2 Pages12>
Offline Ranjit
#1 Posted : 23 June 2021 15:06:10(UTC)
Ranjit
Hi All...
As in real life, the catenary swings across the pantogragh in order to not great so much heat and to not split the pantograph, do the scale models, particularly the HO, also behave prototypically in a similar way ? Does the pantograph also stay in contact with the catenary at all times ?
Ranjit
#Get Vaccinated
thanks 2 users liked this useful post by Ranjit
#2 Posted : 23 June 2021 17:33:10(UTC)
Yes, if the catenary is hung correctly. Although, I don't think our models make much heat. Long runnung may cause uneven wear if the overhead cable isn't staggered.
#3 Posted : 23 June 2021 17:38:00(UTC)
I remember that Sommerfeldt used to offer catenary masts with short or long arms, which enabled the zig zag of the catenary line to be reproduced in model.
Maerklin's catenary (classic) had only a single length of the arms. In curves, rather than having short straight sections, Maerklin actually recommended to modellers to bend the catenary so that it follows the line of the curve. The newer (Viessmann) inspired design uses shorter straight lengths, but still has only one length of the mast arms.
I remember many instances from childhood where the catenary would snag the pantograph if there was too much play. Fortunately back then, there was little damage. Today, with the fine detailed pantographs, a repair/replacement after an accident is more than likely to be required.
#4 Posted: : 23 June 2021 19:12:55(UTC)
True, but each mast has two fixations-points; one for short arms, and one for long arms. So you still get the staggered overhead wire.
I suppose they thought it was a good idea to rationalize the production of mast like that... (Even my cheap Hobbex system has two different masts, so WTF¿?)
Offline Ranjit
#5 Posted : 23 June 2021 19:18:15(UTC)
Ranjit
Is Sommerfeldt still in business ? Just checking.
Between Sommerfeldt and Viessmann, which one is better ? In terms of robustness, prototypical look and feel and price ?
Ranjit
#Get Vaccinated
thanks 1 user liked this useful post by Ranjit
#6 Posted : 23 June 2021 19:43:15(UTC)
Yes, Sommerfeldt is still in business, or was when I looked at their website on Instagram a few months back. I think they may still supply to Marklin. Thye aren't far away from Goppigen.
Offline mvd71
#7 Posted : 24 June 2021 00:41:06(UTC)
Ranjit
I believe Sommerfeldt is still in business, and their products are by far the most robust.
#8 Posted : 24 June 2021 03:08:57(UTC)
Sommerfeldt provides pantographs to Maerklin, Hag and many other brands. Viessmann was chosen as the company to make the current Maerklin catenary system.
The Sommerfeldt catenary is much more fragile and requires a more complex assembly, whereas the Viessman masts still clip to the track and can be set up and taken down with relative ease. Sommerfeldt masts are anchored to the layout, and there is soldering involved, making takedown much more complex.
Offline Ranjit
#9 Posted : 24 June 2021 04:56:49(UTC)
Ranjit
Interesting comparisons between Sommerfeldt and Viessmann !!
#Get Vaccinated
Offline Legless
#10 Posted : 24 June 2021 05:37:37(UTC)
Legless
This is well worth purchasing if you want a great system.
Legless
thanks 3 users liked this useful post by Legless
Offline mvd71
#11 Posted : 24 June 2021 07:18:36(UTC)
Perhaps we should clarify, the sommerfeldt masts are much more robust, but the wires are smaller diameter. Is this what you mean by the more fragile?
I currently have Viessmann catenary, but I am seriously looking at changing to sommerfeldt because of the fragility of viessmann masts.
Cheers….
Mikeu
#12 Posted : 24 June 2021 07:35:38(UTC)
Indeed is very worthwhile purchasing, as noted above by Legless
I posted on this five years ago :
https://www.marklin-user...rklin-Catalog#post507185
May I also point out that the Sommerfeldt Catenary system is not "much more fragile" but is very robust. It is the only system I have seen readily available that has a good representation of the structure of DB catenary and reflects the same functional aspects as true as possible to the prototype.
Offline Ranjit
#13 Posted : 24 June 2021 08:28:55(UTC)
Ranjit
Hey Mike..
Does this Sommerfeld's catalogue come in English?
