Offline Ephraim
#1 Posted : 11 January 2022 09:54:35(UTC)
Ephraim
Israel
Need advice to overcome a ~4 mm gap in the marklin C track layout.Tried conventional method of averaging out but I still miss this gap distance. The electricity is ok on both sides but the wheels of the cars cannot pass the gap.
Appreciate a solution
Thanks Ef
#2 Posted : 11 January 2022 10:09:58(UTC)
Hi, Ef!
Welcome to the forum!
If you would show what you have (track plan) then we can make better suggestions. That is, if you are interested in a solution that works without cutting an gluing.
With cutting and gluing it will be easy to solve the issue.
Offline Ephraim
#3 Posted : 11 January 2022 10:29:22(UTC)
Ephraim
Israel
Thanks Tom
The problem is that the track is already embedded in the landscape and i cannot change the structure. I would like to avoid cutting/gluing options
thanks 1 user liked this useful post by Ephraim
#4 Posted : 11 January 2022 12:43:11(UTC)
Hello Ephram! If you can't shim the track if it is unlevel to close the gap, you can try a dot of solder in it. I have done it with K track. Sometimes temperature changes cause tracks to move a bit. I have C track joining K track on a bridge approach. I noticed a current break when the temperature changes.
Offline Ephraim
#5 Posted : 11 January 2022 13:26:15(UTC)
Ephraim
Israel
Tnx 5999
Will try the soldering approach
Any particular tip with respect to track cleanup prior to soldering (acetone, ethylalcohol, isopropanol ) ?
Offline Ephraim
#6 Posted : 11 January 2022 13:27:44(UTC)
Ephraim
Israel
Tnx 5999
#7 Posted : 11 January 2022 13:51:28(UTC)
Alcohol should be fine, just be sure it's dry afterward before soldering. Use thin wire solder so as not to make a bump in the track, or a buldge in the side. You may have difficulty filing the sides of the rail. That could also cause derailures.
Offline Copenhagen
#8 Posted : 11 January 2022 16:20:41(UTC)
Copenhagen
I haven't any experience in soldering tracks so I don't know how well the tin will adhere to the metal. Maybe it would be a good idea to practice on some spare pieces of track before doing it on the layout?
#9 Posted : 11 January 2022 17:45:25(UTC)
4 mm is a big gap to be filled with solder alone. More realistic to fill it with a piece of wire that is soldered in.
To resolve a purely mechanical problem it might be better to glue a little piece of plastic or even wood into the gap.
#10 Posted : 11 January 2022 18:50:55(UTC)
I would sacrifice 6mm of rail from some other track, file it down to the right length and push it into place, hold it in place with superglue.
#11 Posted : 11 January 2022 19:59:30(UTC)
Marklin do supply packs of track joiners for C track, for people who cut to custom lengths.
This page was generated in 0.354 seconds.
