Offline Big AL
#1 Posted : 28 October 2020 20:18:15(UTC)
Big AL
Sorry for the n00b questions.
I am thinking on a split baseboard for ease of storage and transportation and I am wondering on the feasibility of having the split cross 4 sections of straight track at the track joints.
My proposed layout is at this link and the proposed split is the thin black vertical line in the centre of the image.
https://imgur.com/ROS05PY
Should I just forget this idea as practically unworkable in terms of not being able to join eight fishplates?
Also I have only one power feed section. Is that enough? Do I need more? If so, where would they need to go?
Offline Poor Skeleton
#2 Posted : 28 October 2020 22:58:25(UTC)
Poor Skeleton
I think it all depends how good your swearing is. If you are an expert you may be able to deal with the fiddly job of simultaneously aligning eight rail ends, but it will take some championship cursing. I think it would be better to split the baseboard mid track section and have those sections removable, but even that would be quite fiddly unless they're quite long sections, I think.
Exhibition layouts normally just cut the track at baseboard joins, supporting the rail ends by soldering them to a strip of copper-clad board glued to the baseboard, but this is often quite unsightly and will be more so at Z scale.
As for your power feed question, I would suggest at the very least you isolate the two loops at the crossover and feed power to each loop separately. On a single baseboard I wouldn't see the necessity to have any more feeds on a layout this size. However, if you do decide to split it, I'd suggest you have a feed per loop on each baseboard section.
Hope that is of help, all the best
Chris
Offline Big AL
#3 Posted : 28 October 2020 23:33:30(UTC)
Big AL
Haha! I imagine it could get quite sweary. Thanks for the answers. I do appreciate the advice and will follow it. I think I am erring on not splitting the layout. 800x600 is not so big.
Offline phils2um
#4 Posted : 29 October 2020 02:11:49(UTC)
phils2um
Check out this site: http://www.ztrackmagazin...nd_Track_Manual_2004.pdf
It has standards for the interface between z gauge modular RR modules. The standard uses Märkin 100mm to 120mm adjustable length z-gauge track sections, No. 8592 to bridge the gap between modules. If I ever get around to building my z-gauge layout it will be based on these Z-Bend modular standards!
Phil S.
thanks 1 user liked this useful post by phils2um
Offline Bahner
#5 Posted : 29 October 2020 04:38:27(UTC)
Bahner
With some patience and perseverance it can be done (this is only my second layout, first one in Z scale):
The track ends very nearly touch each other (no physical connection), so they must meet precisely in the horizontal and vertical planes to prevent derailing. Numerous male/female electrical plugs located between both halves provide precise alignment and electrical connections. Because they aren't physically connected, each side's track sections have power routed where needed. I decided to go this route to avoid having to connect tiny and fiddly fishplates.
A short video of a consist running the outer track:
Kleinhopfensee Z Scale Outer Track Running Email_083118.wmv (3,072kb) downloaded 21 time(s).
Custom storage boxes:
Kleinhopfensee Box Inside.jpgKleinhopfensee Carrying and Storage Boxes_102019.jpg
Layout is still a work in progress (more photos and details here):
Kleinhopfensee (Z Scale)
Ralph.
thanks 1 user liked this useful post by Bahner
Offline Carim
#6 Posted : 29 October 2020 10:57:26(UTC)
Carim
Unless you are really pushed for storage space, I would not split such a small layout. The first part of my layout was completely portable at 125cm x 55cm (and got stored under a bed - with a suitable cover). I once tried splitting a 120cm x 60cm "N" scale layout; it was more trouble than it was worth (track joining, electrical and scenery problems) and it soon became one board again. Crying
Carim
Offline Big AL
#7 Posted : 29 October 2020 13:58:26(UTC)
Big AL
Guys, thanks for your great replies. I love that Z-bend modular concept.
I live in a teeny tiny UK house where literally if I had two cats I would need to take turns at swinging them.
This is what I am leaning towards... Electrically feeding each loop on both sides of the split as per Chris's suggestion.
I will butt the track together without the fishplates and try for precise alignment using some king of key alignment system on the bases. Maybe a couple of hinges with a removable pin. Or dowels and sockets.
If I don't like how its working it will become one piece, as in Carim's experience. :) Splitting would be a nice to have rather than a fixed requirement. It sure would be more "acceptable" to the management committee in two smaller pieces.
Offline IanC
#8 Posted : 29 October 2020 16:42:34(UTC)
IanC
For a layout this simple, I'd use C track as it is reliable and has no fishplates and set it up from assembling individual pieces of track as I do with my basic Marklin exhibition demonstration layout.
IanC
Offline Big AL
#9 Posted : 29 October 2020 17:18:46(UTC)
Big AL
IanC
I already have all my track Ian, but thanks for the suggestion. I have the S, T2 and a whole load of other boxed track.
This page was generated in 0.455 seconds.
