Offline drstapes123
#1 Posted : 25 November 2019 04:38:12(UTC)
drstapes123
hi All,
I have recently acquired a nice 3015 crocodile which has not run recently. It does not run at present as power causes buzzing and the lights to come on brightly with no movement. I assume a reverser or a brush problem. I rather quake at trying to dissemble this complex loco. Is there anyone in the UK that could service this for me or failing that have a photocopy of the schematics to give me a clue to opening the engine
Thanks in advance
Geoff
Offline Markus Schild
#2 Posted : 25 November 2019 08:16:46(UTC)
Markus Schild
Hi Geoff,
welcome to the forum. Your description sounds like the loco is suffering from the "hardened oil syndrome". Märklin used an oil which becomes a gear-glue with the decades. I prefer a product sold as "SR24" to clean the loco, other people just use lighter gasoline to wash out the gears.
Some documents for the loco:
3015-ya-1063.pdf (649kb) downloaded 85 time(s).
3015-a-0174-ru.pdf (530kb) downloaded 70 time(s).
ba-3015-68315-tn-0265-ka.pdf (2,794kb) downloaded 65 time(s).
Markus
thanks 6 users liked this useful post by Markus Schild
Offline drstapes123
#3 Posted : 27 November 2019 01:14:26(UTC)
drstapes123
Hi Geoff,
Markus
Hi Marcus, thanks for your reply. The links to further details are very helpful. on the underside of the loco is a black cover which when removed shows the underside of the armature. Also I can see both drive shafts which can be rotated and which turns the wheels. That makes "Hard Oil" less likely I believe.
Geoff
This page was generated in 0.314 seconds.
