Offline Toosmall
#1 Posted : 27 December 2021 11:03:31(UTC)
Toosmall
Installing a private ski lift for the local ski lodges to get up to the main ski runs. The bull wheel rotates, but this was easier for spray painting. Also the bull wheel and motor slide off the back, so one could argue that the new structure has hydraulic cable tensioning.
I wanted to show the mechanical structure rather than building a motor room to cover everything. A bit fiddly in Z gauge, but not too difficult.
Hopefully painting in the next few days. Unfortunately had a computer system meltdown, so photo was with an old pocket camera.
thanks 12 users liked this useful post by Toosmall
#2 Posted : 27 December 2021 16:33:31(UTC)
Remarkable Jonathon! Will you motorize it? I got one as a Christmas gift, but wrong scale. The E-bay seller in Tussing Germany is accepting it back.
Offline Toosmall
#3 Posted : 27 December 2021 20:06:40(UTC)
Toosmall
While building I did think that it wouldn't be too difficult to do a motorised ski lift in Z gauge, but I would have to use high density FTFE (I have a few thicknesses up to 3mm) for the Bull Wheel and the Sheave Wheels on the In Line Towers for the cable and together with stainless axles for bearings which would last... But, as the second photo indicates my Z gauge layout other than the actual rail has an abrupt flat earth problem!
I have cheated with the hydraulic cable tensioning and resorted to using a spring instead to keep the cable (1:220 polyester thread) taught. There is about 4mm (0.9m 1:1 scale) of useful tensioning. Hopefully no one will notice. Probably shouldn't have pointed it out!
OD of the bull wheel is 15.5mm.
#4 Posted : 27 December 2021 20:39:37(UTC)
oh, it will be cool just the same!
Offline AmalfiCoast
#5 Posted : 28 December 2021 01:01:18(UTC)
AmalfiCoast
I like your layout. What chalets/models are those?
thanks 1 user liked this useful post by AmalfiCoast
Offline Toosmall
#6 Posted : 28 December 2021 06:36:14(UTC)
Toosmall
The buildings are Kibri, decades old, so probably toned down with dust.
I will winterize the scene later, have ordered some skiers. The T-bar is a bit of stainless steel etching offcut bent to shape. Will have to do some more. The main cable is some Gütermann CA02776 polyester thread about 0.25mm diameter, so about 55mm in 1:1 scale. The ladder is an offcut of stainless steel balustrade, a touch wide but the rung pitch works out at 290mm, so good enough! Paint is car touch up spray cans. The spring works really well to maintain tension, so it turns out to be a practical solution even at 1:220 scale.
(The PistenBully and Land Rover are custom built)
thanks 6 users liked this useful post by Toosmall
Offline PeFu
#7 Posted : 28 December 2021 07:09:10(UTC)
PeFu
Great crafts and art! And this is Z gauge! I was just about to ask from where you purchased the Pistenbully, notising it was also custom built. Did you design and print all details for the lift and bully?
ThumpUp
Offline Toosmall
#8 Posted : 28 December 2021 11:38:49(UTC)
Toosmall
It was a compilation of various images. I could have projected photos and built up a 3D model but it's a lot of work for not a lot more benefit for the model I wanted. So just did some basic plans. I did drift off my plans and also left a few things off, but happy with the result. It's difficult to see it without glasses anyway!
But the key is to make some plans before you build something. The time you spend on plans will save far more time building.
Offline ClimbingKarabiner
#9 Posted : 01 August 2025 23:30:42(UTC)
ClimbingKarabiner
This is truly epic. I have just ordered some micro slow geared motors so will be aiming to get this motorised. Do you sell the 3D print codes or would you be prepared to create me two sets one for a ski lift and the second for a gondola? Would obviously pay for your time, material, postage and put some extra in for your extra ordinary creative talent. You are the only person I have found who has ever attempted this in 1/220th scale - truly well done!
thanks 1 user liked this useful post by ClimbingKarabiner
Z-Gauge Ski Lift or Gondola (Small scale)
by ClimbingKarabiner 01/08/2025 22:59:42(UTC)
Seilbahn / ski lift (H0-scale)
by Lars Westerlind 11/02/2009 00:49:28(UTC)
Rocker Insulator, Ski Lifters, Ski Ramps, Part # (Digital)
by dntower85 26/11/2007 20:56:29(UTC)
This page was generated in 0.580 seconds.