#Get Vaccinated
Offline mvd71
#14 Posted : 24 June 2021 09:09:36(UTC)
Good question, would be great if there was an English version
#15 Posted : 24 June 2021 09:41:51(UTC)
It's not a catalogue.
This Sommerfeldt manual is bi-lingual (German and English). I don't have it, so I cannot comment on its quality.
The catalogue is also German and English. The catalogue can be downloaded for free, the manual must be bought.
https://www.sommerfeldt.de/de/download/ => Katalog als PDF zum download
Offline Ranjit
#16 Posted : 24 June 2021 09:44:13(UTC)
Ranjit
Like an instruction manual, Tom ? Good that it is bilingual !
Ranjit
#Get Vaccinated
#17 Posted : 24 June 2021 12:07:21(UTC)
As Tom points out, the image is the manual.
It is indeed tri-lingual ! (German, French and English)
My copy is rather old now. It does show you in detail how to construct the catenary system:
sample contents :
The Catalogue (again, mine is old) is also tri-lingual :
sample contents :
#18 Posted : 24 June 2021 12:31:16(UTC)
May I please add a correction Blushing :
The current, up-to-date manual is only bi-lingual (apologies, Tom)
(The catalogue remains tri-lingual)
OhMyGod
#19 Posted : 24 June 2021 12:54:30(UTC)
Yes, but that hasn't changed for years as I have the exact same file listed as the 2009 Sommerfeldt catalog.
German, English and French.
The majority of the catalog is in German. Some of the introduction is also in English.
Product descriptions are in German, English and French.
#20 Posted : 24 June 2021 13:19:25(UTC)
I've been using Sommerfeldt for donkey years and never had a problem with it, I think Märklin produces the best pantographs., most other brands, their spring isn't strong enogh to keep the wiper against the wire., meaning the are not suitable running locos from the oerhead system power.
Offline Ranjit
#21 Posted : 24 June 2021 14:12:14(UTC)
Ranjit
You guys are brilliant ! Thank you all for your feedback and comments on the Märklin, Viessmann and Sommerfeldt catenary systems. It seems that Sommerfeldt is winning hands down.
The Sommerfeldt catalogue is so detailed ! It is amazing. Does the fixing of the masts to the table and the soldering of the joints, etc. make the Sommerfeldt catenary system more intricate and difficult to use and maintain long term ?
Ranjit
#Get Vaccinated
#22 Posted : 24 June 2021 14:57:18(UTC)
Ranjit, to build and construct the Sommerfeldt catenary system is not a job for the faint hearted., you need certain skills an patience to construct an overhead system.
all masts are metal and you have a choice of wire gauges 03mm, 05mm and 07 mm., I'm using 07 gauge because it is robust and epeciallwhen using the overhead system as it was intended.,
also the myth about using a catenary when running digital trains is absolutely false and misleading, I've used it for over 40 years.
At one stage I've ordered just wires and constructed my own wires but since than, unfortunately I've realized I used an inferior flux which didn't keep the uprights from breaking away when handling trains., since than my son bought ready made wires and when I have time will replace the old ones, a lot of work turned out to be a waste of time.
the Sommerfeldt sytem is not cheap but on the other hand it lasts a life time., with the odd bump of a cross span mast (one particular it is very close to the edge of the board) I've repaired it about 4 times and it is still standing today.
the application of the catenary has shifted slightly over the years with more locos being produced authentically or prototypical and this includes the pantograph and the wipers width, the SBB system used wipers with a narrower wiper and this makes it it again harder to reproduce to acomodate the tollerance between left & right (staggered application).
so what was perfectly before has now become somewhat trouble some and there had been a lot of alterations to the allowed width which ment to adjust the arm to its right position but it also made it impossible to adjust the wire within a curve and the masts had to be relocated to its new position,
Yes we had a few unrepairable pantographs but in hindsight we've learned our lesson., we also had incidents whereas trains were running for month with a hitch and than for no reason at all another pantograph got hooked up., well this was until I've investigated the cause, in one incident the track had moved, in others the downwire got broken off from the bottom wire or other pantographs have a very sharp edge and any rough soldering spot got caught, this is the main reason we're changing it to ready made wires and the doldering point is limited to the mast where 2 wires are joined together.
