Offline Thewolf
#1 Posted : 18 January 2020 00:13:50(UTC)
Thewolf
Hi guys Cool
Track C marklin is a reproduction of a track with ballast.
So I'm looking for something to put between the two tracks.
I really don't see what
Do you have any ideas?
Thewolf
Offline Copenhagen
#2 Posted : 18 January 2020 00:53:20(UTC)
Copenhagen
Busch has a ballast (Schotter) especially made for C track (I believe Noch has something very close too). Using a different color for variety works well also (like Woodland Scenics gray in medium size) and then vegetation, flock, grass etc. can be used where appropriate, also something like yellowish sand/gravel can be used.
Offline Danlake
#3 Posted : 18 January 2020 01:46:00(UTC)
Danlake
I agree with above post. Rather than try and replicate the ballast in between tracks it looks quite good doing a different colour. The contrast will make the tracks stand out a bit.
Have a look at Marklin exhibition layout where they use a dark brown underlay between tracks.
Best Regards
Lasse
thanks 3 users liked this useful post by Danlake
Offline PeFu
#4 Posted : 18 January 2020 08:55:12(UTC)
PeFu
Hi guys Cool
Do you have any ideasBigGrin ?
Thewolf
As you plan for 77.5 mm track distance instead of 64.3 mm, you could also place a lake or a city between the tracks... BigGrin
Ofcourse I’m just kidding... This layout ”almost” had me going for C tracks instead of K tracks in visible areas, it could maybe be of inspiration:
I like e.g. the areas where ballast color is the same as the C tracks. ThumpUp
thanks 9 users liked this useful post by PeFu
#5 Posted : 18 January 2020 10:15:49(UTC)
Hello Peter,
Thank you for your post of the video, I enjoyed it very much. BigGrin
You may have seen from my posts that included images of my layout that I am quite enthused with K track for numerous reasons.
As you note, K track can enable close inter-track distances - but to each his own and this wonderful forum has many fine members of eclectic interest variant at power control format, gauge, manufacture, vintage and Märklin track differences - these are the attributes that make it such a magnificent diverse forum !ThumpUp
PJSmile
#6 Posted : 18 January 2020 12:24:03(UTC)
I use the Noch ballast that matches C-track, and I think the effect is very realistic.
thanks 9 users liked this useful post by RayF
#7 Posted : 18 January 2020 12:54:05(UTC)
Go with Rae as his layout with C Track to me looks excellent.
Offline Thewolf
#8 Posted : 18 January 2020 17:29:00(UTC)
Thewolf
Hy gang Cool
Thank you for your suggestions.
They are noted
I can see I'll be spoilt for choice.
Thewolf
Offline Copenhagen
#9 Posted : 19 January 2020 13:16:27(UTC)
Copenhagen
You can see a mix of Busch C ballast and Woodland Scenics gray and brown here:
thanks 6 users liked this useful post by Copenhagen
Offline esgovipa
#10 Posted : 19 January 2020 19:20:24(UTC)
esgovipa
I use the Noch ballast (09376).
In this album you can see the process album
"https://www.youtube.com/profile?user=rapama14"
IC1968
thanks 9 users liked this useful post by esgovipa
#11 Posted : 19 January 2020 21:25:48(UTC)
Nice looking bit of scenery. ThumpUp ThumpUp ThumpUp
The folds in the hills do look natural, not always easy to achieve.
Offline midwestbls
#12 Posted : 23 January 2020 21:09:52(UTC)
midwestbls
I think the greatest contributor to C-track looking more "natural" is to weather - even lightly - the sides of the rails! A bit of dry brushing (almost any shade of gray, black, brown, etc.) across the plastic ballast is also a winner. And if you clip your catenary masts or signals under the roadbed, for sure ballast or cover the "gap" - that looks terrible.
thanks 3 users liked this useful post by midwestbls
Offline dickinsonj
#13 Posted : 24 January 2020 00:48:05(UTC)
I agree. You can get a really nice look with less mess and way less cost and labor, especially for a larger layout by weathering versus the (beautiful) hand laid ballast. I would prefer the later but my plans are for long lines and I can't lavish that much money and effort except in a few areas. The weathered track and ballast are easier to keep clean too, which is a concern for me, after seeing some people's trains after running or storing under poor conditions
BTW - Just figuring this stuff out is really fun for me - I know that I am weird- but at least I am happy. ThumpUp
Offline mbarreto
#14 Posted : 24 January 2020 13:30:26(UTC)
mbarreto
In a Märklin Magazine (German edition) from 1997 or 1999 (I can't remeber but think was from 1999), there was an article about weathering C track.
Beyond painting the rails, I remember the first task was to remove the shine of the ballast. After that thye changed the colour to something close to what is the Trix C track and added some raw painting so that it didn't lok so homogeneous.
Unfortunately I can't remember how it was done, and I also don't remember if I understood it (as it was in German...).
In case during the weekend I find the article, I will take a photo and upload, but probablility of find it is very low.
Miguel
Mostly Märklin H0.
#15 Posted : 24 January 2020 19:12:18(UTC)
On the question of "weathering" C-track, I would like to comment that when ballasted nicely with the Noch ballast and used for a couple of years, the natural effect of trains running and household dust mixing into it will produce quite a pleasantly realistic look.
