Offline ocram63_uk
#1 Posted : 25 May 2020 12:21:11(UTC)
ocram63_uk
Just a thought, I have a 7186 and a spare m83 decoder.
My EcOS has the possibility to control a turntable which I have
enabled in one of the layout diagrams.
Will the m83 pilot the 7186 roundtable via the EcOS?
After all it has to give the initial impulse to the motor as the turntable is powered by a white transformer.
Just a thought
Marco
Online JohnjeanB
#2 Posted : 25 May 2020 14:27:18(UTC)
Hi Marco
The 7186 needs:
- a switch (like 84) to set the direction by sending a +16VAC (L) to one of the extremity plugs
- an impulse to set the TT in motion by connecting the center plug to +16VAC (L)
Note: the other ends of the Solenoid and the motor are connected to the ground (0) This is the separate plug on the TT
So in short, the best is to use an M84 (2 outputs)
Edited by user 26 May 2020 11:38:15(UTC)  | Reason: Not specified
#3 Posted : 25 May 2020 15:27:52(UTC)
this may help:
https://cabin-layout.mixmox.com/2004/12/Digitizing-turntable-7286.html
The switching module I used is similar to the '84 items from Märklin
Offline ocram63_uk
#4 Posted : 26 May 2020 10:20:55(UTC)
ocram63_uk
so, the m83 decoder is no good at all to do what I have in mind :-(
This is bad.
This page was generated in 0.477 seconds.
