Offline TIM A-B
#1 Posted : 13 May 2020 22:09:19(UTC)
TIM A-B
Hello, I wonder if anyone can provide some advice please ? I recently purchased on Ebay a "new" Maerklin 36501/94424 diesel shunter loco. The motor runs perfectly. However when the engine passes over turnouts/points and also an X intersection it stops and has to be pushed forward or backwards to regain drive. I have a combination of M,C and K track, there are no turnouts on the K track. I notice only the rear axle contains the drive so this may result with inferior traction ? I get the impression the loco drops or becomes stuck on the turnouts ? I also notice this model has an extra long shoe is this the cause of the irregular running ? Is there a small shoe that fits ? I have 12 other locos albeit much larger items which run perfectly over the track .
Any suggestions or is this a problem with base "starter" model ? I am starting to regret the purchase..... Tim
#2 Posted : 13 May 2020 22:57:29(UTC)
Likely need to have the pick up shoe straightened.
Needs to be perfectly flat, perfectly parallel to the chassis and with the springs adjusted to provide enough contact pressure.
If you'd post a picture of the underside , we may be able to offer you some suggestions
Jacques
Offline ktsolias
#3 Posted : 13 May 2020 22:58:41(UTC)
ktsolias
Is a well known problem of these small locos like other 3 axle locos.
Has nothing to do with the pick-up shoe
The problem is that over turnouts there is no good contact of the axles with the metallic rails and the loco loose the earth connection
A solution is a buffer for the decoder
Costas
#4 Posted : 14 May 2020 00:02:15(UTC)
In addition to what Costas states, I've also found that mixing C track and M track on a large layout seems to cause erratic running - I certainly found that out on my layout. Since changing the layout to being all C track I have found the running characteristics much much better.
Offline TIM A-B
#5 Posted : 14 May 2020 08:57:56(UTC)
TIM A-B
OK THANKS ALL. I HAVE ORDERED A NEW PICK UP TO SEE IF THAT REOLVES THE PROBLEM, THANKS AGAIN FOR ALL YOUR ADVICE. TIM
Offline TIM A-B
#6 Posted : 18 May 2020 14:34:20(UTC)
TIM A-B
Hello Costas I found this on the Marklin site " Gauge H0 - Article No. 60974
Buffer Capacitor with Built-In Load Circuit for mLD3 and mSD3" I this the item ? If so will it fit under the body shell? Is it difficult to fit ? Any advice much appreciated. Thanks Tim
Offline ktsolias
#7 Posted : 18 May 2020 19:55:20(UTC)
ktsolias
Hi Tim
The 60974 is only for retrofit decoders and connected to the SUSI socket.
So this is not your case
Costas
Offline TIM A-B
#8 Posted : 18 May 2020 20:26:41(UTC)
TIM A-B
Hi Costas thanks for . So how do I configure a buffer for decoder on this loco or is it a too involved procedure? Thanks and regards Tim
Offline ktsolias
#9 Posted : 18 May 2020 22:20:07(UTC)
ktsolias
I use this one
Costas
Edited by user 19 May 2020 15:51:33(UTC)  | Reason: Not specified
Offline TIM A-B
#10 Posted : 18 May 2020 22:59:39(UTC)
TIM A-B
Many thanks Costas, Tim
Offline ktsolias
#11 Posted : 19 May 2020 15:58:55(UTC)
ktsolias
This is the picture of my DHG 500 3078
motor 60943
Decoder 60760
And the small buffer in the front made by me
I use the biggest capacitor who can fit inside each loco
Costas
Offline TIM A-B
#12 Posted : 19 May 2020 16:37:18(UTC)
TIM A-B
Thanks very much Costas very helpful. Appreciate your time. TIm
This page was generated in 0.346 seconds.