I wouldn't recommend it for clumsy people as it needs adjustment to be aware there is an overhead system present and it takes some time to get used to it, its not an ideal situation when you change locos or wagons on a regular basis and we are still working on this how to overcome it.
its like with everthing else in life you have to live with it and except it., I wouldn't change anything and I couldn't see myself having electric locos without a catenary system, some people may have a different view of an overhead system but when you build one you never look back, the only think you regret the mistakes you've made in the past but with making mistakes you never can go forward with fresh and more constructive ideas.
Offline rbw993
#23 Posted : 24 June 2021 15:29:26(UTC)
rbw993
I have just about completed installation of the Sommerfeldt catenary on my layout. It requires a lot of assembly but that is the fun part and it means it is easy to modify so that it more closely matches the type of catenary used in different locations. The Marklin/Viessman system is DB generic. Sommerfeldt offers German, Austrian, Swiss, Dutch, Belgian and Italian and offers lots of different parts for customization. I customized a Dutch Cross Span type to closely match the catenary style at Kussnacht am Rigi.
I haven't installed the overhead wires at this point and may never as they are oversize. I'll make that decision when I have finished the scenery
Roger
Offline Ranjit
#24 Posted : 24 June 2021 16:02:29(UTC)
Ranjit
Thank you, John, for your very detailed account of your "hands-on" experience using catenary systems for over forty (40) years !! I too agree with you that you can't run electric locomotives without a catenary system.
Take care and stay safe.
Ceers,
Ranjit
#Get Vaccinated
Offline Ranjit
#25 Posted : 24 June 2021 16:09:49(UTC)
Ranjit
Congratulations, Roger, for completing the installation of the Sommerfeldt catenary system on your layout !! Yay !! I too agree with you that you need to sometimes dive deep down and get your hands dirty assembling and installing a complicated system while having lots of fun. I like the idea of Sommerfeldt offering different parts for customization and styles that are unique to different countries. I gives the system a very classy and prototypical look and feel.
Why are you not going to be installing the overhead wires. Isn't that supposed to feed the power for the locomotives ?
Ranjit
#Get Vaccinated
Offline rbw993
#26 Posted : 24 June 2021 16:20:07(UTC)
rbw993
Hi Ranjit, thanks. The issue I have with the wires is that they get in the away and are out of scale. Even the fine scale 0.5mm wires are well oversize. I may yet decide to use them but I have a lot of scenery work to do and I am sure I would damage the wires if I put them up first. John's layout is a good example of how good the catenary can look if done right.
I am not going to power the catenary, it is purely cosmetic. I run the layout digitally through the track and will not change that. I do plan to add a restraining wire to the pantographs that will allow them to run in the up position near to where they would be if there were a wire.
Roger
thanks 3 users liked this useful post by rbw993
Offline Ranjit
#27 Posted : 24 June 2021 16:31:53(UTC)
Ranjit
Thank you for that info, Roger ! Good luck with the scenery work !!
Ranjit
#Get Vaccinated
Offline rbw993
#28 Posted : 24 June 2021 16:43:30(UTC)
rbw993
Thanks Ranjit. I'll try to post some pictures soon.
Roger
#29 Posted : 24 June 2021 19:56:55(UTC)
Ive been looking at the pantograph of the Be4/6 of this months Wallpaper and thinking how narrow the wiper area is. Also looking at the mast where the overhead wire is clipped on. I assume this is the Marklin/Viessmann system.
Offline jcrtrains
#30 Posted : 25 June 2021 01:42:17(UTC)
jcrtrains
Ranjit;
Give some thought to the cost of adding catenary. Build a rough spreadsheet of the masts needed paying particular attention to where you have multiple tracks. One particular curve of mine has 11 double masts ( Viessmann part 4160). Reynaulds prices those at 33 usd each and that is one curve. It can mount up. However, it is a great project and looks great.
thanks 3 users liked this useful post by jcrtrains
Offline Ranjit
#31 Posted : 25 June 2021 13:10:43(UTC)
Ranjit
Originally Posted by: jcrtrains Go to Quoted Post
Ranjit;
I will keep this in mind, and pay attention to the cost. Usually, for me, when I purchase Märklin items and other model railroading accessories, I always consider the quality first. No doubt, the cost is important, but it takes second place.
