Offline W3Machinist
#1 Posted : 14 February 2020 01:25:40(UTC)
W3Machinist
I want to have a 6036 distant signal and a 6039 main signal tied together into 1 set of ports on a K83.
My concern is will there be enough power to work both signals at the same time or do I have to separate each signal to separate ports.
Any idea will be greatly appreciated.
#2 Posted : 14 February 2020 04:27:43(UTC)
They are working together in the same port of the K83.I am working five 7036 with five 7039 and two 7038 with two 7041 signals in my layout without any problem at all.I am working them for 15 years with 6021 controller and for two years with CS 2.
Offline TEEWolf
#3 Posted : 18 February 2020 01:46:36(UTC)
Confused Confused Confused He is not writing from 6036 and 6039?
#4 Posted : 18 February 2020 06:02:13(UTC)
I think our friend obviously meant 7036 and 7039,i thought it would be unpolite to correct him.
I hope i helped him.
Offline W3Machinist
#5 Posted : 23 February 2020 21:18:47(UTC)
W3Machinist
Thank you for your consideration, you are quite correct about the 70series signals, senior moments happen more often now, that is why I always keep my I.D. handy.
Thank you all for your help.
Woody
thanks 1 user liked this useful post by W3Machinist
eCoS to M track points to marklin k83 (Model railroad wiring)
by Ausipeet 26/09/2021 06:32:55(UTC)
Marklin k83 (H0-scale)
by plane2557 08/02/2010 08:01:28(UTC)
Marklin k83 (60830) power source (Digital)
by francoisw 13/07/2009 12:36:21(UTC)
Non marklin K83. (Digital)
by steventrain 15/01/2006 13:36:04(UTC)
This page was generated in 0.212 seconds.
