Offline CGuy
#1 Posted : 29 November 2020 03:15:14(UTC)
CGuy
I was at my local dealer today and he had a brown based Marklin C-track that didn't seem to match the profile of standard C-track. I was initially interested in it because the switches were R1 and I have never seen R1's. Also what was interesting is they had thumb wheels for switching the track. Anyone seen this stuff before?
thanks 1 user liked this useful post by CGuy
#2 Posted : 29 November 2020 03:54:00(UTC)
Is it Alpha track?
Alpha was a series of trains for kids produced in the late 80's / early 90's and featured a forerunner of what we know as C track.
https://www.marklin-user...m/posts/t858-Alpha-track
BTW, welcome to the forum.
Offline CGuy
#3 Posted : 29 November 2020 15:32:56(UTC)
CGuy
Is it Alpha track?
Bigdaddynz, after some research on Alpha track that is what it seems to be. Thank you for the info, spot on. Also thanks for the welcome, I am new to Marklin within the past year. A.C. is much easier to deal with.
#4 Posted : 29 November 2020 23:14:46(UTC)
You have been a member since:: 23/07/2014(UTC)
Originally Posted by: CGuy Go to Quoted Post
Is it Alpha track?
Alpha track needs a small modification to connect with standard C track. I can't recall what the difference is off hand, but I'm sure someone will come up with the details.
But that is only needed if you expand your track with c track. If you are using the Alpha track on its own then nothing need change.
Offline CGuy
#5 Posted : 04 December 2020 20:33:10(UTC)
CGuy
Not sure if I plan to adapt my C-track to Alpha. I like it due to the R1 Switch as it is like M-track in that respect but I'm on the fence about it. Thanks for the info kiwiAlan.
#6 Posted : 04 December 2020 21:59:46(UTC)
A very interesting topic Alpha Trains were phased out in 1995 and C-Track was introduced in 1996.
I made a search and you may read here https://www.maerklin-h0-forum.de...is/das-spielgleis-alpha/
So in short:
- the track geometry (lengths, diameter) follows the M track
- the connecting section of the Alpha track is compatible withe the C-track EXCEPT a little plastic piece protruding from a C rail does not exist on Alpha track
It is very easy to remove on one C track to allow the connection.
One other topic: the plastic used. The early C-Tracks were aging very badly (a drop of 40 cm on wood floor would be enough to break them after 10 years of aging).
No panic it is true from 1996 until 2002 or so.
I am not sure but the same may very well be true with Alpha tracks
This page was generated in 0.330 seconds.
