Offline Agustín Urrejola
#1 Posted : 13 May 2020 23:09:13(UTC)
Agustín Urrejola
Chile
Hello, I have a Trix transformer, it is compatible with marklin HO tracks?
#2 Posted : 14 May 2020 00:27:42(UTC)
If the transformer (controller?) is from the 1950-80s and you are trying to drive Märklin locomotives on Märklin tracks, the answer is NO.
#3 Posted : 14 May 2020 01:03:21(UTC)
Originally Posted by: Agustín Urrejola Go to Quoted Post
Hello, I have a trix transformer, it is compatible with marklin tracks?
That depends.
Generally speaking the answer is no, because Marklin analog locos run on AC so would not respond to a Trix transformer which I assume uses a DC output.
Marklin track requires a centre rail pickup shoe on the loco used and the two outside rails are electrically joined (which they aren't on a 2 rail system). You would need a Marklin loco that could run on DC, or a Trix DC loco that had been converted with a centre rail pickup shoe added so that it could run on Marklin tracks to be able to use your Trix transformer.
#4 Posted : 14 May 2020 01:09:25(UTC)
You've raised this question is several threads, please do not do that! It's a sure way to annoy members and forum moderators.
I have merged the replies to your queries into this thread.
#5 Posted : 15 May 2020 09:58:31(UTC)
Contrary to what most ppl say here, you can actually run your old analogue Märklin locos fine. You just cant change the direction.
-Even if it´s not a "compatible" item.
#6 Posted : 16 May 2020 02:05:04(UTC)
Hi Henrik,
Thanks for clarifying that information.
I dug up an old thread on the Trix Express technicals here:
https://www.marklin-user...7899-What-s-Trix-Express
Therein and I quote:
Most TRIX-EXPRESS (TE) is DC. Only early models before ~1953 can be run with AC. But all Marklin transformers (execpt for Z and SPRINT) are delivering AC. So look out for any 12-14VDC-controller. Almost all US-brands used that system.
Markus
Marklin and Trix C Track program (H0-scale)
by michelvr 21/03/2018 03:02:47(UTC)
Marklin and Trix C Tracks not the same? (H0-scale)
by michelvr 30/11/2017 17:17:00(UTC)
Marklin and Trix differences? (H0-scale)
by Wikkedy86 24/07/2017 01:03:58(UTC)
Gaugemaster to distribute Marklin and Trix in the UK again (News from Märklin and others)
by AshleyH 19/03/2015 09:38:24(UTC)
RARE Old Marklin and Trix in Gaggenau (Collector's Corner general)
by Weltenbummler 25/02/2008 10:05:42(UTC)
This page was generated in 0.409 seconds.