Others might disagree, but I think there's no need for me to paint the rails or do anything else to this track...
Offline dickinsonj
#16 Posted : 25 January 2020 01:10:17(UTC)
I completely agree with you Ray - that track is perfect and needs nothing but trains running on it. ThumpUp
I think the utility of weathering is for long runs of straight track like the American southwest I want to model as part of my next layout. When modeling very long lines the economy of just dry brushing and getting a good appearance makes sense. I think everyone agrees that doing something like Noch ballast gives a lovely result and is preferable. ThumpUp
I also was interested in your comment about it looking better with time and dirt and thinking Wow, I never thought my poor cleaning habits could have an actual purpose. BigGrin
But seriously, maintaining it over time was a concern of mine when deciding how much of my layout I want to do real ballast on. Definitely in more built up scenes and in my more highly landscaped areas and it is good to know that it just gets better as it ages. ThumpUp
thanks 5 users liked this useful post by dickinsonj
#17 Posted : 25 January 2020 07:03:10(UTC)
You have been a member since:: 18/03/2007(UTC)
I agree that painting the sides of the rail is likely the most effective, but a lot of work.
Try to vary the colours between C track.
I use standard coloured Noch or other scenic texture paper underlays, changing them every half-metre (18 inches) or so.
It looks OK to me for a model train set, and bypasses the mess associated with glues and ballasting.
The more random your colour changes, the better.
Yards are in-fill with cardboard rail to rail.
Offline rrf
#18 Posted : 25 January 2020 13:11:49(UTC)
rrf
Has anyone found an underlay that is a good match for C-Track Ballast?
Rob
Mackenrode Wende Bahn
Offline michelvr
#19 Posted : 22 October 2020 18:38:34(UTC)
michelvr
Hello Serge (Thewolf) and fellow Márklin users,
Seeing the beautiful work done by my fellow Marklin-users.net modellers on ballasting Márklin C track, I thought it was time for me to try my hand at it. BigGrin
Here are a couple of pictures of my attempt. OhMyGod
First, paint the plywood grey. Yes grey not gray as I’m not American, I’m Canadian, eh!
As some of you know I have quite a substantial amount of track to do so to make this easy, I’ve had to come up with a way to do this effectively and most importantly, easily! My solution to tackle this endeavour is to use 1/2 inch/13mm artist masking tape, the reason being is that it sticks really, really well! I’ve tried painters masking tape but that does not stick well enough. I position the tape in the middle of the rail and then press down the sides of the tape so that is covers the wooden tie ends. Then I can brush glue onto the sides of the angled track bed without getting glue on the top of the wooden ties and track bed. I’m using the Noch Grass Glue item number 61130I which seems to work best at letting me brush on a thin coat of glue. Once I get a better feel for doing this, I will post a video.
One lesson learned so far is not to let the glue dry before removing the masking tape as it will remove the ballast that’s stuck to the tape leaving an uneven edge of ballast on the road bed edge!
BTW; I’m using Woodland Scenic coarse grey ballast for the ground covering and fine grey ballast for the angled track bed.
The painting of the track will come once I’ve completed the ballasting of my layout sometime in 2030, Just kidding!LOL
Any question please ask!
Sincerely Michel.
FCD0304A-0BDF-45D0-A881-342D6DB7F4AD.jpegA19E6A22-F62D-4077-A33D-C5FF9E696CF8.jpegE4602B64-98E8-466C-8BD6-F11DD669BA12.jpeg55360885-16ED-4472-A7F4-BA425DA4B5ED.jpeg
thanks 3 users liked this useful post by michelvr
Offline Copenhagen
#20 Posted : 22 October 2020 21:37:47(UTC)
Copenhagen
Michelvr. Thx for sharing pictures. Have you considered the Woodland's medium ballast?
Offline michelvr
#21 Posted : 22 October 2020 22:43:37(UTC)
michelvr
Hello Copenhagen,
Medium would also work nicely too!
I’m using what I have on hand as I have a box full of scenic material which included these two types of ballast in grey.
#22 Posted : 23 October 2020 14:43:13(UTC)
Ballast should have different colours along with weeds etc. using ballast of the same colour without any type of oil patches and weeds just looks wrong. Woodland scenes have track underlay which is not bad and different scatter can be added to it.
Offline harris19
#23 Posted : 23 October 2020 20:13:25(UTC)
harris19
hello all of you.
in my opinion the noch n scale product for ballast is the one you can select.
the noch 09174 looks like Maerklin c track ballast , it is inportand to to remember that if you use the n scale you can correct
the result easily , if you dont like it adding a bigger one ( in my opinion you dont need to for the purpose you want it ).
the colour is very near but if you use vallejo washer you can give an extra focus to the points steam locos sprays some oil to the ground.
Finnaly ,in my opinion the way you do it is the 50% of the success
1st you apply the material and you formed
2st moisturized it with water + (2-4) drops of dish detergent (prevent adhesive to melt with the moisturized ballast) using small areas
3rd fill the area with pla adhesive 50 -50 with water + 2-4 drops of dish detergent (it will look like a small white lake !!!, but dont worry thats good )
let it dry for a day
thank you
Harris
thanks 2 users liked this useful post by harris19
Guest (6)
This page was generated in 1.493 seconds.
