Offline cantanks
#1 Posted : 24 September 2021 00:59:31(UTC)
cantanks
Hello all
I have had 6 Amtrak passenger cars for years. No box and no parts to connect them all up. looks like some sort of push-in wire connection required?
cars are numbered as follows: 2/3340 (front and rear?) 2/1047 baggage cars 2674 includes pick-up slider finally 4813
checked out Mr Google. don.t think it is s Marklin 43600 set because no observation car.
as usual any advice much appreciated, thanks
[img=null]Marklin Amtrak passenger cars[/img]
#2 Posted : 24 September 2021 02:44:06(UTC)
Your photo is not visible. Try editing the post and including the photo as an attachment, rather than as a photo which requires a URL.
https://www.lokmuseum.de...ak&Seite=64&SID=
Your coaches seem to be from the 43600 set.
#3 Posted : 24 September 2021 05:04:42(UTC)
Jim has sent the photos to me, will load them up when I get a chance.
#4 Posted : 24 September 2021 11:46:03(UTC)
Photos as promised.
#5 Posted : 24 September 2021 11:51:33(UTC)
Originally Posted by: cantanks Go to Quoted Post
Hello all
I would suggest fitting couplings from the 72020 set, which will provide conductive connections between cars. I suspect the set may have originally been supplied with the conducting drawbar that has been around for years, but i wouldn't recommend using it as it is a pain to couple units up.
Offline cantanks
#6 Posted : 25 September 2021 05:16:46(UTC)
cantanks
thank you Alan, thank you David
looks like an expensive exercise from here in NZ. from what I can work out looking at around $160 - $180 all up $30 a car? doubt I would get my money back.
thanks again & stay safe out there
#7 Posted : 25 September 2021 11:06:27(UTC)
Hi Jim,
You only need the "coupler heads", which are not very expensive. The part number is E115737 (sometimes "abbreviated" to 115737). I don´t know about the shipping cost, but normally a pack of ten costs less than 20 Euros. There are several vendors on German eBay.
Smile
#8 Posted : 25 September 2021 15:49:35(UTC)
For the sake of completeness re. the images in post no. 4:
Photo 1 shows:
- observation car (running at the end of the train)
- baggage car
- baggage car
- coach
- sleeper
Thus, you are owning two "tail end cars".
Photo 2:
The pockets in which the coupler heads (E115737) need to be inserted are clearly visible.
The passenger cars have been produced in various liveries. The Santa Fe cars used to be sold individually, and sometimes spare parts are offered by referring to their article numbers:
43601 coach
43602 sleeper
43603 baggage
43604 observation
Edited by user 25 September 2021 23:55:20(UTC)  | Reason: Not specified
#9 Posted : 25 September 2021 16:20:49(UTC)
I think that the Amtrak set came with factory installed lighting and current conducting couplers. I don't think that the separately sold models were outfitted as such, but I do not have any of the models so I cannot be certain. As you stated, the basic parts would be the same though although Maerklin has used different types of interior lighting in some models than those which are sold separately.
#10 Posted : 25 September 2021 16:25:17(UTC)
without pre-installed lighting: 43601 coach/43602 sleeper/43603 baggage
with pre-installed lighting: 43604 observation
Offline cantanks
#11 Posted : 26 September 2021 00:34:15(UTC)
cantanks
Hi Jim,
pack of 10 ordered as per your P.M. total cost 31.03 EURO will let you know how they work in 3 or 4 months time when they arrive
(been in a drawer for very long time another month or 2 will not matter.
Big thanks to all for advice.
thanks 1 user liked this useful post by cantanks
#12 Posted : 26 September 2021 08:57:25(UTC)
Very good. The installation is easy (no tools needed):
(1) Hold the pocket carefully to prevent lateral movement.
(2) Then push the coupler into the pocket until it clicks.
This page was generated in 0.795 seconds.