Ranjit
#Get Vaccinated
Offline Mman
#32 Posted : 25 June 2021 14:33:56(UTC)
Mman
Referring back to the original post about the wire zig zagging to spread wear evenly on the top of the pantograph, this is important on the full size railway as the contact surface is carbon and does wear - the carbon part is replaced frequently. Much easier to replace than the miles of wire of course.
On miniature railways the contact is often plated metal and wear is not significant, the current is comparatively small.
Similarly do our HO or Z rails ever show wear? Or the wheels even? I once made some soft brass replacement wheels for a loco to see if I could detect any wear after prolonged running but all I saw was polished areas.
On the London Underground with its many sharp curves it has long been a delicate compromise between hardened wheels or hardened rails each having pros and cons. On British Railways wear of wheels and rails causes problems near insulated rail joints and powerful magnets have been installed at these joints to attract the filings to avoid short circuiting the IRJs, again, luckily that doesn’t affect us!
The sliders/skis do wear of course on HO three rail, perhaps the studs should zig zag.
ChisG
thanks 3 users liked this useful post by Mman
Offline Jimmy Thompson
#33 Posted : 25 June 2021 15:48:26(UTC)
Jimmy Thompson
Mman wrote:
"The sliders/skis do wear of course on HO three rail, perhaps the studs should zig zag."
LOL LOL
Jimmy T
Dr Dirt's Rule #1 and
#34 Posted : 27 June 2021 09:40:54(UTC)
Hello Alan,
A very good observation.
I own this locomotive (39511) and am pleased to report it is supplied with an additional set of wide pantograph wipers wich the user can fit in lieu of the standard ones.
By the way, this is a stunning piece of modelling from Märklin in every respect.
Offline ccranium
#35 Posted : 29 June 2021 01:37:16(UTC)
ccranium
ChisG
I'm slowly installing classic Märklin catenary on my analog layout, and with the variation of the bent/curved and even straight sections and their masts, zig-zagging is unplanned but a byproduct. The more important challenges for mine are 1) to be sure the zigs and zags don't go too wide for the wipers and 2) all the small bolts, nuts and adjustment sections are smooth on the underside. Slow test runs using the studs first make it less painful before powering up a new section of wires! So far a very rewarding goal.
thanks 6 users liked this useful post by ccranium
#36 Posted : 29 June 2021 14:31:25(UTC)
If you do decide to install the wires, here is a tip for making your life easy:
https://cabin-layout.mixmox.com/2002/05/catenary-guide.html
As hinted, I used to install the actual wires but found them to be:
a) too much in the way
b) easily bent via a small bump, and then cannot be straightened properly
c) unrealistic - too thick (even with the fine Sommerfeld profi wire, painted, etc.)
So on my new layout, I am only putting the masts up.
It looks fine, see first image at:
https://cabin-layout.mixmox.com/2016/11/distances-markers.html
It is cheaper.
And yes, the pantographs on the locos have to be run either in the down position or tied with a tiny thread.
And yes, you don't see little sparks (not that I would place wires in hidden areas to run power through the visible areas anyway).
Arguments for missing realism of this approach have to set aside that the model wires are simply too thick in HO scale to even start. See photographs of real trains photographed from 180' (2' in HO scale) and see of rarely one can see the wires!
thanks 5 users liked this useful post by DaleSchultz
Offline Ranjit
#37 Posted : 29 June 2021 16:43:12(UTC)
Ranjit
Hi Dale...
IMHO, putting up the catenary masts on a layout and not connecting the contact wires looks very unattractive and not having any beneficial features to run electric locomotives. You might as well not have the masts. I see your point that it is difficult, time-consuming and expensive to connect the wires, but once it is done, the layout is going to have a different look altogether with a great amount of "realism".
Ranjit
#Get Vaccinated
thanks 3 users liked this useful post by Ranjit
#38 Posted : 30 June 2021 00:41:08(UTC)
sure, I used to think the same way.
Order enough for to do a trial stretch.
See how it looks.
Wait until it gets bumped, then try to straighten the wire.
Note how the realism has now gone out the window....
It is of course all a matter of personal choice, but seeing the masts along my mainline very convincingly persuades the viewer that there is a complete catenary system in place that resembles real life.
