Offline Harvey
#1 Posted : 15 December 2020 01:19:00(UTC)
Harvey
For several years I have read about contact tracks but not tried. My M track, CS2 layout uses reeds and circuit tracks. I recently installed an LED strip in my two track helix and initially set up with reed tracks to turn on/off as trains enter/leave the helix. The reeds also control block sections. This works fine with 1 train running but with 2 trains, the timing of trains entering/leaving the helix can result with a wrong setting for the lights. I decided to experiment and install contact tracts on each path, understanding that as long as 1 train is within the 'contact' section the LEDs will be on. Questions I have are how to build the contact section.
M-Track. To create the isolated section I need to 'break' the connection on one of the two rails (going to O) at a beginning and end point of the isolated section. How best to create this isolated section?
- Somehow pull off the small piece at the end of the M-track, that is used to join two sections of track. Then, grind away a very small piece of rail. I tried prying off one clip - not that easy.
- Use a dremel and slice the rail - Seems this could result in a rough surface.
- Other ideas?
Once the isolated section is completed, solder a wire to the isolated rail and connect to the S-88.
S-88. Based on page 64 of the Marklin 'Running Trains Digitally with the Central Station 3' a wire from the uncut rail would be connected to the inverted T on the S88. While the track is already grounded (to the O of the transformer) I assume there is no electrical conflict in running another ground wire to the S88. The isolated section is connected to 1 of the 16 slots on the S88. That slot would have the instruction (in my case) 'Turn current on at the M84 address'. So, when a train is in this isolated section, a pulse is sent to the S88 and the M84 leaves the current on. The pulse is continually set while a wheel set is in the isolated section. Once there is no wheel set present, no pulse is sent and the light turns off. Correct?
If I connect both Sets of isolated track (the lines going up/down the helix) to the same S-88 slot, then as long as one isolated section has a wheel set present, the LED is lit. Correct? Or, do I need to use 2 connection points of the M84?
Appreciate suggestions
Harvey
#2 Posted : 15 December 2020 05:52:46(UTC)
What you describe is, to me, a path of last resort.
Given that you already have operational reeds and S88, as well as a m84, I would just configure these to hold the "occupied state" of the two helix lines, and make use of the conditional controls for a Memory route when the exit sensor is triggered to ignore the turning off of the lights if the state of the "other" line is occupied.
Alternatively, you might consider a 60882 S88 (I refuse to call it -DC) in order to monitor the current draw when a train is on either helix track.
Offline Harvey
#3 Posted : 18 December 2020 15:29:22(UTC)
Harvey
Thanks for the response. I came to realize that M-track can not be converted in the way C-track can be. A special (contack) track is needed for M and K and C track can be converted. I am staying with my use of reeds.
Harvey
Offline Martti Mäntylä
#4 Posted : 18 December 2020 21:47:02(UTC)
Martti Mäntylä
Just for the record, it is quite possible to make M-Gleis contact tracks yourself; it just takes a bit more effort. I made about 20 of them last year as a part of my digital M-gleis experiment.
- Martti M.
thanks 2 users liked this useful post by Martti Mäntylä
Offline mrunix
#5 Posted : 15 February 2023 00:35:55(UTC)
mrunix
Hello, could you describe how you made these?
Offline BenP
#6 Posted : 15 February 2023 05:41:55(UTC)
BenP
Have a look at this thread and one M solution it offered
https://www.marklin-user.../t48501-M-contact-tracks
Ben van der Pluijm--
thanks 4 users liked this useful post by BenP
Offline amartinezv
#7 Posted : 15 February 2023 10:39:46(UTC)
amartinezv
Hello, good morning,
There is a way to make contact tracks with M track, basically it consists of cutting a certain length of a rail, for example 10 or 12 cm, insulate it with schrink tube, connect a cable and put it back in place. It is not difficult, but it requires a little time, I attach (I hope) some pictures.
https://photos.google.co...Z4Yez2Is06JxltyoCWbqWibd
https://photos.google.co...OO9TFkRfFEUR23njzF7RH5k2
https://photos.google.co...aBJIusFgZqAINpILaSEMur7o
https://photos.google.co...EMNjgt8ImFJwVvBu3PqLGUNl
https://photos.google.co...yL5RqrLxyfgs1QlRAohwB8OL
https://photos.google.co...3O-jD9EJ-rzASMxmPfGwzsYM
https://photos.google.co...aolKClGWtWQwxqwyMnz0pLYY
https://photos.google.co...Vtk-JtWuEbV5krGRtBpTbHp8
As the heat shrink tubing has a certain thickness, when placing it back on the track, the track bed must be sunk a little so that there is no height difference in the rail, the tube is white to show well in the pictures.
It works!
Antonio Martínez
www.raildigital.es/davidruso
thanks 1 user liked this useful post by amartinezv
#8 Posted : 15 February 2023 16:33:04(UTC)
Martti Mäntylä
Hi, other members already replied on my behalf. Shrink tube is the key ingredient.
- Martti M.
This page was generated in 0.363 seconds.
