Just some ancillary comments
Originally Posted by: JohnjeanB
Registration on my CS3 is fine except if there is data traffic on the Ethernet link where unplugging it can help a lot.
A curious observation that I will take on board.
The TFP(GFP) is meant to be a separate processor that I would have expected to be insulated from the async activity of the ethernet. And while the ethernet is reflecting the registration traffic, it is just UDP and not waiting for a reply.
? Are you perhaps referring to ethernet traffic
from a layout control program?
Quote:Registration on the program track can help if there are quite a number of locos on the main output (32 in my case)
In operational mode the programming track is similar to the main (all be it reduced power) - it is only when you actually "do programing" that the port switches to drive differently (in the CS1 you could actually hear a relay switch in)
In this sense mfx registration and even mfx/CV changes is not programming as such - programming refers to the MM/Reg , non-POM DCC/CV and firmware updates of a decoder.
That said, (poor) wiring (connections) is probably more of an issue than number of other mfX decoders. But NON mFx decoders would have an influence.
During the registration any mfx decoder should be quite silent during the feedback window, it is nonmfx decoders that will continue to present a load.
And just to be clear the feedback signal of a mfx decoder is not the decoder "driving/sending" a reply, but modulating (selectively loading/sinking) the feed from the controller which, at the time of a registration process window is not "fully driving like a fire hydrant" but "driving and listening"
the ability of decoders over the generations of technology to crisply sink and modulate may mean that the programming output (reduced current) is better for some , but not enough for others
It may be counter intuitive but one of the first things to pay attention to when putting a new loco (mfx decoder) onto a new controller is to observe that it immediately stops (if it was left with a speed setting on its prior controller). This happens because ever decoder knows/remembers its latest controllers signature ID (serial number) and, because a new controller is constantly sending its own ID with every packet, the decoder quickly (within secondss) says to itself "Whoa - new boss - better stop and wait for further instructions".
This generally is seen only with the motor stopping, it would be nice if the lights and certainly the sound also turn off until after registration to remove their power drain. If you loco does not turn its lights and sound off (because you left them on on the last controller) you may ant to return to the prior controller and specifically turn them off.
But again, as a debug tool, you might deliberately leave a loco/decoder "wound up" (from its old controller) just to ensure it does stop on the new controller -thus indicating that it is at least sensing a mfx command in the data stream.
It is then a separate process for the controller to - once every 30 seconds (so wait and count slowly) - put the call out "is there anybody new out there".
i.e. the new loco does not just hop on the line and shout "I am new here", it must wait to be asked.
Only new decoders will respond as existing ones will know who there controller is.
At this point it is definitely a hinderance if you have put more than one new decoder on the layout, as this will invoke another level of tie-breaking logic and slow the whole process down.
As a side comment , I would highly recommend an un-smoothed LED connected (with current limiting resistor) to the track power feed, as a human visual aide/guide for observing the flickering patterns of the track pulsations. It does not take long before you can discern the difference between the patterns of ongoing idle chatter, the busts/pause of the 30 second poll and the intense feedback traffic when getting data returned.
If nothing else it helps communicate to people that the registration can take "a while" to even start.
As a closing comment on decoders behaving badly. Experience from other life - not specifically trains/mfx
A single decoder/device on any bus can sometime "not shut up". While it may quite happily be doing what it is actually told and seeming to work ok, when you are attempting to send to a different decoder/device it will not get "off the line".
Unfortunately technology changes - especially timing tolerances - come in to play.
If anyone has experience with very early decoders/locos registering on a CS1/ECos but not a CS2/CS3 I would like to hear if you think it is speed related
(The CS1 was a lot more measured in its discovery and I wonder if the older/original mfx decoders cannot cope with the CS2 rate of command requests)
Edited by user 03 July 2021 13:14:03(UTC)
| Reason: Not specified
