Offline mnusair
#1 Posted : 21 July 2020 00:23:55(UTC)
mnusair
I am rewiring the motor drive on the turntable. The old wires that connect the motor and solenoid are not there any more, so I am trying to figure out where to solder each wire. Can anyone help, please?
Marwan Nusair in CincinnatiConfused
Offline mnusair
#2 Posted : 18 August 2020 17:30:45(UTC)
mnusair
I figured it out!!
thanks 1 user liked this useful post by mnusair
#3 Posted : 19 August 2020 12:16:18(UTC)
Originally Posted by: mnusair Go to Quoted Post
I figured it out!!
That's nice, would you care to share with the forum what you did (photos are even better)?
There's no such thing as a Marklin turntable under the article number 6651, maybe you have a Marklin 7286 which is the 3 rail version of the Fleischmann 6651.
Offline mnusair
#4 Posted : 19 August 2020 19:20:01(UTC)
mnusair
FleischmannWiring.jpgThe turntable is made by Fleischmann and I have the Marklin (3-rail) as well as the Fleischmann versions. In both cases the item number on the manual is 6651 or 6651C. I found a circuit diagram from 1989 but I can't figure out how to include a picture of it here.
Edited by user 20 August 2020 23:10:19(UTC)  | Reason: Not specified
Offline dickinsonj
#5 Posted : 20 August 2020 01:36:36(UTC)
Ahhh.. Your first test grasshopper.
#6 Posted : 20 August 2020 01:58:47(UTC)
From
https://www.marklin-user...s/t45367-Signals-M-track
Originally Posted by: rogergags Go to Quoted Post
I tried to add photos but it asks me for the URL.....how do I upload a file?
Edit the message (or start another), then click on the paper-clip icon and follow the prompts to find the photos on your PC and upload
(No point re-inventing the wheel!)
Offline mnusair
#7 Posted : 20 August 2020 23:11:50(UTC)
mnusair
From
Thanks. I think the picture uploaded.
Offline Ross
#8 Posted : 21 August 2020 05:52:15(UTC)
Ross
I see you (name?) found my diagram,
Auto Manual-Wiring for Fleischmann 6652 turntable
Link corrected 31-12-2024
Hope it helps
Edited by user 31 December 2024 05:22:41(UTC)  | Reason: Not specified
Ross
Offline mnusair
#9 Posted : 21 August 2020 21:39:24(UTC)
mnusair
Hope it helps
It was very helpful. My biggest issue was figuring out the distance to the turntable center of each electrical wiper, but the whole thing worked once I soldered new wires and repaired a cut in the solenoid wires. I installed it and it is now earning its keep on my switchable 3-rail & 2-rail layout where I run Hornby Dublo trains using Marklin K-track.
Guest (4)
This page was generated in 0.291 seconds.
