Offline Drongo
#1 Posted : 10 December 2020 04:42:40(UTC)
Drongo
Hi, I need some help to understand the wiring for the Viessmann 1500 (in Australia we call them outside dunnies).
I'm using an EcoS with a m84 and a Marklin transformer 66470. All on c track. I thought I had followed the Viessmann diagram, however, it doesn't work. Maybe someone can help me with a suitable wiring diagram.
Thanks in advanced
Greg
#2 Posted : 10 December 2020 05:25:57(UTC)
Thanks in advanced
Greg
Greg, do you have any wiring diagram what you've done so far ? what roll does the ECoS play ?
https://viessmann-modell...a9/1500kxewJW2tP7K9M.pdf
Offline Drongo
#3 Posted : 10 December 2020 05:37:37(UTC)
Drongo
Thanks in advanced
Greg
Yes John, that's the wiring diagram that I used, however, I find it a little confusing with the brown wire. The EcoS is used to connect to the m84 address and then to switch the door open/closed.
Offline Drongo
#4 Posted : 10 December 2020 07:08:46(UTC)
Drongo
I've managed to get the dunny door to work. Now for the Ladies dunny.
Greg
thanks 2 users liked this useful post by Drongo
#5 Posted : 10 December 2020 11:06:08(UTC)
Greg
This will take you hours BigGrin
Offline Drongo
#6 Posted : 11 December 2020 12:44:43(UTC)
Drongo
Greg
Surprisingly the sheila's dunny didn't take as long as the bloke's. However, the doors open and close at different speeds - the sheila's door stays open for about 3 seconds and the blokes only for 1 second. Does anyone know if it's possible to adjust the timing ?
#7 Posted : 11 December 2020 13:36:29(UTC)
Yes Greg,
But it requires a change of gender !!OhMyGod
BigGrin Laugh
Request Help with Wiring Joystick to Marklin 7051 Crane (General MRR)
by mjborelli 26/12/2022 01:42:54(UTC)
Help with Wiring (Small scale)
by Ricinport 26/02/2021 11:16:10(UTC)
Help with wiring of 76xxx Marklin Signals (Model railroad wiring)
by nelson77 09/10/2010 02:57:01(UTC)
Need basic help with wiring of 1970 era set (Model railroad wiring)
by Alphi 27/01/2010 09:51:34(UTC)
newbie to marklin - needs help with wiring signal boxes (Model railroad wiring)
by hjh10 18/01/2010 03:11:04(UTC)
Help with wiring (H0-scale)
by dalmationx 08/02/2002 02:03:23(UTC)
This page was generated in 0.329 seconds.
