP switch settings on the decoder.
#10 Posted : 26 January 2022 00:57:30(UTC)
I just found this on a very strange homepage....................... LOL
https://www.marklin-user...digital/DIdeltaaddr.html
Unfortunately for Tim it looks like he has to solder to change the address from 78, if his decoders are the solder-addressing type,
which means that my suggestion above about removing solder doesn't help him Blink
#11 Posted : 26 January 2022 02:35:15(UTC)
Yes, which is why I used the word 'usually' in reference to DIP switches - having in the back of my mind the fact that some decoder addresses are programmed via a solder bridge.
#12 Posted : 26 January 2022 09:21:42(UTC)
There are no programmable Delta decoders. Not worth trying.
Address is in register 1 for programmable decoders. But I repeat: Delta decoders are not "programmable".
Offline bph
#13 Posted : 26 January 2022 11:24:21(UTC)
Do you know anyone that can help you solder ? Don't necessarily need to be a Marklin person.
your decoder probably looks like this: (with 4 solder bridges to the right). and are fairly easy to solder if you have sone some general soldering experience. at least as long as you stay within the 15 normal addresses.
https://abload.de/img/decodersebwwpd2.jpg
normal addressing:
http://www.ralf-bueker.de/Anleitung_Deltamodul_6603_01.jpg
http://www.web-hgh.de/images/decoder/maerklin/delta/std/6603/6603_0_adr.jpg
more information:
http://www.web-hgh.de/index_jsm_moba.htm?http://www.web-hgh.de/p03_maedel_dec.htm
Marklin official address table:
https://www.maerklin.de/fileadmin/media/service/technische_informationen/Codiertabelle2.pdf
Offline Willem99
#14 Posted : 26 January 2022 15:00:31(UTC)
Willem99
Here is a picture of the locomotive and the decoder.
Now you can see why I am not willing to spend any money on it, it is cheaper to just replace the unit.
Thanks for all the replies.
Tim
Offline Willem99
#15 Posted : 26 January 2022 15:02:50(UTC)
Willem99
I honestly do not know why one of the pictures turned around.
I did them both the same way.
Tim
#16 Posted : 26 January 2022 15:04:07(UTC)
Tim
Right, that looks like the loco from the 2915 start set, or similar set.
You can see the solder jumper points in the top right hand of the second picture. Personally I would put solder blobs on the three remaining contacts (you can see the top one has solder on it) and that would give the loco an address of 80.
#17 Posted : 26 January 2022 16:21:32(UTC)
or try one of the product that comes in a tube that conducts electricity. Just add a blob between the pads as needed.
Offline Willem99
#18 Posted : 26 January 2022 21:33:01(UTC)
Willem99
Hi there,
I bought myself a little soldering iron at the Home Depot.
I bridged the 2nd contact from the top without burning anything else (but it was close).
Now the little steam locomotive is chugging happily along on digital address 72 without any issues.
My original diesel 33744, which was at a digital address of 72, has dip switches which I could reset easily.
So now I am good to go with all my locomotives.
On to the next project.
Thanks for all the help in resolving this issue.
Tim
thanks 6 users liked this useful post by Willem99
#19 Posted : 26 January 2022 21:43:57(UTC)
Hi there,
Tim
Oh great. welcome to the world of tweaking your items ... ThumpUp
Glad you had success. Cool
#20 Posted : 26 January 2022 23:51:21(UTC)
Right! There are also pens with conductive ink for around $7.
Or conductive paint, like any other Humbrol/Airfix can.
Not long ago I bought a soldering iron for around $6. Incredibly cheap. With a real wooden(!) handle. It´s really bad of course, but could be used to place a blop over the pads...
This page was generated in 0.757 seconds.