#39 Posted : 30 June 2021 04:15:20(UTC)
Dale, your assumptions are totally unfounded: Wait until it gets bumped, then try to straighten the wire., the moment the wires are soldered together and tightend there is no movement, any bump you may experience does not alter the line of the wires., because they are tightend, there is movement but the moment you release the extra tension (bump), the wires will go back to its original position.
I agree with Ranjit, why bother putting up the masts and at the same time commenting on the Sommerfeldt unrealistic look of the profi wires., your argument seems to me, going from unrealistic to realistic at the same time.
It is your choice whatever you intend to do: but seeing the masts along my mainline very convincingly persuades the viewer that there is a complete catenary system in place that resembles real life: it's not my view and one can follow the trend by errecting a new catenary system but than you wouldn't have electric locos running along., somewhere you've gone off the rails with your theory.
Offline Ranjit
#40 Posted : 30 June 2021 05:16:33(UTC)
Ranjit
There is no doubt that Dale has "derailed" !!
Ranjit
#Get Vaccinated
#41 Posted : 30 June 2021 06:47:15(UTC)
I think this only holds true for Sommerfeldt wires, which are under tension. The rest of the systems uses "hanged" wires, where any deformation stays until you straighten it back.
Although the wires are too thick in H0 scale, I still prefer to have them, as they look so great. I don't agree that you don't see them on photos of the prototype unless a too low resolution of the picture has blurred them away...
Even WITH the wires, you might want to keep the pantos a little down (f.x. with a thread or a drop of super-glue) so as to no be foiled when it slips to the side of the wire. -Maybe because of an accidental bending!
Offline Ranjit
#42 Posted : 30 June 2021 08:39:04(UTC)
Ranjit
Hi All...
Does anyone know if the MIBA Report 19 - Elektrische Leitungen by Lothar Wiegel (update by Bernd Zoellner/Bruno Kaiser) available in English ? If not, is there a translation of this publication in English ?
Ranjit
#Get Vaccinated
#43 Posted : 30 June 2021 21:28:54(UTC)
these are not assumptions.
I have personal experience of erecting the catenary carefully. Under tension.
Here is how it looked.
https://cabin-layout.mix...Sommerfeld-catenary.html
Once those wires got bumped they bent.
Once bent it it is impossible to get the nice lines back.
Like I said, try it.
#44 Posted : 01 July 2021 01:35:52(UTC)
Hello Dale,
I am sorry for your experience with the wires.
Fortunately this has not been my experience, as detailed in the link provided at my earlier post # 12
Philip
Offline Ranjit
#45 Posted : 01 July 2021 05:09:55(UTC)
Ranjit
Dale... Take a look at Philip's work on the Sommerfeldt overhead catenary system. He has laid out the system very nicely. You may learn something new. You never know.
Great work, Philip !!
Ranjit
#Get Vaccinated
Offline Ranjit
#46 Posted : 01 July 2021 05:42:21(UTC)
Ranjit
Of course, you may also touch base with John who has years of experience working with catenary systems, Dale. When you say, "Sommerfeld catenary is rock solid high quality stuff", and at the same time, you say, "it is simply impractical as the slightest bump bends the running wires", there must be something that you are not doing right. Check it out.
Take care and stay healthy.
Ranjit
#Get Vaccinated
Offline applor
#47 Posted : 01 July 2021 08:56:52(UTC)
applor
If you're interested I did my catenary with Sommerfeldt profi range, designed as per prototype instructions etc. featuring multiple cross spans and details such as Y hangars
https://www.marklin-user...9th-June-2021#post585972
My station catenary is not yet finished since I need to finish all detailing first otherwise it will restrict access too much.
#48 Posted : 01 July 2021 09:09:05(UTC)
The work you've undertaken is amazing,
#49 Posted : 01 July 2021 14:03:56(UTC)
how about stopping telling me how wrong I am until you have tried it yourself. An bumped them accidentally.
I am done with this topic. Best of luck.
Offline Ranjit
#50 Posted : 01 July 2021 14:15:12(UTC)
Ranjit
Got it !
#Get Vaccinated
2 Pages12>
This page was generated in 1.855 seconds.
