Offline H5463
#1 Posted : 13 June 2021 01:19:46(UTC)
H5463
Knowing this version of DB class 103.1 electric locomotive may be sold out everywhere, I still hope to know where to buy it. Or, will the company release the article again in the future? How often will Marklin remake the model? I see one in 1975!
I really like its digital controlled pantograph. I know Roco has issued a similar one (Roco 78211 - Electric locomotive 103 195-4) but without pantograph control.
Thanks!
#2 Posted : 13 June 2021 13:16:24(UTC)
There is a 39579 on ebay.uk at the moment. This is the first version of the operating pantographs using a piezo motor.
Offline H5463
#3 Posted : 13 June 2021 14:15:52(UTC)
H5463
I got a MS2. I guess it cannot run the loco's pantographs digitally. But anyway, thanks a lot for searching!
#4 Posted : 13 June 2021 15:35:55(UTC)
Why not? MS2's with the latest update (v3.55 or above) can control locos with 32 functions. The pantograph raising is a function which you engage with whatever controller you have.
#5 Posted : 13 June 2021 17:40:05(UTC)
This:
Due to the mechanical operation, the locomotive cannot be powered by catenary.
Offline H5463
#6 Posted : 13 June 2021 18:55:05(UTC)
H5463
Great! I should give it a try. By the way, I watched some YT, for upgrading MS2, you need to connect a CS, and if you don't have one you need to go to the model store or friends who have it. Instead of buying a CS, are they only ways to upgrade?
Thanks!
Offline bph
#7 Posted : 13 June 2021 19:45:54(UTC)
Thanks!
You don't need to upgrade the MS2, for it to handle the 39579, since the locomotive only has light (F0) and 4 functions.
You should also be aware that the 39579 has a C-sine engine, and if it needs to be repaired it can be costly and require a custom solution. And the locomotive lacks mfx, DCC, and sound.
#8 Posted : 14 June 2021 09:57:13(UTC)
39150 is the new mould with the correct length, 39579 is the old mould - too short by 5 mm and with yellow LEDs.
Over time we can expect various livery variations of the new mould, but not all will have motorized pantographs.
This page was generated in 0.547 seconds.
