Offline sintra
#1 Posted : 31 August 2020 06:58:04(UTC)
sintra
I have installed ESU LokPilot and Loksound, all v4, in a couple of Marklin locos.
All locos has also been converted into 5-pole motors.
In some of these locos I have also installed ESU PowerPack.
The reflection that I have is that it does help with this PowerPack on a dirty track, but I have never seen any of my locos running for more than maybe 1-2 seconds after power is cut of.
On Youtube there are quite a lot of videos showing locos running a long time after power is cut of. Why doesn't mine do that?
Maybe there is some CV-values that I have missed to optimize?
Which CV's are most important to optimize?
#2 Posted : 31 August 2020 08:42:32(UTC)
Page 44 of the LokPilot V 4.0 manual :
Offline sintra
#3 Posted : 31 August 2020 09:57:25(UTC)
sintra
Thanks for Your replay PJMärklin.
Well, I have tried CV113 a couples of times but to me those values doesn't make any big differences.
It would be nice to hear if anybody at this forum could say that "Yes, I can make my Marklin locos run for at least five seconds after power is cut of because PowerPack has been installed".
Not really because for that I want my locos to run 5 seconds at a none powered track, but maybe they won't "jerk" when passing at spots of dirty track.
As an example, this kind of powerloss would be impossible for my locos to manage.
thanks 1 user liked this useful post by sintra
Offline sintra
#4 Posted : 31 August 2020 10:56:14(UTC)
sintra
Maybe this is an even better example of how it should work:
thanks 2 users liked this useful post by sintra
#5 Posted : 31 August 2020 17:30:37(UTC)
It is also possible that motor makes difference by draw current.
I suppose you need larger capacitor to feed bigger motor, because of the draw current.
Offline applor
#6 Posted : 03 September 2020 23:57:02(UTC)
applor
I use Powerpacks and have adjusted the setting (I use lokprogrammer) so it runs for a few seconds without power. That is all is needed to prevent the loco from stopping.
Mine is set to value 92 which is 3.01s. Setting it longer than needed can cause problems when using emergency stop.
They are only needed on my small locos (ie glaskasten and T3) that lose power or earth when crossing the K track DKW.
thanks 4 users liked this useful post by applor
#7 Posted : 05 September 2020 09:14:27(UTC)
Even larger locomotives do have some contact problem on the tracks grease of dirt on the rail.
You need to use power pack almost to all Märklin locomotives too, because in slow speed they tend to stop.
Offline applor
#8 Posted : 07 September 2020 00:30:18(UTC)
applor
No, I don't have that problem and so do not need power packs except for those mentioned above.
Offline applor
#9 Posted : 21 September 2020 03:24:39(UTC)
applor
Back to the OP, I just finished installing a new powerpack to a loksound 4.0 micro and have the same problem.
Despite setting CV113 to 183 for a 3 second delay, the powerpack does not work when suddenly removing power.
The only difference here is I have connected it to a LS 4.0 micro. The other 2 I have installed were in a LS 5.0 micro.
I will have to enquire with ESU forums/support.
Offline sintra
#10 Posted : 22 September 2020 11:02:49(UTC)
sintra
@applor
That will be interesting to follow.
Offline mbarreto
#11 Posted : 22 September 2020 11:33:45(UTC)
mbarreto
I found this youtube video. Don't know if it helps.
Miguel
Mostly Märklin H0.
Offline Gregor
#12 Posted : 22 September 2020 17:31:59(UTC)
Gregor
Hi Applor,
Have you verified that the decoder output to which you connected the white cable has indeed been programmed as power pack control?
Gregor
Offline applor
#13 Posted : 23 September 2020 02:55:15(UTC)
applor
Well I decided to re-check my wiring and found the problem.Blushing
I had wired it based on notes/photo I took previously of wiring to the LS micro but it was for LS5 micro and not the LS4 micro which is wired differently - despite having the same contact pads as the LS5.
I feel rather sheepish but also relieved it is now working OK. I should have double checked with the manual first.
Guest (4)
ESU Powerpack installation (Digital)
by gwolski 28/01/2018 02:00:39(UTC)
This page was generated in 0.400 seconds.
