Offline LongHairedDavid
#1 Posted : 28 November 2019 11:29:45(UTC)
LongHairedDavid
I am thinking about utilising one of my Viessmann colour lights to act like the Marklin signals - i.e. provide a braking section before the light controlled by the light.
To do this I need some of the red insulators for the pukos. I can't find these on the Marklin web site.
Does anyone know the part code for "4 Insulator sleeves (red) for C track (1 sprue)" as supplied with the Marklin signals?
Long Haired David
AKA David Pennington
A mystified Maerklin Newbie
Offline mbarreto
#2 Posted : 28 November 2019 13:12:33(UTC)
mbarreto
74030 ?
Miguel
Mostly Märklin H0.
#3 Posted : 28 November 2019 14:01:36(UTC)
74030?
Wrong answer to the question, that's a bag with 8 insulators.
But probably that's the solution to the problem. I'm afraid you cannot get 4 insulators only as a spare part. And if you can it's probably more expensive anyway.
But maybe there is a spare part number to order just 4...
Offline mbarreto
#4 Posted : 28 November 2019 14:49:41(UTC)
mbarreto
Yeah! BigGrin
Miguel
Mostly Märklin H0.
#5 Posted : 28 November 2019 15:05:34(UTC)
LongHairedDavid
74030?
I am happy with 8. I only said four because I copied and pasted from the instructions for my current color light signal. Thanks. I can get on nowWe
Long Haired David
thanks 1 user liked this useful post by LongHairedDavid
#6 Posted : 28 November 2019 17:22:06(UTC)
74030?
If you cannot find some in a hurry you can use thin plastic sleeving. I have used heat shrink tube before now.
The picture shows some (gently) shrunk and unshrunk HS sleeving on track pieces. Gently shrinking the sleeve makes it easier to mate the next track piece.
#7 Posted : 28 November 2019 19:42:57(UTC)
LongHairedDavid
I like that. I have a good stock of shrink wrap so I will give it a go. Thanks for the idea
Long Haired David
#8 Posted : 29 November 2019 04:23:19(UTC)
The heatshrink isn't a bad idea. The Marklin insulators to be honest are rubbish, they get pushed down into the opposing track piece by the by the 'sprongs' (for want of a better word) that Alan shows as being heatshrunk in his picture.
I have been cutting the inside sprong off (which is the centre pukos sprong) to make sure - I cringe every time I do it - there must be a better way!
I have experimented with putting a cut down insulator in behind the main one to stop it being pushed back. That seems to work OK, but means you use two insulators.
